Question about Brother MFC 210C All-In-One InkJet Printer
Printer unable to clean. Have follwed
Mr Brother MFC-210C printer is unable to self clean. I have followed the instructions in the user guide [althought they don't refer specifically to the problem I am experiencing] but machine still unable to clean and therefore won't work. What am I missing?
Try this...
Go into maintenace mode by pressing ( Menu * 2 8 6 4 ) within 2 seconds. You should be in the maintenance mode now. Press 80 and scroll down to purge count, if the figure is more than 6000, press 2 7 8 3 to reset the purge count. The printer will restart and everything normal. Good Luck
Posted on Aug 04, 2010
  • 1 more comment
  • AnnieM Nov 20, 2011
    Unbelievable! It worked perfectly. You just saved me at least $100 for service or a new printer. You rock!!!
  • M Dougherty Apr 07, 2012
    Again-- you saved my life. It worked on the Brother mfc 210. The only caveat I would add is that you have to press Menu then * 2864. Then 80 then you scroll thru a long and scary list til to you get to purge count and then as instructed above 2783. Then you have to unplug the machine and re-plug it to restart and you should be perfect now.
  • Nora Gutierrez Sep 01, 2013
    I have and a brother MFC-210C with that problem I try to follow your solution, but when I press menu the machine have the nunmber 1 and do not let me continue what I did wrong?
  • Brother Master
  • 378 Answers
In the guide, for the error you quote Brothers guidance is to check for a stuck piece paper, however it also states that if the print head is hard over to one side (righthand side if memory serves me correct), then to contact Brother. If you do so, Brother will tell you it needs to be serviced by a Brother agent, which will likely cost you more than a new one !
If it isnt a stuck piece of paper, the problem is due to the fact that Brother machines excessively self-clean. Each time they self-clean a small amount of ink is dumped in to a holding tank/sponge. When a predefined number of self-clean operations have been performed, the machine refuses to print and gives the error message you have stated. Brother state that the tank/sponge must be replaced before the counter is reset, again by a Brother agent.
However, there is a way of reseting the self-clean counter yourself - if you Google your model number and the error code somewhere in the results you'll find how to do it. The only risk of doing this without changing the tank/sponge is that it will eventually overflow and leak out the bottom, but I did my Brother all in one some time ago and have had no problems yet.
Posted on Jul 12, 2010
Testimonial: "Thanks for that help - much appreciated."
Yes! Fantastic...faffed all morning till I found your solution, just one thing I had to refer elsewhere to understand I needed to press 'stop/exit' at the end and then 99 to exit maintenance mode. Fingers crossed am about to print something.......holding my breath but the machine is starting....and it worked! Thanks so much
Posted on Aug 14, 2012
  • 50 Answers
1> Go to < http://www.brother-usa.com/SiteSearch.aspx?sk=MFC-210c >..........downlaod the latest user manual and service the product manually.
2 Suggested Answers
  • 121 Answers
SOURCE: Mr Brother MFC-210C printer is unable to self
might need service
Posted on Sep 23, 2010
My printer say "Unable to clean See trouble
you can download the user guide in english language from this link: http://welcome.solutions.brother.com/BSC/Public/files/dlf/doc000222/Mini2LowBase_UkEngUsr.pdf for the error enable to claen see page 11-4
Dec 13, 2010 | Brother MFC 210C All-In-One InkJet Printer
Brother mfc-210c, error message "Unable
It seems simple enough, but this is one of the most effective ways of fixing printer cartridge error. Mostly, printer cartridge error occurs when the printer head is unable to identify the cartridge properly. And the basic reason behind this is that the cartridge is improperly attached.
To reattach the cartridge check the following steps :
turn on the lid of the printer and then remove the cartridge from the printer head.
Check the cartridge to make sure that there are no scratches or other damaged parts that can contribute to a printer cartridge error report.
Take note that the cartridge should not be left open for more than 30 minutes; otherwise the ink will start to dry up and the cartridge will get clogged.
Nov 15, 2010 | Brother Office Equipment & Supplies
UNABLE TO PRINT BROTHER MFC 210C
Go to this link and find Page 11-4 in the section on Troubleshooting:
http://welcome.solutions.brother.com/BSC/public/files/dlf/doc000222/MFC-210C_UsaEngUsr_B.pdf
Let me know if this has helped you to solve the problem. Binary Bob
Dec 14, 2008 | Brother MFC 210C All-In-One InkJet Printer
[HELP] MY BROTHER MF-210C "UNABLE TO INIT"
Dear Guru,
I have a same problem" UNABLE TO INIT " but my printer DCP 110.
Please can help me.Thanks
Sep 19, 2008 | Brother MFC 210C All-In-One InkJet Printer
Brother mfc-210c
You can download the manual from this link: http://welcome.solutions.brother.com/BSC/public/files/dlf/doc000222/MFC-210C_UsaEngUsr_B.pdf See page 11-4
Aug 05, 2007 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC 210C All-In-One InkJet Printer Logo
1,860 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
