Question about IBM Lenovo ThinkPad T400 7417 Notebook
My lenovo T400 will not start up. The computer is plugged in.The battery and plug indicator lights are both green. When I push the on / off button the 2 indicator lights that are shaped like "houses" momentarily turn green and then turn off and nothing happens.
I got the same problem. Have u resolved the it? If so, please send a message to: tjsteen@broadpark.no
Posted on Oct 22, 2010
2 Suggested Answers
SamuRaiii
  • 130 Answers
SOURCE: My lenovo T400 will not start up. The computer is
if you battery is working and you have continuous A/C power. laptop has a hardware failure :(
Posted on Dec 18, 2010
G780 started up then shut down, no indicator lights when plugged in and will not sart up
Is the ac plug loose? If you wiggle it does the light come on and off? If that isn\'t the case and it powers up then goes right off sounds like an issue with your motherboard. If the unit is under warranty I would contact Lenovo. If the unit isn\'t under warranty you should try to blow it out with can air to get all the dust out of it to see if its a simple over heating issue. If the unit still doesn\'t post, sounds like you have a bad motherboard. Let me know if you have any other questions. Good place to find more info: http://support.lenovo.com/en_US/
Just need to type in your model number which can be found on the bottom of the laptop. should be MTM:XXXX-XXX
Apr 07, 2014 | IBM Lenovo ThinkPad T400 7417 Notebook
My lenovo T400 will not start up. The computer is plugged in.The battery and plug indicator lights are both green. When I push the on / off button the 2 indicator lights that are shaped like...
A less frequent situation that can happen in a laptop resulting in it not booting up is a damaged USB port. If the pins are touching the system will not start up. You can fix this problem by using a small flat blade screw driver, tweezers or micro needle nose pliers to carefully separate and reform the contacts so they do not touch.
This is not a permanent fix because the USB port will become unusable. To fully fix it would require you to replace the system board, which may or may not be covered under your warrenty.
Jun 01, 2013 | Lenovo ThinkPad T400 - Intel Centrino 2...
Battery light on nothing else
Has there been ANY damage? Have you tried another Cord/Charger with the EXACT same power specs? Has the AC jack been damaged due to pulling on the cord while plugged it? Unplug, remove battery, plug in, try to reboot. Has it been overheating? Fan, vents, heatsink clean?
May 06, 2013 | IBM Lenovo ThinkPad T400 Notebook
My laptop Lenovo T400 2765T7U is not operation, please help me !
Hi hieuhvat,
try to do this:
- remove the battery and charger (everything connected to the pc) then press the power button for 1 minute.. - plug back in the charger - after few secs try to turn it on
hope this helps :D
Apr 05, 2011 | Lenovo T400 Notebook
My Lenovo ThinkPad T61 has the indicator light that it is plugged in and that the battery is charging. The computer is also off. But every time I press the power button to turn it on the both lights go off...
Try to start the laptop without battery (remove the battery and plugh the adapter and switch on) if problem persists. Take it to the Service center , Becose your laptop motherboard may have some kinda SHORTS. best of luck
Jan 22, 2011 | IBM Lenovo ThinkPad T400 7417 Notebook
Battery appears charged, but computer will only run when plugged in
does your battery have one of those charge indicator panels on bottom?
also, it's possible that the connection from battery to the internals is shot..if that's the case, then you're looking at a major motherboard swap
May 15, 2008 | Lenovo 3000 V100 Notebook
IBM Lenovo ThinkPad T400 7417 Notebook Logo
2,154 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
