Question about Dynex DX-E401 Router
Dynex DX 402 Router
Have connected the router and it works fine, but every two or three gours the connection drops and I have to reset the router and modem to re-enable it.. Windows keeps trying to 'dial up' the broadband connection on both pcs that are connected to it.. Any help would be appreciated..
  • Jonathan Apr 19, 2008
    Have all the electronics in the house routed through phillips powerstrip/surge protectors, having lost a really good system to one back in phoenix, so that would not be the problem there.
    Both of the connected systems are running windows vista home premium, don't know if that helps, but just restored the system to a date about three weeks ago, just before we got online, and everything seems to be running smooth for some reason.. Perhaps it was a user error of some kind.
    Many thanks for the rapid response, friend.
  • 105 Answers
Check for power surge or any other related proplem. Electronic item strat malfunction, if it does not get proper current.
you connect the router power supply to UPS and check for happy ending.
Posted on Apr 19, 2008
Trying to acces dynex router for xbox live and need a " pass phrase " lost the manual how do i connect
The Manual:
http://dynexproducts.com/cms/documents/DX-E401%20User%20Guide.pdf
The default address of the router is 192.168.0.1. Type that address into a web browser on a computer connected to the network and it should bring up the login screen for the router. The default login for the router is Username: admin with a blank password. If you changed this, you will need to reset the router with the reset button and configure your entire network again to make changes.
May 20, 2011 | Dynex DX-E401 Router
How to connect a dynex (dx-e402)router to linksys (befsr41) router
Configure the dynex on another computer that is not connected to the linksys router.
Assuming that your linksys is currently setup as 192.168.1.1
Turn off DHCP on the dynex and setup the IP to 192.168.1.2 subnet mask 255.255.255.0 gateway 192.168.1.1
use a cross over cable and plug each ends to the LAN port on port routers.
you should now be able to ping 192.168.1.2 (dynex router) from your other computers on the linksys router network.
any computer that is connected to the dynex should be able to get a dhcp address from the linksys router.
Mar 01, 2011 | Dynex 4-Port Ethernet Broadband Router...
Bought a new computer and trying to install my 4-port wired router and when I go to http:192.168.0.1 it tells me to type in admin for username and leave the password blank but when I do it asks me to type...
The Dynex manual for this router says the default address of the the router is 192.168.1.1 and both the username and password should be admin. If you are connecting to 192.168.0.1, you might be reaching some other router connected to your network, or the Dynex settings have been changed. You can restore default factory setiings by resetting the router. Use a straightened-out paper clip to press the recessed RESET button on the rear panel. Hold it until the System LED flashes three times, then release the button. The router will reboot and factory default settings will be back.
Nov 28, 2010 | Dynex 4-Port Ethernet Broadband Router...
Dynex router won't communicate with the modem.
If you connect the modem to the computer, does it go online ?
If your computer is online through the modem, then the modem is working properly.
Check the connections between the modem and the router.
Reset the router for 30 seconds , unplug the power to the router and plug it back in. Wait for 1 minute and set up the router again manually.
Click Here for more info
Nov 12, 2009 | Dynex DX-E401 Router
Lose internet connection
Try Unplugging Your Router And Modem For 1 Minute. Then Re Plugging The Power Cords In.
Jun 14, 2009 | Dynex DX-E401 Router
Can  Dynex 4 Port Router DX-E402 be used to connect internet on a notebook without using cable to notebook?? i.e. Can it be used like a wireless g router??
Unfortunately, the DX-E402 is not a wireless router, so it can not transmit its signal without a physical cable connecting the router to your computer. If you want a wireless router that can also connect to your ISP, check out the Dynex Enhanced Wireless G Router:
http://www.dynexsupport.com/product/?pid=DX-WEGRTR
Nov 28, 2008 | Dynex 4-Port Ethernet Broadband Router...
Reset and setup help on dynex dx-wgrtr wrireless g router
Hi guys, I have the same router and I had the same issue. I just figured out how to fix it. All you have to do is access the mac ip address and it will give you all of the information that you need. It will show you your old password (which you can reset if you want), also it lets you access all of the settings on the Dynex router. The mac (ip) address for this router is http://192.168.2.1/. I recomend righting this (along with your password) on the router itself with a sharpy (marker) so that you can find it quickly in the future if you have the same problem. Godd luck, I hope this helps you.
Nov 16, 2008 | Dynex DX-E401 Router
No connection
Try resetting the router to factory , should have a button on the back to do this .
you will have to log back into it with the default factory password
see their site for more info.
Jan 26, 2008 | Dynex DX-E401 Router
Computers & Internet Logo
246 people viewed this question
Top Dynex Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Dynex Computer and Internet Expert? Answer questions, earn points and help others
