Question about Friedrich QuietMaster Electronic SS12J30D Air Conditioner
My AC unit is blowing hot air, what can I do to fix that? what type of refrigerant does this unit need?
  • Friedrich Master
  • 43,501 Answers
There can be a couple of things that could be happening...
The first and easiest thing is to check the air filter. Make sure that it is clean... clean it or replace it. Next check the air vents to make sure that they are open and giving you good air flow...
Also check to make sure that you are not icing up on the indoor coil... ice will tell you that you are low on refrigerant. You also could be low and not be icing over, but you would need to have gauges on the unit to check that.
Finally check and clean the outdoor coil...this also can give you problems if the heat is not being removed from the outdoor unit efficiently...
You may also have a unit that is sized in such a way that it hits the balance point at about 85...that means that your heat gain is equal to the capacity of the unit...I often try to size them for about that here in Northern PA. because wqhen seldom get hotter then that and the unit then is much more effective at removeing humidity at lower temperatures...
You can also check out the tips that I have wrote about Air conditioningmy AC unit is blowing hot air, what can I do to - 2_bing.gif trouble shooting and maintenance...
Here is one about cleaning the condenser coil and at the bottom of that one are links to others..
Condenser Coil Cleaning Condenser Coil Cleaner
http://www.fixya.com/support/r3850183-condenser_coil_cleaning_condenser_coil
heatman101
Posted on Jul 12, 2010
Why is it that when i turn on my ac my car idol drops low and the car turns off
If you gassed the ac system your self then it mat be overfull and that is why it is not working and if you did no check for leaks (why else would need gas) then it may be all pumped out . The AC compressor takes a lot of power to drive and all cars loose around 300rpm's when it cuts in so if you have an idle too low then it will drop below needed idle rpm's . Most cars have a compensating unit the raises the idle rpm when the ac is working so check out your system for a faulty unit there.
May 02, 2014 | 2002 Mercury Sable
I want all cold air it blows hot out the back why
the back should blow out hot and at the front it blows out hot
the hot is the air in your room
Jul 22, 2011 | Heating & Cooling
My 2002 Expedition air conditioner will sometimes blow hot air and others cold air
I would check the following possibilities:
1. Is compressor clutch working? - You need to do this when the ac is blowing hot air only - locate compressor drive pulley on engine - rubber belt wraps around it. Start engine and set to max ac. When the ac is blowing hot air, look at the center of the compressor drive pulley using a good flash light - watch it for a while, it should be spinning with the pulley - this means the compressor is engaged. If not, the compressor is not engaged. If your ac is blowing hot air, then the compressor should be engaged and running (trying to cool). If it is not engaged, then your compressor clutch is probably going out. Could be low voltage to clutch, but more likely the clutch is worn out and only working some of the time. Note: if working normally, the compressor clutch will engage and disengage in cycles- but the air should always be cold. If clutch is bad, compressor would need to be replaced (sold as one unit). This is tricky to diagnose and could take some time - you need to do it when ac is blowing hot air but set to max cooling.
2. Low on refrigerant or refrigerant has moisture in it? If your ac blows cold initially after being off for a while, then heats up, and continues to regularly cycle back and forth between hot and cool air, then the system may be low on refrigerant or the refrigerant may have moisture in it that is freezing and restricting refrigerant flow. An a/c shop can check refrigerant level and even replace refrigerant if moisture is suspected.
Could be other issues, but I would start with these.
Good luck
May 07, 2010 | 1999 Ford Expedition
When i turn ac on air blows hot. the fan is
sounds to me u need to have it recharrged
Oct 03, 2009 | 2004 Infiniti G35 Sport Coupe
Ac sytem blows strong air but its warm
If the compressor and fan work in the outside unit, and the fan inside (air handler) works, probably the system is low in refrigerant which means there's a leak that has to be fixed and then recharge the unit.
Sep 04, 2009 | Carrier 38CKC030 Air Conditioner
Kia spectra 2004 AC no power blows hot air
In almost every case, it is most likely low on freon. Most all systems use some type of pressure switch to prevent the unit from freezing up via a low pressure switch. It also acts as a "Loss of Charge" safety. I would think there is a leak. Most of the time it is in the condenser, evap, or compressor. Usually not real cheap to fix but you got to check it out to be sure.
Aug 06, 2009 | Heating & Cooling
2004 MALIBU MAXX A/C BLOWS HOT AIR
Could be several things. The fuse relay to the AC compressor could be bad. The system may need to be recharged due to lack of refrigerant the compressor will not work unless it has enough.
Jul 19, 2009 | 2000 Dodge Neon
A/c blows hot
Your car is low on refrigerant.
  1. Your system requires R-134A refrigerant which is available at most auto parts stores.
  2. You will also need a hose to connect the refrigerant to the AC system.
  3. You will need to locate the low side AC fitting (looks like a nipple)
  4. With the car running and the AC turned on high, attach the hose to the AC fitting,
  5. attach a can of refrigerant to the other end of the hose.
  6. Turn the screw on the hose to puncture the top of the refrigerant.
  7. Move the can back and forth until the refrigerant is empty.
  8. Detach the hose from the AC system.
Check to see if frost forms on the AC lines under the hood and cool air blowing from the vents inside. If the air isn't cold enough, add another can of refrigerant.
CAUTION: Do not overfill the system. If the system doesn't "**** in" the refrigerant, the compressor needs resetting (disconnect battery 5 min in GM cars and trucks)
I hope this solves your AC issue. All the best!
Greg
May 14, 2009 | 1997 Buick Park Avenue
AC Wall unit is blowing hot air
Bit difficult? Brand/type of this AC?
Can't see what controls what from here.
Your fan works, but I can't see your compressor working to compress the freon (or what ever is in there).
So give some more details about electrical connection.
2 / 3 phase /grounded?
Suppose the unit is disconnected now and thawed up?
Apr 17, 2009 | Heating & Cooling
Friedrich QuietMaster Electronic SS12J30D Air Conditioner Logo
138 people viewed this question
Top Friedrich Heating & Cooling Experts
Bill Long
Michael Vincent Cruz
Tim Whalen
Are you a Friedrich Heating and Cooling Expert? Answer questions, earn points and help others
