Question about Dryers
My gas dryer ignites and runs fine for about a minute or so and then the flame shuts off...... What do you think the problem could be?
    President:
  • 1,430 Answers
The problem is the dryer coils are failing. They tend to fail as they heat up.These are inexpensive and easy to replace. Heree is a video that should help. http://appliancehelponline.com/gdryertroubleshootge.html
Posted on Jul 11, 2010
  • 478 Answers
Sounds as if you have a clogged exhaust. Pull off the exhaust and then try it if it works then just get a brush at a hardware store especially for this propose. You may also use a vacume.
If it still fails the flame sensor mounted on the left front side of flame tube may be either dirty or not operating,unpug the drier and remove it with one screw, clean and check. Its a faily cheap part less than 25.00.
Why does my dryer turn off after it heats for about 2 minutes
Remember the igniter has to go on and off several times every little while. Its possible a bad igniter or Thermo coupler
that is your problem.
Dec 30, 2017 | Dryers
Gas Dryer Ignition Issues
did you try bypassing the cycling t-stat also?
Aug 25, 2012 | Samsung Dryers
My gas dryer starts fine than the flame goes out
replace the coils. i promise you. and here is a guide to most gas dryer problems that even a kid can see.
starts fine, cycles off, igniter comes on, hear a click, and no flame.-coils.
(can also be intermintent)
igniter stays on, no flame.-flame sensor
no glow from igniter.-igniter
remember, always allow about one minute for ignition.
Oct 06, 2009 | Frigidaire GLGR331A Gas Dryer
Gas dryer heat is intermediate
does the igniter glow white or orange? if it is orange you need to replace it. has to be white hot to ignite. if the igniter is white it could be the coils not opening the gas valve all the time - an intermittent problem.
Oct 04, 2009 | Kenmore 73952 Gas Dryer
After starting my GE gas dryer , the burner fires and everything seems fine . The burner stays on for a few minutes and shuts off like it's supposed to . After a few minutes , the glow element turns on to...
Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
Aug 01, 2009 | Dryers
Gas dryer burner cuts off after a few minutes of use
Your gas solenoid coils are bad. Replacing them will solve your problem.
May 17, 2009 | Whirlpool Dryers
Heat runs ten minutes than heat shuts off continues to run
I'm thinking the thermostat has failed, it get's too hot and the emergency over temp sensor kills the flame before a fire is started.
Apr 07, 2009 | Kenmore 63942 Dryer
Maytag gas dryer fires, then shuts down
may be the coils on the gas valve. there are 2. usually they need replacing when the ignitor glows but no flame
Nov 20, 2008 | Maytag Dryers
Open Questions:
Dryers Logo
71 people viewed this question
Top Dryers Experts
