SOURCE: eye 312 problem
Normal
0
Web Camera’s have to be
setup on the program they are to be used with.
Just installing the camera on your computer does not set it up to
broadcast on messengers or Skype.
Each program has Options that have to be setup in order for
the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype set it up as follows:
The camera and audio should function properly. Your friends and Family will now see and
talk to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger set
it up as follows:
When done both the Audio and Video will function properly so
you can chat and see family or friends you are connected to.
Hope this helps. Bud
SOURCE: i dont haveany installer for my web cam genius eye
This is a hardware driver issue.
If your using a MS Windows based o/s on your computer.
Try this: open your internet browser so as to connect on line,then connect the web cam per the instructions and turn it on. This should automatically open the "Found new hardware" wizard, where you can/should chose to search the web for the appropriate software.
If that doesn't work try downloading a free program called "Driver Max" and see if that helps.
These suggestions might only get you the drivers needed, and not all the "bells and whistles" from the original CD, but at least it will work.
SOURCE: can't use cam genius eye 312, how to download
Click this link for your driver just scroll down and search for your your drive in that link
