Question about Frigidaire Microwave Ovens
I have Frigidaire FMV156DBC, it works fine as far as buttons & lights. But when you hit start the oven does not come on and start to cook. Can I fix this?
3 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: Cook time button problems
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
Please reply back here and let us know if the hard reset doesn't fix it.
It may have a bad door switch, and we can help you check into that. The first test for that is to try it while gently lifting up and then while gently pushing down on the door.
If you don't have your owner's manual, you can download it here:
http://www.mcappliance.com/products/otrdetail.asp?record=yes&modelname=MCO153UB
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Apr 12, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: frigidaire microwave model fmv152ksa Some of the
If you're saying that some digits or segments on the display do not light up, then I would first suspect grease or moisture on the control circuit board.
If it's just that some pads on the keypad will not respond, I would say your membrane keypad is failing.
I would first give it a "hard reset" by unplugging it for 2 minutes, then trying it again.
If it still fails, I would remove the control panel assembly (see the disassembly video here) and inspect the circuit board for green, gray, or white residue or grease.
The membrane keypad is not available as a separate part, but comes already installed on a new control panel frame, which is part number 5304464130 which you can order from the Pros here.
To replace that, you unplug the keypad (as per the photo below) and move your circuit board into your frame.
If you need more help, feel free to contact us directly.
Posted on Jan 29, 2011
FMV156DCA turns on, cook indicator lights but not cooking, timer counts down fine too
Hello epinvegas - Try reprogramming the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart unit. If it proves to be ineffective, then it sounds like the microwave has a faulty magnetron, wiring failure or control board. Contact a professional to assist with the repairs.
Feb 07, 2013 | Frigidaire FMV156DC Microwave Oven
Microwave seems to run, but won't heat.
We have a similar problem! It sounds like a problem with the microswitch inside the unit that the door is suppose to engage when closed. If not engaged properly, it will not cook. We had the switch replaced last March but it has started acting up again. We can press in on the door and/or lift it slightly and it will cook. Try putting time on the counter and hit start. It the word "cook" appears then try moving the door slightly and see if the turntable starts turning. If not, then you may have a more serious problem. Good luck!
Oct 09, 2009 | Frigidaire FMV156DC Microwave Oven
My Frigidaire microwave stopped working while cooking food.
All lights are operational. Model number is FMV156DBC.
Aug 29, 2009 | Frigidaire FMV156DC Microwave Oven
Microwave just stopped cooking!
The simplies is the fuse, which is located inside the unit, you need a screwdriver to open it
Aug 18, 2009 | Frigidaire FMV156DC Microwave Oven
How can u tell which switch is bad on the frigidare microwave
the door switches almost never break it sounds more like no power check the fuses on the pc bords
May 15, 2009 | Frigidaire FMV156DC Microwave Oven
Won't cook
check for any holes in the microwave, then also checkplugs/electrical. if ALL this doesn't work.. then you probably need a new microwave, or return the microwave to the shop, saying that it is a manufacturer fault.
Trust me, many microwaves have done this.
Apr 21, 2008 | Frigidaire PLMV168 Microwave Oven
Microwave Ovens Logo
87 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
