Question about Arris SURFboard SB5120 Modem
Would like to know if this Model is a Full Duplex Modem ?? Would like to hook to computers up, please help
Can't get Oki to duplex
some of the oki's & hp's wont duplex on the network without a print server, know it's a shot in the dark but is it connected to a print server or directly to the network.does it give any errors or just fail duplex and comes out single sided?
Jul 28, 2009 | Office Equipment & Supplies
Having problems with my Belkin N Wireless Router F5D8236-4. It's not picking up my Phone Power VOIP modem thing as far as connecting to the net. yet I can get the net if I hook directly to the computer. I...
Is the Belkin capable of providing power to the port? Are there any specific suggested port settings such as 100 full duplex? Auto negotiation can be rough on voice devices.
Jul 06, 2009 | Computers & Internet
OTHER PARTY CANT LISTEN MY VOICE WHEN I AM USING MICROPHONE
mohiddinpate, can you check the specifications of the modem you are using is Full-duplex? This is required for 2-way communicatrions. And if it is Full-duplex, check that this is enabled in it's settings.
May 20, 2009 | HP Computers & Internet
I cant here any audio sound on my computer
There are a few simple things to check first:
• Make sure your computer has a sound card.
You must be logged on as an administrator to perform these steps.
1. Open Device Manager by clicking the Start button getopencontent.aspx?assetid=4f6cbd09-148c-4dd8-b1f2-48f232a2fd33&documentset=en-us&renderkey=xml, clicking Control Panel, clicking System and Maintenance, and then clicking Device Manager.‌ getopencontent.aspx?assetid=18abb370-ac1e-4b6b-b663-e028a75bf05b&documentset=en-us&renderkey=xml If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
2. Expand the Sound, video and game controllers category. If a sound card is listed, you have one installed. If no sound card is listed, You will need to install one. See Install or remove a sound card.
NoteIf you think you have a sound card installed but you don’t see it under the Sound, video and game controllers category, expand the Other devices category and check any devices listed there. 3. If there is a yellow question mark next to the name of the sound card, there might be a problem. Right-click the name of the sound card, and then click Properties.
4. Click the General tab, and then look in the Device status box to identify problems with the sound card.
May 06, 2009 | Computers & Internet
Problems
Absolutely. The router will have an uplink port. It will indicate on the back. Hook the modem from sat to the uplink and the other 2 computers to the other ports. make sure the computers are on DHCP (they should be defaulted to it) and they should auto connect
Jan 26, 2009 | Linksys 5 x 10/100Base-TX - Ethernet...
I have a modem im hooking up 4 pcs to. Where does the phonelineGO
When I hook up my Linksys the way it should be hooked up I loose my internet connection on my computer. Help!
Dec 31, 2008 | Linksys Cable Modem
Network is SLOW
I can assist with the full and half duplex question...but I'll need a specific HP model number for the Procurve in order to give you correct advice about it.
If the Procurve is not configurable, or has never been configured, then it is using autonegotiation to determine speed and duplex. Each of your computers should also be set to auto for speed and duplex.
The general rule of thumb is to make sure that speed and duplex for both ports on a link are set the same. For example, if the port at one end of a cable is set manually, then the port at the other end must also be set manually...to the same speed and duplex values. If one port is set to auto, then the port at the other end of the cable must also be set to auto.
Jan 15, 2008 | HP ProCurve 24x10/100 Mbps Networking Hub
Not Compatible with Xbox 360 controller
how could you have hooked it up to a 360 controller? this headset is USB.
Dec 21, 2007 | Logitech 250 Headset
Arris SURFboard SB5120 Modem Logo
48 people viewed this question
Top Arris Computers & Internet Experts
Jerry
Jerry
jimmy Leo
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
