Question about Sport & Outdoor - Others
Scag 52" mower blades will not engage------fuses are good replaced engagement switch wiring seems to be fine any suggestions
GM Elec
  • 1000 Answers
SOURCE: Craftsman riding lawn mower...engine dies when blade is engaged
Push the clutch all the way down and try to start, does it crank over?
Let me know.
Regards,
Posted on May 10, 2009
  • 225 Answers
SOURCE: Scag SMT61A Mower with Kawasaki 27KA engine. 200
try taking stater fluid to carb and try keeping it running,needle seat might have some dirt in it or the carb itself needs to be cleaned.
Posted on Jun 07, 2009
wadembly
  • 513 Answers
SOURCE: Craftsman riding mower blades will not engage
maybe the safty switch under seat might be starting to go out if that switch doesn't work the blades wont come on at all for safety
Posted on Jun 28, 2009
  • 57 Answers
SOURCE: my mower quit mowing i pull switch and my blades
sound like your electric pto clutch has a problem check to make sure it is getting power first remember you will have to sit on the seat with the tractor off and the key on to test
Posted on Jun 29, 2009
SOURCE: LTX1000 42" 18HP Kohler - Blowing fuse after 2-4 min mowing.
i hav a 18hp ohv eng. back fires and gas is coming out of muffler.
Posted on Jul 18, 2009
Mower blades still engaging with broken pto clutch wires, why?
looking at the unit
could be the design of the clutch
fully engages when no power
http://www.scag.com/clutch.html
May 12, 2016 | Husqvarna Garden
Why will the cutter blades on scag SW36A not engage?
I am thinking this is a 12 volt PTO system that does not have a battery... this is where you need to check the wiring, especially the big white plug on the right side of the mower... It might also be a mechanical engagement system, if this is the case, suspect the belt popped of or is way out of adjustment
Sep 12, 2014 | Garden
When engaging mower engine stals
Safety switch to the lever that allows you to engage the blades is bad you can make a small jumper wires to by pass the switch. Unplug the connection .then insert two jumper wires into the plug .where your two white wires .insert jumper wire ends then two purple wires the same way with jumper wire.then start mower if it dies whenever you try to engage the blades switch 2 ends and replace a flat fuse.for it will have blown.you should be good after that.
Jun 22, 2014 | John Deere L100 Series
I have a ariens zoom 1540 mower it runs fine but the blades wont engage to mow. It worked when i put away after last mowing and 2 days later it doesnt. Ive checked the wires off pto switch and they seem...
You've checked the wiring to the PTO and it looks OK. Does the PTO engage when the switch is thrown? Do you have a multi meter , so you can trace the voltage to the switch, from the switch to the PTO. You also should check the safety switch (s) which will prevent the PTO from engaging if there is a faulty switch. And it could simply be a fuse that has blown.
Jun 20, 2014 | Garden
Blades will not engage but will remain running
It is most likely the switch. I had the same problem and that fixed. I found the switch on Amazon for less than $20. Stens 430-798 PTO Switch Replaces Scag 483957
Apr 05, 2013 | Scag SFZ52-26BS Freedom Z Zero Turn Rider
Pto, electric clutch
check the wires they rub on sharp edges
Mar 23, 2012 | Husqvarna Garden
Arien 34- Blades won't engage
This mower has an electric PTO on it. I had a Scag and the electric PTO clutch went out on it. Not the cheapest things to change but easy to do yourself with some basic tools. Also, before running out and getting a new one, check the wires to it and to the engage/disengage switch. You may have a bad connection.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/matthew_d24b835e574ef6ca
Oct 12, 2009 | Ariens 34 In. Zoom Series Riding Mower
sounds as though you are on the right track
but be sure to check the wiring directly from the electric clutch on the front of the motor back to the switch
a wire could be pinched in the frame and shorting out intermittingly
look around and find those wires and move them around and look for chaffing and tightness
and what you could also do is to unhook the clutch at the connection to it at the front of the motor and engage switch and ride around and see if fuse blows and if not you may have an electric clutch issue
Jun 07, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Sport & Outdoor - Others Logo
310 people viewed this question
Top Sport & Outdoor - Others Experts
Marvin
Marvin
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
