Question about Danby DAC9003D Air Conditioner
Not that cold and not much watewr coiming from the backofit
  • Danby Master
  • 43,501 Answers
There can be a couple of things that could be happening...
The first and easiest thing is to check the air filter. Make sure that it is clean... clean it or replace it. Next check the air vents to make sure that they are open and giving you good air flow...
Also check to make sure that you are not icing up on the indoor coil... ice will tell you that you are low on refrigerant. You also could be low and not be icing over, but you would need to have gauges on the unit to check that.
Finally check and clean the outdoor coil...this also can give you problems if the heat is not being removed from the outdoor unit efficiently...
You may also have a unit that is sized in such a way that it hits the balance point at about 85...that means that your heat gain is equal to the capacity of the unit...I often try to size them for about that here in Northern PA. because wqhen seldom get hotter then that and the unit then is much more effective at removeing humidity at lower temperatures...
You can also check out the tips that I have wrote about Air conditioningnot that cold and not much watewr coiming from the - 2_bing.gif trouble shooting and maintenance...
Here is one about cleaning the condenser coil and at the bottom of that one are links to others..
Condenser Coil Cleaning Condenser Coil Cleaner
http://www.fixya.com/support/r3850183-condenser_coil_cleaning_condenser_coil
heatman101
Posted on Jul 12, 2010
Water want drain
HAVE YOU CHECKED THE INLET SCREEN TO THE WATEWR PUMP? IF NOT PULL THE LOWER PANEL BELOW THE DOOR AND THE PUMP SCREEN FILTER IS RIGHT THERE.
Apr 07, 2012 | Maytag Neptune MAH5500B Front Load Washer
THE MACHINE BLOWS BUT DOES NOT TAKE THE WATEWR OUT OF THE AIR
Sounds like a refrigeration leak or the compressor isnt coming on. truthfully as cheap as dehumidifiers are it's probably more cost effective to buy a new one.
May 09, 2011 | Midea Dehumidifiers
Watewr is not pump0ing in to machine
that is one of two problems, your solenoid is damaged that open and close the water for you and secondly your mesh that keeps the dirt of the water out of the machine is blocked. 1st remove the pipe at the back of machine and pull out the mesh, if it is blocked clean it and replace, put back the pipe and test, if the problem are still present open the panel and test the solenoid. if you use only cold water and the solenoid is o.o.o i suggest you change the pipe to the hot water side that should solve the problem
Dec 12, 2010 | LG WFT1071TP Top Load Washer
Kodak wont install >>
i just installed my old kodak easyshare disc onto my new computer but when i am in the installation process it coimes up with the error code 11-84-32 ande it says that it cannot complete the installation. whats wrong?
Apr 14, 2010 | Kodak EasyShare C330 Digital Camera
DRIVE OUTPUT NOT COIMING & LCD mointor
hw to select a drive depending on current rating
Mar 13, 2010 | Lenze AC Tech Lenze 8100 AC Drive Inverter
Model MSD2555DR Refrigerator very low watewr flow from water despenser.
IF YOUR MODEL HAS A FILTER YOU MAY NEED TO CHANGE IT. SOME TIMES JUST TURNING OFF THEN BACK ON THE WATER SUPPLY VALVE WILL HELP. THIS CLEANS OUT THE VALVE..GOOD LUCK!
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Jan 14, 2010 | Maytag Refrigerators
How do i removed the ink cartridge from my printer? - Canon PIXMA iP4600... Thanks
just open the cover and the cartridge will just coime out for you to easily remove it
Dec 01, 2009 | Canon PIXMA iP4600 Color InkJet Photo...
Cold spot not making ice
you may need to plaug in the solonoid
look for a tan and whit connector
and the paddles on the soloinoid
right behind the panal where you connected the watewr
Oct 08, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Noise coiming from drive box at 70 mph vtx 1300 c
could be chain needs adjusted or loose sprocket
Aug 04, 2009 | Honda VTX 1300 C Motorcycles
No picture on initial portable dvd player
Make sure it's not turned to a different output, like it expects to be plugged in to a tv screen.
Mar 02, 2009 | Initial Televison & Video
Danby DAC9003D Air Conditioner Logo
112 people viewed this question
Top Danby Heating & Cooling Experts
Dennis Boxerman
1STHVACMAN
Mike
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
