Question about John Deere Gx75 Rx75 Srx75 Sx75 130 9hp Starter
How do I adjust the brakes on my John Deere GX75?
rwvanlue
  • 486 Answers
SOURCE: John Deere Gx75, kawasaki 9hp motor- oil in carb!
A very common problem with the GX series with Kawasaki engines. The carburetor 'inlet needle' sticks open and fills the crankcase with fuel. When checking the oil, it can be difficult to see the gasoline and the level appears to be OK. Remove the dipstick and smell the oil, you may detect a gasoline smell. Also, drain the oil, and you may find much more fluid than you expect.
The solution on newer mowers was to install an 'in-line' shut-off valve to keep the fuel from syphoning into the carburetor. The inlet needle and seat in the carburetor is NOT replaceable, so a new carburetor is the ultimate solution, but VERY expensive. Installing and using an in-line shut-off valve is more affordable.
Also, this situation is common when machine is transported on a trailer, as the bouncing causes the needle/seat to leak. When transporting, always turn off the fuel supply to the carburetor.
Posted on Nov 08, 2009
nova2nv
  • 197 Answers
SOURCE: John Deere 4210 brakes are locked up
On both sides of trans housing just in front of axles is where brake shafts go into trans.To fix this you have to spray alot of lube between shaft and housing while trying to rotate shaft.This may take hours to free up and also check for the return springs to still be hooked up to lower roll bar frame.I have seen this alot in the 4000 series tractors.
Posted on Nov 14, 2009
  • 8404 Answers
SOURCE: John Deere f1145 front mower's engine stops
You must be in the seat to run the mower ... safety interlocks ... operator presence control is what it is called.
Posted on May 02, 2010
SOURCE: John Deere 185 deck height adjustment
having a problem with dive belt being hit by the mower deck 185 john deere suggestions !!
Posted on Jul 16, 2010
  • 3911 Answers
SOURCE: trying to change the blade belt on my john deere
Get in touch with your common sense. You have the deck out from under the mower and you have cleaned it. By chance is there a belt install guide on a sticker on the deck? This is a very common sticker. If you can get on fixya you can Google "John Deere deck belt install" with your model number. Failing all that, look at all the pulleys and the belt itself. The belt is flat on one side and v shaped on the other. Now look at all the pulleys, some have a groove and some are flat. The groove tells you the v of the belt goes in there and the flat tells you it is to take up slack or absorbs shock and the flat of the belt runs touches it. There is but one way it will go. One of the pulleys moves in an arc on a spring loaded swivel, that is your tensioner and will be the last one as you will move the tensioner to get it installed.
Posted on Aug 23, 2010
Is there a hand brake adjustment on a 855D
John Deere Gator XUV 4x4 855D adjusting handbrake ...
www.fixya.com/.../adjusting_handbrake/.../john_deere/gator_xuv_4x4_85...
John Deere Gator XUV 4x4 855D atvs adjusting handbrake unsolved issues. Ask your John Deere Gator XUV 4x4 855D questions. Get free help from atv ...
  1. John Deere Brake Adjustment‎
    Adfixya.com/John+Deere+Brake+Adjustment‎Troubleshooting Tips
  2. Free Manuals
  3. Instant Solutions
  4. Instant Answers
  5. John Deere Brake Adjustment‎
Jan 17, 2016 | John Deere 2012 Gator XUV 4x4 855D
John deere rx75 adjust belt tension
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
Apr 21, 2014 | John Deere Gx75 Rx75 Srx75 Sx75 130 9hp...
My john deere gx75 don't go into reverse and when i put forward gear i hear a noise like a tic tic tic...
It sounds like the spider gears inside transaxle is worn or broken causing noise and causing reverse not to work.
Oct 16, 2013 | John Deere Gx75 Rx75 Srx75 Sx75 130 9hp...
I have a John Deere rx75. The mower deck seems to be too low when I set it at the highest position. I have no idea how to do that or to level the deck. Please help. The lawn is cutting uneven and its...
find someone who can read and use the internet
go to www.google.com
search for john deere lawn tractors
go to the john deere website and click around under "support" until you find the manuals
download a manual for your model,l but they are all about the same
have the person who can read, read you the part in the manual about adjusting the deck height and how to level it.
there you go, bob's your uncle.
Sep 19, 2011 | John Deere Gx75 Rx75 Srx75 Sx75 130 9hp...
Model rx75transmission locked and will not relase with the clutch or the park brake
Look under the front of the drivers seat for a e-brake type lever that moves up and down and over to release transmission/diff lock .
May 23, 2011 | John Deere Gx75 Rx75 Srx75 Sx75 130 9hp...
John Deere Gx75 Rx75 Srx75 Sx75 130 9hp Starter Logo
770 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
