Question about Whirlpool Duet GHW9150P Front Load Washer
I have an error of f 35 and can't find any information on problem? whirl pool front loader
    Genius:
  • 1,417 Answers
what this sign indicate is an error code meaning that there is over flow of water around the panel connected to the lens reader,
what you will have to do to fix up the f35 code problem on the screen of your washer is to unscrew (open) the washer with stroll driver with care then trace the wire(power supply) down to the panel and the screen then clean up all for of liquid or water around them with care with out disconnection of wire .please note this information do not use any form of liquid to d the cleaning then make sure that power supply is disconnected from the washer before working on it then couple it back as it was
Rate this if it help
thank you and thanks for using fixya.
Posted on Jul 11, 2010
Clutch for whirl pool 5 speed 9 cycle top loader washer
only available from a whirlpool service agent spares or from the whirlpool parts web page
Feb 06, 2017 | Whirlpool Washing Machines
Ld code. It won't drain. Not the drain pump (I changed) and not clogged pipe.
Slow drain code. How high is the outlet pipe ABOVE the machine?
Jan 05, 2016 | Washing Machines
It makes all the noises but dose not turn around how can i fix it. Its a whirl pool ultimate caire 11 top loader.thanks
Hi!!
The noise is your loose or broken belt. Take the cover off the back to access it, re-install or replace it.
While you're at it, check and clean the exhaust pipe. It will work better and save you some $$$$$$.
Good Luck
Mar 30, 2010 | Whirlpool Ultimate Care II GSW9650LW Top...
WHAT IS ERROR CODE 35 OR ERROR CODE 37? ON MY FRONT LOADER.WFW9600TA00
does it say f35 and sud?
you need a new pressure switch
sounds like a new washer is it 1-2 years old?
Jan 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My whirl pool washing machine no longer spins. I just stopped on day. I can hear the motor trying to turn the drum but it doesnt.
Hi. This is a possible broken belt. You will need to access the drive assembly to confirm. The symptoms you have posted will often lead to a separated belt.
NOTE(IF this is a top loader, and you are hearing noise during the spin attempt, this will lead to failed motor coupler. Please disregard this note if the unit is a front-loader)
Oct 08, 2009 | Whirlpool Washing Machines
No power
The following link explains how to replace the drain pump on a Whirlpool Duet:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
If you have questions about this repair, or need additional assistance, please let me know. I hope this helps you.
Sep 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirl pool duet
Lets run a diagnostic test selecting drain/spin, on spin speed select no spin then press prewash quickly twice, watch for F error codes and write them down, press prewash again to advance past error code seen. Then post back because there are several issues here that can cause this, motor sensor errors, serial communication errors, pump and drain siphon issues.
Sep 14, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirl pool front loading washer
F 06 has to do with what they call a tachometer error from the mcu. This little white box is usually on the bottom of the machine. I would first un plug and re plug all the connects top and bottom using the tech manual also at the bottom in a manilla envelope. Is your machine less than a year old? If it is call and get in warranty repair for defects.If not and reseating the connections doesn't help you will need a mcu.188 at repairclinic.com
Sep 10, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
62 people viewed this question
Dan Webster
Dan Webster
Sal De
