Question about Malibu ML200RT - Low Voltage Power Pack -200 Watt - With Timer - Plastic Ho
Clock does not work,manual operation turns light on
You posted under Intermatic-malibu power packs.
There are no replacement clock motors.
Improvise by setting timer to override and plug power pack into cheap plug-in timer.
For information on Intermatic/Malibu power packs showing troubleshoot steps, replacement trippers, useful links, warranties and tips:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Posted on Mar 21, 2011
BO6255SS - The clock turns on but we are unable to set it and therefore cannot turn it on. Can you help?
this is as much as the manual says
After your appliance is connected to your mains supply for the
first time, the numbers on the timer display will flash. Before
you can select a cooking function or set a temperature, you
must set the appliance into manual operation mode.
o To select manual operation mode, press the manual operation
button (9) on the control panel.
http://www.manualslib.com/manual/956107/Baumatic-Bo625ss.html?page=3#manual
Jun 02, 2016 | Baumatic Ovens
Hi, i missed the operational manual of my LEXON LA-78 CUBE CLOCK RADIO and i cant make it work properly. If you have the manual, please send it to my mail account. Best Regards Sotiris
I have a scan in of the instructions for the LA78 - not very clear but adequate. If the problem is you don't know how to tun off the radio alarm set icon, hold down the Snooze/Light button 2 secs (blue display will light up)
Aug 16, 2011 | lexon iHome IH12BR Cube Clock Radio wiPod...
Subaru Forester, 2003. clock light and dome light not working (clock works, just no light at night). all other dash lights appear to function. i replaced fuse marked 12 in engine fuse panel, described...
The clock works, correct? It is just not illuminating when your headlights are turned on? If this is the case then it is most likely that you have 2 burned out bulbs. The forester clock bulb is Sylvania bulb part #2723
Hope that helps! I have a bunch of clock related info on my website www.autoclockrepair.com. Let me know if I can be of assistance.
May 09, 2011 | 2003 Subaru Forester
When I turn on the wall oven it will not heat up, the light doesn't come on
If the oven element or the indicator light don't come on it sounds like a timer problem. I assume the oven has an electronic timer/clock. The timer must be in manual mode for the oven to work. If so, turn the oven ON. Then operate the clock/timer buttons to get it in the manual mode. Be patient. When the oven indicator light comes on it is in manual mode.
Please vote for me if this helps you.
Mar 05, 2011 | Ovens
I have a Fisher & Paykel OS302. The temperature and oven mode selects are dead, no LED display, no operation. The clock module is working. This happened all at once, I tried to turn it on and both...
This sounds as if the electronic clock timer is in automatic mode. It must be in manual mode for the oven to work. Turn the oven on and play around with the timer controls/buttons. When the oven indicator light comes on the clock is in manual mode.
Feb 26, 2011 | Fisher and Paykel AeroTech OS302 Electric...
The manual switch works but the timer does not rotate. The timer knob is properly placeed into the geared drive but the timer motor does not seem to be operating.
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/e1010%20-%20english.ashx
Half of the online manual is upside down.
According to the manual, the clock motor that operates the timer requires a separate Neutral wire.
The clock motor is a separate circuit, just like your alarm clock.
The wiring is:
Black-hot-from-breaker connects to timer-black wire
Wire-to-Load connects to timer-red wire
Timer-white wire connects to Neutral.
The Neutrals are white wires twisted together and covered with a wire nut.
Not every box has Neutrals ... in that case, connect timer-white wire to bare copper wire.
Bare copper wires connect back to the Neutral busbar in breaker box.
Attaching your white wire to ground is not code, but it will work.
How to test your wires:
Separate wires
Turn on power
Test each wire to bare ground
Tester lights up on Hot wire from breaker
Now test Hot from breaker to each of the other wires, except ground.
Tester lights up on Neutral
Nov 09, 2010 | Intermatic Timer E1020, Single pole/single...
Time wheel stopped moving.
You posted under the Intermatic T-101
Troubleshoot:
Check if manual override turns Load on and off
If manual override snaps clean and crisp, and Load operates correctly, then you can replace the clock motor.
If manual override does not work very well, then you can buy another T-101 and swap out insides without changing box.
If manual override snaps clean and crisp, but Load does not come on, then check your electricity at breaker and check if wires are tight inside the timer.
Clock Motor
T-101: replace with T100series 120Volt clock motor
T-103: replace with T100series 120Volt clock motor
T-104: T100 series 240V clock motor
Where to buy clock motor:
http://www.grainger.com/Grainger/timer-accessories/timers/electrical/ecatalog/N-8hi
How to replace clock motor:
Turn off power.
Take a photo of your wiring so you have a record of how wiring looks.
There are two small white wires that go to clock motor.
Inside box, there is a release lever located top of box.
Push release lever up and timer mechanism tips out.
Lift mechanism up slightly, and then tip all the way out.
Clock motor is held by tiny screws or tiny star-screws
Swap motors.
Attach clock motor wires on front terminals in exact location they were connected before.
Turn screw terminals very tight against copper wire.
Nov 04, 2010 | Intermatic T101 - 24 Hr. Dial Time Switch...
The old timer that was there quit working tryed to put a new woods one in but cant get it to work help
The following wiring diagram works for Woods, GE, Hagar, Leviton, Sylight, Utilitec, some Intermatic in-wall timers.
It does not apply to Aube timers or Intermatic battery-operated timers.
If the wires are not connected correctly, the timer will not operate as expected.
Click the manual override and see what happens.
If the lights do not turn ON with the manual override, then the wiring is suspect.
If the lights blink, then you have put the red and white wires together.
If the lights turn ON, but timer clock is not working, it is possible you have the black and red wires reversed.
If the white wire is not connected correctly, the clock mechanism will not operate.
Review the wiring.
Black-timer wire goes to black-hot-wire from breaker
Red-timer wire goes to black-wire going to Load (lights)
White-timer wire connects to the Neutral wires that are usually twisted together and covered with a wire nut.
IF your box does not contain those white wires, then you can work-around by connecting white wire to bare ground wire.
Nov 02, 2010 | Woods 59028 Programmable Timer Switch...
Just installed a T101. Unit will not switch to on position works perfectly to off position. Can it be adjusted.
Yes.
Programming Instructions for the Intermatic T101 - 24 Hr. Dial Time Switch:
1. TO SET ON AND OFF TIMES: Hold trippers agains edge of clock-dial, pointing to time (AM or PM) when ON and OFF operations are desired, tighten tripper screws firmly. For additional tripper pairs on CLOCK-DIAL order 156T1978A.
2. TO SET TIME-OF-DAY: Pull CLOCK-DIAL outward. Turn in either direction and align the exact time-of-day on the CLOCK-DIAL (the time now, when switch is being put into operation) to the pointer. DO NOT MOVE POINTER.
Operating Instructions:
* To operate switch manually: move manual lever below clock-dial left or right as indicate by arrows (graphics) This will not efect next operation.
* In case of power failure, reset clock-dial to proper time-of-day. See Programing Instructions (top lines).
Good luck (reemmber rated this help).
Oct 23, 2009 | Intermatic T101 - 24 Hr. Dial Time Switch...
Malibu ML200RT - Low Voltage Power Pack -200 Watt - With Timer - Plastic Ho Logo
513 people viewed this question
Top Malibu Hardware & Accessories Experts
Gene Haynes
Scott Jelt
Scott Jelt
jdthefixer
Are you a Malibu Hardware and Accessory Expert? Answer questions, earn points and help others
