Question about HP G60-235DX Notebook
My HP G60-235DX notebook worked fine.I tried to turn it on the next day and it won't power up.The indicator light turns on but stays red and the screen stay black and windows won't start.Sometimes If I have it opened a certain way it will start but then it shuts down for no reason.What can I do?
  • 81 Answers
Try removing the battery and the power cable for about 30-40 min and then plug it back in. If that doesn't work try contacting HP. I had a similar issue with a Toshiba replaced the HDD and after that it was fine. So I would say try those, if all else fails post on www.techsupportforum.com.
Posted on Jul 11, 2010
Funai TV will not stay on. It turns on for 1 second and then turns off. Red standby light blinks on and of, what can I do?
Either the power driver board is faulty, or it has a humidity sensor in it, which turns it off. Move it to a very dry place for a few days, then try it again and it might work.
Jan 19, 2015 | Funai Televison & Video
I HAVE A TOSHIBA SATALITE A135-S4427 TURNED IT OFF ONE NIGHT WORKING FINE, THE NEXT DAY IT WONT TURN ON. I HAVE POWER THRU THE CORD AT ABOUT 18+ VOLTS BUT NO INDICATOR LIGHTS OR POWER TO COMPUTER. HELP?
Try removing the battery and power supply, hold the power button for about 10 seconds then just plug the power supply back in (not the battery) and see if it turns on.
Holding the power button with no power supply can discharge any stored power in capacitors.
Oct 24, 2013 | Toshiba Satellite A135-S4427 Notebook
Lenovo Ideapad Y510 won't turn on or off
try removing the battery and removing the adaptor press and hold down the power button for 5-10 seconds then let got this will power drain your system board noy turn the system on using the battery only without any adaptors to charge or power the system, try turning the system on if the system turnes on leave it turned on for a couple of hours then conenct your sysem adaptor monitor if the battery light and the battery indicator on the lower right of the screen in windows woll indicate that the system is chargin if it is then I believe everything should be fine the blue indicator is for your system if it is blue then your system is turned on and has power if it turned orange and blnking then the battery will be more likely be almost out of juice or may need charging.
Jun 23, 2010 | Lenovo IdeaPad Y510 Notebook
I have an Acer Aspire 5100 and on the front is an indicator light next to a light bulb icon and it never turns off, how can I turn it off?
hi-I have 2 of these 5100 notebooks-indicator lights are as follows -left is bluetooth next one is wireless lan, next one is power on,and the last one is battery. only way I know is to unplug it when not in usand the light will go off. if plugged in the light will stay on showing charging(orange) and charged (green). me i just put somthing in front of the light to block it from lighting my room at night.yes, they should have made it turn off at full charge, but they did not. good luck with that-hope this was helpful. have a great day!
Jan 27, 2010 | Acer Aspire 5100 Notebook
Hp nc4200 won`t start
There could be a problem with the battery. A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective & needs to be replaced.
If this did not work, try also disassembling the laptop & make sure that all main components are seated properly. Also make sure that all ribbon cables interconnecting the various components of the laptop are tightly connected.
Dec 28, 2009 | HP Compaq nc4200 Notebook
Charging indicator stays red
Hmmm...is the USB cable plugged in to a powered PC? Could be cable or battery issue. Red light means that the battery is very low on juice. Return it to where you got it from if you can't solve it on your own.
you want a repair service
Oct 16, 2008 | HP iPAQ hw6965 Smartphone
Philips flattv wont turn on
I had the same sympton on my tv...it worked fine one day and the next day it would flash a green light a few times you would see the screen power on, but still be dark then the power light would go red. I couldn't do anything on the tv no menus or sound. It turned out to be a bad power supply, a new power supply will run around $200-300 - in my opinion it wasn't worth fixing. My neighbor was able to fix my tv - he repairs electronics - ended up cost me $100.00 - its been running for 7 months now no problems so far...I can have him fix this for you if you are in the area - shipping makes this to expensive..he is located in south jersey...or you can try a tv repair shop ( i called for this but they wanted between $75-100 to just look at the unit + repair cost - i would of been back to the 200-300 range) let me know if you need help...John
netplus@comcast.net
Oct 08, 2008 | Televison & Video
Computer will not turn on
This could indicate a bad battery, or bad memory chip. Try starting without the battery. If this doesn't work, then try takeing one or the other memory chips out. If the problem persists, then it may lie within the power management system on the motherboard.
Jun 26, 2008 | Compaq Presario M2000 Notebook
Amplifier problems!!!
it sounds like your running your ohms to low, check to see what the amp can power and then read up online about ohms and your subs and how they should be wired
Oct 12, 2007 | Car Audio & Video
HP G60-235DX Notebook Logo
375 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
