Question about Toro Garden
#20064--Ser#280062204 Toro 22" Recycler Lawn Mower Started making a loud "ticking" noise during use and would only go into drive intermittingly.Mower is only 1 year old,has been used maybe 50 times.Adjusting cable as per user manual has not been successful and I cannot remove the plastic cover on front of deck.
  • 2,272 Answers
It sounds like the caarb floats have varnish (a natural byproduct of cheap gas) on them. This varnish will not allow the floats to slide up and down in their slides. Simply removing the bowl on the bottom of the carb (near the air filter)will show you the slides and float. With a clean rag wipe the brown varnish off the slides. drain gas into a can before you remove carb parts, otherwise it will drain onto the mower deck. after replacing all the parts you may have to re adjust the carb needles for air and gas mixture. here is a link to where to find the diagrams. First thing I would do is see if the engine rotates. Remove the spark plug and see if you can spin the engine. If so, then it should be fine. If not, make sure there is not something with the drive system, blade, or starter that is binding and preventing the engine from rotating. Next repair the starter, the pull string starter.
99% of the engine problems today are caused by dirty carburetors. Today's carbs are manufactured with tight tolerances to meet EPA emmission standards...just a drop of water or a spec of grass in the carb can cause issues. Cleaning the carb with compressed air from an air compressor and spray type carb cleaner usually helps in this types of problem.
Also check the start pull cord.Check if the oil level is low.Also check if any blockage in air filter. Clean every thing and re-check. This unit does not have an oil plug on the bottom of the engine, so it needs to be tipped on its side. This is best done when the fuel tank is nearly empty, so gas does not leak out when it is tipped over.The correct oil for your toro is SAE-30W.The air filter should be changed every year. The replacement filter is a Tecumseh 36905, which I found at both Lowes and Home Depot. Also to get required parts and manuals and parts diagram of your toro you can get it from the link below.Click the link. https://homeownersolutions.toro.com/portal/server.pt/community/solutions_home/222).
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Posted on Jul 11, 2010
How to fix stuck pull cord of a 22 inch Toro Recycler lawn mower
Is the engine seized?. Try turning the blade and if it won't turn then you have a seized engine. If that is ok your recoil has a stuck part possibly something has broken off inside. If it's an older model try shooting WD40 inside the recoil as it could be rusty.
Jul 25, 2014 | Toro Garden
How do I open the case around the pull cord on a Torro 22" recycler lawn mower?
It's been a while since I pulled one of those engines apart - the LV195 engines came in 2 versions. One has a detachable recoil starter that is held on by 2 screws, the other is an integral part of the cowling. Either way, the repair procedure is the same - remove the starter, or entire cowling as appropriate (may need to remove some plastic and the tank first), remove label on top, SUPPORT THE ASSEMBLY ON A DEEP WELL SOCKET or similar and drift out the central roll-pin into the centre of the socket drive the pin from outside to inside. If you don't support it, it WILL bend and make it useless. Make a note of the order of the washers and springs etc, then fit a repair kit.
May 03, 2014 | Toro Recycler 22" 149cc Personal Pace Lawn...
Toro 22" recycler lawn mower, Briggs & Stratton engine. Engine low on oil, would not start after a few pulls. 20 oz oil added, mower started after a few pulls. Finishing the lawn when a white puff of...
Hi michael, You have most certainly put in too much oil. Try draining a bit off and then clean the spark plug with some paper towel. Leave the mower level for a few hours and then try it again.
Sep 22, 2013 | Toro Garden
Toro self propelled 22 inch recycler lawn mower not picking up grass
is there to much old grass built up under the mower?did you damages the blades
Apr 06, 2012 | Toro Power Lawn Mower
I have a Toro 22 in Recycler Lawn Mower Model No. 20331 I can't pull the starter cable, it seems locked. My boys were mowing the lawn earlier, some very high grass, and the mower stopped
Hi. It's not locked. The piston has siezed up maybe for lack of oil or sitting too long. It is time to retire it. If your son or daughter or grand kids has some mechanical in them. They can tare it apart and fix it. Good luck.
Jun 25, 2011 | Blount International Oregon Gator Mulcher...
How do you change the self propelled cable on Toro Model 20005 22 " recycler. Can't figure out how to remove the plastic black cover the cable goes under.
how do you change the self propelled cable on Toro Model 20005 22 " recycler. Can't figure out how to remove the plastic black cover the cable goes under
Aug 27, 2010 | Toro Lawn Mower With Toro Power Tools
I have a 22 in Recycler Lawn Mower. I haven't had it 1 year yet. It is supposed to be self propelled but that quit being self propelled today. thank you in advance donna
turn it over and check the drive belt. it's probably too loose or broken. don't ask me how to fix it, i'm here trying to find out why mine keeps dying.
May 19, 2010 | Toro Lawn Mower With Toro Power Tools
Need to replace pull string on lawn mower
how do i change the pulling string on my toro 22 recycler
Jun 13, 2009 | Toro Lawn Mower With Toro Power Tools
Mower will not start. Makes a loud fast clicking noise when the key is turned.
Loud ticking usually indicates near dead battery, take it out and charge it. If it still ticks you may need to replace it as they are only good for a few years.
May 10, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
789 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
