Question about Garden
Stalls when blades are engaged - Garden
  • 6,993 Answers
Most likely the problem is in the carburetor. There should be an adjustment on the carburetor that might fix the problem. Try turning the high speed needle out 1/8 of a turn. Also Clean/replace spark plug and air filter.
Something else to check: Some riding mowers have a sensor switch that will not allow the blades to engage unless the clutch is depressed. The switch may be faulty.
Newer mowers come with a safety interlock system that prevents mower engagement when no operator is on the seat or when the parking brake is engaged. Check your seat switch by jumping across the terminals, if the blades start then the seat switch is bad.
Good Luck.
Posted on Jul 11, 2010
Have a craftsman EZ3 917.272121 mower engine e stalls when blade switch is pulled
If you are sitting on the tractor seat and the engine stalls when engaging the PTO mover blades I would check the switch under the seat.
This seat has a saftey switch to assure that the operator is in a safe location before engaging the the blades. Also if the blades are engaged and the operator leaves the seat the blades will stop. If a young rider with insufficient weight the blades will not engage.
26147998-f1dbbl4o5m3nghfc10hihvyr-4-0.jpg Hope this helps?
Mar 31, 2016 | Craftsman Garden
Goes dead when disengaging brak
Lawn Tractor stalls after engaging blades or releasing brake ...
www.shopyourway.com > Manage My Life > Questions
Scenario 2: Engine started, as above in scenario 1 and manaul brake lever is engaged. Again ... Lawn Tractor stalls after engaging blades or releasing brake .... I am goingto replace that anyway but it almost seems my problem is electrica
Sep 14, 2015 | Garden
Ariens lawn edger bogs down and stall when the blade is engaged
sounds like you need to return it and get replaced should be warrantied sounds like the bearings are seizing up on the blade shaft .
Jul 26, 2015 | Ariens Wheeled Edger - 986103
Honda HRA-214 stalls when engaging blade
yes it is the bearing going out of the blade drive no the cables just activate the drive probably nothing wrong with cables
Jul 04, 2013 | Honda Garden
Stalls When engaging the blade clutch
Check that the blade brake is disengaging. Slip belt off blade spindles and check that they spin freely. Check underside of deck for clogged grass, ropes, wire, etc.
May 07, 2012 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Craftsman 18hp riding mower runs & stalls when engage the blades
motor off= deck engaed turn blade should turn motor and belt fairly easy, NO remove the belt from the motor pulley with deck engaged blades should turn freely.
most decks have breaks on the pullies so if the deck is not engaged the break will be on
May 27, 2017 | Craftsman Garden
Mower stalls when engaging blades
check the safety switch for engager could be bad,, hope this help,, good luck
Aug 08, 2009 | Garden
Stalls when engaging cutter blades
The shaft that holds the blade could be rapped with something or needs a new bearing. Check again next to the deck, try a little WD 40 on the bearing.
Jul 09, 2009 | Garden
Stalls when engage blades in forward, but cuts fine in reverse
Did you try to disengage the safety feature that should shut the tractor off when the blades are engaged and the tractor is placed in reverse? I believe that it is located under the shift leaver
May 14, 2009 | Mtd Garden
Garden Logo
42 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
