Question about Maytag SAV365ZAWW 3.3 cu.ft.
WHEN MACHINE IS SPINNING IT SOUNDS LIKE A JET PLANE
Buy a new washer - NOT A MAYTAG - Parts are $80-120 and it takes special tools and a lot of time.
Ours ran for greater than the average time - about 7 years and that was God's blessing! Time for a new unit - NOT A MAYTAG.
Posted on Mar 20, 2011
SOUNDS LIKE JET PLANE WHEN IT GETS BY RINSE AN SPIN TIME
I assume you mean it sounds like a jet plane when it spins, if so, I suspect a bad tub bearing. Depending on age of the machine, probably too expensive to repair.
Mar 07, 2015 | Maytag Neptune Washing Machines
Loud noise during spin cycle now they are stacked
a loud noise comes when you forget to remove shipping bolts after installation or if the shocks are worn out it makes noise thirdly the bearings might be worn out if the washer is more than 6years old
Jan 21, 2013 | LG Cherry Red Steamwasher Wm2487h Front...
Jet Plane noise in spin cycle
The bearing in the outer tub assembly is going out and you will need to replace it. Here is the part if you want to order it but you might want to look into buying another machine.
Nov 20, 2012 | Washing Machines
Sounds like a jet plane taking off when it spins, I think I got in 2003 Also the top of the agitator wont stay on
Has it always sounded like a jet plane? If it has. Then who installed your new washing machine didn't disengaged the two counter weight inside the washing machine. There two concert block or plastic block inside the washing machine. Each block is attached to one end of counter blanching bar which has some spring attached to them. During manufacturing these weights are tied down for shipment. During installation the ties are removed then the washing machine can be leveled.
Counter weights are used to off set the uneven load in the tub. That way the washing will not start walking in the house. Side load washing machine use a plastic donut the fits around the drum and it fill with fluid for counter weight.
Now the cap of the agitator, it broken. The locking tabs are broke off. needs to replace. I hope you said the top of the agitator and not the agitator is coming out. If it is, you got major problems. stewbison
Aug 20, 2011 | Amana Washing Machines
Washing machine sounds like a jet plane, when spinning
I would suspect that the main drum bearings have failed.
From the front of the washer, spin the drum by hand, and if it feels rough or is noisy, then the bearings have failed.
There should be little or no noise when you spin the drum.
Jan 31, 2011 | Hotpoint Aquarius WF000 Front Load Washer
Car engine sounds like a jet plane
sounds like a jet plane is the exhaust is probably collapsed. Check the exhaust system and the cat converter.
REMEMBER TO RATE THIS ANSWER
THANK YOU
Dec 26, 2010 | 1998 Chevrolet Malibu
Noisy during spin cycle, sounds like a jet plane at full spin.
the drum bearings have gone, expensive repair, this is caused by over loading the machine
Feb 02, 2010 | Maytag Neptune MAH5500B Front Load Washer
How does a person replace the bearings in the machine
this should be a problem for a technician I dont think without training you would want to try.
May 30, 2009 | Washing Machines
Washing Machines Logo
124 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
