Question about Drills
Need a parts break down for a Wilton vsg model 2015 drill press
SOURCE: I have a Buffalo No. 15 floor model drill press
http://owwm.com/mfgIndex/pubdetail.aspx?id=1268
There are other manuals/parts lists for that press on the same site.
Good luck with the restoration!
Posted on Jun 27, 2009
Editor925
  • 285 Answers
SOURCE: ryobi spare parts
Unless you have the part in hand, which you could take to a specialized machinery or spring supplier to see if they could match it up, the only other way to get the correct part is to contact ryobi direct and talk to their parts department. They will be able to tell you the part number, and if available, send you one out direct from their warehouses.
Good Luck!
Posted on Sep 04, 2009
Testimonial: "Thank you very much for taking time to help! I have phoned Bunnings who I think are now the only suppliers of Ryobi in AU who are sending a spare. "
rowdy45176
  • 2176 Answers
SOURCE: Where do I get parts for a clarke drill press model bt1029?
the part number I found is BT1029-0038 for the quill spring and you can contact them at 1-800-227-9603 and see about ordering the part. If I have helped you would you please rate this response accordingly and thank you.
Posted on Oct 13, 2009
cojon
  • 7 Answers
SOURCE: need manual for craftsman drill press model 113.213853
To correct that 2 degree angle, there is often an allen screw at the bottom of the table swivel. Look where the nut to loosen the table is. Under it is an allen head screw. loosen the table swivel a bit and turn that in an eight of a turn at a time, re tighten then remeasure.
Posted on Jan 04, 2010
al_kupchella
  • 843 Answers
SOURCE: chuck falls out of drill press
There is a long tapered hole in the spindle of the press known as a Morse taper. It holds a 6 or 8 inch morse taper arbor which is attached to the drill chuck. This is made to be removed frequently by putting a wedge shaped key into a horizontal hole in the drill press and giving it a little tap. This is for making tool change that involve removing the chuck. If you had two such tools (say two different style chucks) they would each have their own dedicated morse taper arbor. But there is also a short tapered cyclinder on the chuck end of the morse taper arbor, with a matching hole in the back of th chuck. This is not intended to come apart frequently, but it can be disassembled. I'm not sure which one is coming apart, but regardless of which one it is, you might try this fix. Clean up any bumps at all on the oustide of the taper and inside the hole with sandpaper 200 - 300 grit. Use a dowel to hold the sandpaper in the hole, and use the motor to spin it. --- JUST BE CAREFUL that if it grabs that it doesn't grab you! Once it's all cleaned up, you can you the press aspect of the drill press to seat it in place. You also might have to replace the arbor. They don't cost all that much and are available from Grizzly.com. You specify the particular taper for BOTH ends of the arbor. The long end is a Morse 2,3 or 4, and the short end is specific to the drill chuck manufacturer, like JT-2 (Jacobs chuck taper 2). Write back if you need more help.
Posted on Jan 19, 2010
Wilton planer 99178
Walter Meier took over the parts division of Wilton, they are based in Europe. The website is not up to speed.
Dec 10, 2013 | Tools & Hardware - Others
Switch replacement
Go to e replacement parts and put your model number in and this will get you a parts break down.
Aug 10, 2013 | Milwaukee 1670 1 Drill 1/2 900 Hole Hawg
How do you change the chuck out?
if it has a slot in the spindle, there was a wedge that came with it, put the wedge into the slot and strike it with a hammer. depending on the taper fit you would need something like a ball joint seperator to knock the arbor from the chuck body. that is the best I can do without knowing the model and brand of the tool
Jan 25, 2011 | Wilton Drills
Dayton drill press, How do you remove the chuck? It has a Wilton 1/2 chuck 3z568 model
If the spindle has a slot in it above the chuck and you can see the top of the chuck arbor in that slot then you need to get a wedged piece of steel commonly called a drift , insert in the slot so it bears on the top of the arbor and the top of the slot and hit it with a hammer. This will knock the tapered arbor loose from the spindle and it should fall out. Hope this helps you.
Jan 26, 2010 | Drills
What voltage does a wilton model 2320 need to run on
went thru their whole site and found nothing listed with your model number. I suggest calling their technical hotline at 1-800-274-6846 M-F 7AM to 5PM CST for the information. wish I could have helped more.
Oct 10, 2009 | Wilton Drills
Need a chuck for this drill
what is the chuck mounting size or taper? It should be stamped in the chuck itself, let me know what you find and what area you are in city, state and zip and I will try and find one near you.
Oct 09, 2009 | Wilton 2223VS 20 Inch Variable Speed Drill...
Drills Logo
451 people viewed this question
Top Drills Experts
Marvin
Marvin
Craig Butler
Craig Butler
Are you a Drill Expert? Answer questions, earn points and help others
