Question about Porter Cable 345 6" Circular Saw Saw Boss
I have a Porter Cable 345 6" saw "3" series. Do I need to oil this baby?
  • 90 Answers
Unless it has a gearbox with a plug, no. the bearing are sealed. where the saw breaks down the middle, the metal part from the plastic part, there is grease in that gear compartment.
Posted on Aug 30, 2010
Need a power cord for a porter-cable circular saw model 146
All of Porter-Cable's circular saws have model numbers starting with a 3. Assuming your saw is a 346, Porter-Cable's part number for that cord is 330079-98. If your model number isn't 346 or you can't get that part number, most any nine to twelve foot 14-2 power cord will work on your saw.
Feb 24, 2013 | Porter Cable Saws
Need to replace the cord. Before I open it up, wanted to verify that it has serveceable connectors inside?
generally they have ring terminals on the switch or the wires need to be soldered to be pushed into and lock into the switch. ON some rare occasions I have seen wire nuts, so you should be OKAY just make yourself a wiring diagram before removing anything, it makes reassembly easier.
Aug 01, 2011 | Porter Cable 345 6" Circular Saw Saw Boss
What weight oil do I use in Porter Cable 637 Type 1 Variable Speed Tiger Saw?
use sewing machine oil, or 3 in 1 oil, you could use WD40 as well. but not motor oil
Mar 21, 2011 | Porter Cable Variable Speed All-Purpose...
Where do I find a parts list or be able to get parts for porter cable 6" boss circular saw
Go to http://servicenet.deltaportercable.com/
On the left hand side, you'll see a search box where you can enter your model number.
On Delta ' Porter-Cable tools, the model number and type number are usually on the warning label or name plate.
  • These labels are typically found on the bottom or side of the tool.
  • For larger equipment, the label can be found on the top of the equipment.
  • Sometimes the type number is reflected at the end of the model number. The type number can be followed by a " - " or a "T" at the end of the model number. For example: "HFAC3030-1", is a Type 1. "36-450 T2", is a Type 2
Dec 29, 2010 | Porter Cable 345 6" Circular Saw Saw Boss
I want to test the armature to solve a brush arcing problem I have a volt meter. how to do this?
put your test probs on the armature and hold them were the brushes tuch on eather side you should get a reading from all of them "one at a time" check the commutator for burn marks or big gaps,,,if there there scrap the motor,
Aug 08, 2010 | Porter Cable Porter-Cable 6" Saw Boss 345
Change the blade on my porter cable 347
Here is the owners manual for your saw. It details the procedure for removing and installing a blade.
Please rate this positive if it helps!
http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/Porter-Cable/En900003.pdf
Jul 03, 2009 | Porter Cable Cable 7 1/4" Quik - Change...
Porter Cable 345 6" Circular Saw Saw Boss Logo
127 people viewed this question
Top Porter Cable Saws Experts
Marvin
Marvin
Frank Mangiapane
Level 1 Expert
Jim Thurston
Are you a Porter Cable Saw Expert? Answer questions, earn points and help others
