Question about RCA P52926 52" Rear Projection Television
RCA P56926 Would not turn off
I have a RCA P56926 would not turn off until I plugged it, now it will not turn on. It does not make no noise. The chassis # is PTK 195RIP if needed
    Champion:
  • 230 Answers
This tv make a lot loose connections. If you re solder and nothing change, check fly back area's is OK?... Look around convergence board for liquid coolant ( some times CTR liquid coolant projection splitter , becarfull, Liquid is danger!!) Wash yous hands and clean chassis with acetone.
Posted on May 14, 2008
P52926 52 in. Rear Projection Television: Hello. I am trying to find out what tube I need...
look on back of tv for make and model. get online and go tothe manuel of that brand look up parts and it should tell you
May 03, 2010 | Televison & Video
Crescent shaped image on screen - RCA 56" P56926
Hi
Thanks for using FixYa. From what you have described it seems that you have to replace the convergence IC and also check the power resistor, if values are not exact you have to replace them. These ICs are located behind the black heat sink; you can see once you open the back off the TV. Also, the convergence board should be checked for cracked solder joints and please make sure to check the resistors as if they are shot the ICs might blow again. All this is only recommended if you have electrical expertise and know how to solder/re-solder components, if not then you should get this done by a professional. The typical cost to get this fixed by a pro is around $250-$300. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Apr 07, 2010 | RCA P52926 52" Rear Projection Television
Rca p56926 screen is concave and cant adjust convergence in menu
Convergence can only be repaired by going into the unit itself....You MUST know how to do this or risk a lot more problems.....seek qualified assistance!
Aug 29, 2009 | RCA P52926 52" Rear Projection Television
How to remove screen on projection screen tv 56"rca model#p56926
Remove the speaker cover on the front, it just pulls off. Pry each side a little at a time. There are 4 screws that hold the screen on. Remove them and the screen just lifts off. There are wires attached to the controls so, keep that in mind when lifting the screen.
Aug 10, 2009 | RCA P52926 52" Rear Projection Television
I need a lamp number for my RCA P56926 model TV. Can anyone help me??
bluestar international componets 1 800-522-2701 1-631-385-8171 or web site bulb 115.00
Jul 01, 2009 | RCA P52926 52" Rear Projection Television
RCA P56926 - Picture Rolling- no problem when playing Playstation
i had this same problem with my big screen, it may be your connections.  make sure they are all tight and make sure your cable wire isnt defective.  you may also need a signal ampifier, like if you have to many tvs plugged into cable throughout your house.  in my experience, 4 is about all you can have without messing with signal strength
Oct 18, 2008 | RCA P52926 52" Rear Projection Television
RCA P56926 ADJUSTING PROJECTION TUBES
on my rca projection, it let me access all of those functions under the menu button, right on the front of the tv
Oct 07, 2008 | RCA P52926 52" Rear Projection Television
RCA p56926 replacement screen
you cant, the screens for that model are no longer available and even a used scree assembly will be over 200. if you could find a new one they would be about 4 to 500.00
May 25, 2008 | RCA P52926 52" Rear Projection Television
Rca p56926 convergence problem
kraze3,
Your set has a repair issue with the convergence circuit.
Adjustments in the service menu will not help.............I agree
with Guest comment.... circuit board repair or replacement is
what you both need.....................T.
Nov 23, 2007 | RCA P52926 52" Rear Projection Television
RCA P52926 52" Rear Projection Television Logo
71 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
