Question about Traxxas Rustler Vxl Brushless Stadium Truck Rtr 24ghz
Lipo battery i plug my lipo battery in and the light is red and not green... i have no idea why it is not turning green am i not doing something right
    New Friend:
Hold the button on the esc down for 10 _12 seconds and you will here a rising musical note, the light should go green mean low voltage detection is on.. Cheers and good luck
Posted on Jan 02, 2013
  • 31 Answers
Yes tell your dad
Posted on Jul 13, 2010
On the e -flite 2-3 cell lipo balancing charger,
That's what's happening to me I bought another battery it still didn't work so I thought it was the charger I bought a new charger and the same thing happened now I don't know what to do
Oct 26, 2013 | E-Flite Eflc3110 2-3 Cell Lipo Balancing...
Tip
Trailer Wiring
Hello all,
For those of you that need to wire up a trailer or have to occasionally borrow trailers and look at the wiring plugs with disdain (I mean face it they don't make sense, grd is white, +12vdc is black, etc), this is for you.
Plug Types/Application
7 Way - RV Trailers, Horse and Utility Trailers
6 Way - Horse, Stock and Utility
4 Way - Utility Trailers
Columns are: Color, Function, Mark on the plug.
Seven wire Trailer plugs:
Horse, stock or utility trailers:
White = Ground - 1
Blue = Electric Brakes - 2
Brown = Tail and clearance lights - 3
Black = Battery, aux power - 4
Yellow = Left turn/Brake - 5
Green = Right turn Brake - 6
Orange or Purple (not both) = Auxilliary or Reverse - 7
Recreational Vehicle:
White = Ground - 1
Green = Tail and clearance lights - 3
Red = Left turn/Brake - 5
Brown = Right turn Brake - 6
Yellow = Auxilliary or Reverse - 7
Six wire trailer plugs:
White = Ground - GD
Yellow = Left turn/Brake -LT
Green = Right turn Brake -RT
Brown = Tail and clearance lights - TM
Red or Black (not both) = Battery, aux power - A
Blue = Electric Brakes - S
Recreational Vehicle: (color, use, plug mark)
White = Ground - GD
Brown = Right turn Brake - RT
Green = Tail and clearance lights -TM
Black = Battery, aux power - A
Red = Left turn/Brake - LT
Four wire plugs:
White = Ground
Ground should be 10ga.
Others 14 ga
A test light and a 12VDC power source can be handy for trouble shooting.
Best regards
Mike
on Jan 09, 2010 | Cadillac Escalade Cars & Trucks
Tip
Trailer Wiring Cheat Sheet
Hello all,
For those of you that have or occasionally borrow trailers and look at the wiring plugs with disdain (I mean face it they don't make sense, grd is white, +12vdc is black, etc), this is for you.
White = Ground - 1
White = Ground - 1
White = Ground - GD
White = Ground - GD
Four wire plugs:
White = Ground
Others 14 ga
Best regards
Mike
on Sep 23, 2009 | 1998 Ford Explorer
How do you change modes between lipo and nicac
push switch to turn on truck then Hold down the esc switch for approx ten seconds. You will hear a chime and then the led should change from either~ red to green ( Lipo mode) or from green to red ( Nimh mode)
Aug 22, 2011 | Traxxas 110 Slash Truck Mike Jenkins
I just got a traxxas stampede in dec. i have used it about ten times and now i am having issues when i go to turn it on the green light on the esc comes on and then goes to red and then the light goes off...
make sure ur batteries are fully charged and ur using the right ones for ur model reset ur transmitter to factory default, it sounds like the esc is detecting something wrong when u go to use it bad battery if its a lipo may have ran it to long which can mess them up, I would clean the button on the esc really good, if the truck is making that noise the esc will try to shut down the system if all else fails send in ur esc to traxxas and they will send u a new one for like $50 buck let me know if u get it going
Aug 22, 2017 | Electric Traxxas Stampede Xl-5 Rtr ...
Tip
Hello all,
White = Ground - 1
White = Ground - 1
White = Ground - GD
White = Ground - GD
Yellow = Not used -
Four wire plugs:
White = Ground
Others 14 ga
Best regards
Mike
on Sep 19, 2009 | 1987 Jeep Wrangler
Tip
Trailer Wiring Standards (Color Codes/Plug Marks)
Hello all,
Columns are Color, Function, Mark on the plug.
White = Ground - 1
White = Ground - 1
White = Ground - GD
White = Ground - GD
Yellow = Not used -
Four wire plugs:
White = Ground
Others 14 ga
Best regards
Mike
on Sep 09, 2009 | 1981 Ford F 150
The LED on the XL-5 is solid red after programming. The model operates normally, but the light is supposed to be green. What is wrong?
Press the ez-set button on the esc (the one with the heatsink) for ten seconds until it changes color and gives a beeptone,green is low voltage detection on for use with lipo batteries,if they are fully discharged they are dead,the detection system cuts power beyond 3v per cell so that the lipo isnt dameged
Dec 25, 2010 | Traxxas Rustler Vxl Rtr
Wiring towbar for t25 volkswagen
Hi Paul,
This should help,
White = Ground - 1
White = Ground - 1
White = Ground - GD
White = Ground - GD
Four wire plugs:
White = Ground
Others 14 ga
Best regards
Mike
Sep 15, 2009 | 1986 Volkswagen Wagon Camper
Trailer wiring
Hi Smokey,
I've got them for Six and Four wire plugs
Six wire plugs:
White = Ground - GD
White = Ground - GD
Yellow = Not used -
Four wire plugs:
White = Ground
Others 14 ga
Best regards
Mike
Jun 29, 2008 | 2005 Ford Five Hundred
Traxxas Rustler Vxl Brushless Stadium Truck Rtr 24ghz Logo
193 people viewed this question
Top Traxxas Toys Experts
gbob59
paul tooker
Tom Chichester
Are you a Traxxas Toy Expert? Answer questions, earn points and help others
