Question about GE AJCQ08ACB Air Conditioner
Ge model agh10 wall ac doesnot blow any air out vents
  • GE Master
  • 43,501 Answers
There can be a couple of things that could be happening...
The first and easiest thing is to check the air filter. Make sure that it is clean... clean it or replace it. Next check the air vents to make sure that they are open and giving you good air flow...
Also check to make sure that you are not icing up on the indoor coil... ice will tell you that you are low on refrigerant. You also could be low and not be icing over, but you would need to have gauges on the unit to check that.
Finally check and clean the outdoor coil...this also can give you problems if the heat is not being removed from the outdoor unit efficiently...
You may also have a unit that is sized in such a way that it hits the balance point at about 85...that means that your heat gain is equal to the capacity of the unit...I often try to size them for about that here in Northern PA. because wqhen seldom get hotter then that and the unit then is much more effective at removeing humidity at lower temperatures...
You can also check out the tips that I have wrote about Air conditioningge model agh10 wall ac doesnot blow any air out - 2_bing.gif trouble shooting and maintenance...
Here is one about cleaning the condenser coil and at the bottom of that one are links to others..
Condenser Coil Cleaning Condenser Coil Cleaner
http://www.fixya.com/support/r3850183-condenser_coil_cleaning_condenser_coil
heatman101
Posted on Jul 12, 2010
My GE Portable AC (Model: ape07ahm1) blows cold air and then after about 15 minutes seems to blow warm air. If I turn it off, let it sit, and start it up, it blows cold again.
First make sure all a/c vents are clear from obstructions like curtains,etc. Also check exterior vents/hose of any debri. If all venting is clear, does the room eventually cool down? If not than component diagnosis may be necessary.
Apr 09, 2018 | Miscellaneous
AC IS WORKING BUT NOT BLOWING HARD OUT OF VENTS AND CAN HERE FAN BLOWING HARD
Do you have an AC pollen and dust filter? If so it is likely plugged and no air flow is getting through. Another cause of this is that the AC condenser core inside the dash is plugged with dirt and leaf matter (cars without any filter) I really need the make, model, year to be more precise.
Aug 10, 2016 | AC Cars & Trucks
Ac trouble shooting for a 2002 olds intrigue I have a 02 olds intrigue 3.5 LTE engine My ac compressor constantly runs it has pressure in line but not blowing cold air and help would be appreciated
Where the A/C hoses go into the fire wall , are there hot , cold ? Low on refrigerant . Not blowing cold air , is there air blowing out of the center vents ?
Jul 21, 2016 | 2002 Oldsmobile Intrigue
My heater does not blow in floor in a dodgeram 1500
the heater vacuum motor and lines needs to be checked.Also get the blend door checked.
NO HEAT ON FLOOR VENTS
As per your problem mentioned. There are few solved help links to troubleshoot these problems. Go through the list and Click the link below:----
2000 Toyota Avalon: No heat on Passenger Side?
http://whatisbyme.blogspot.in/2012/05/2000-toyota-avalon-no-heat-on-passenger.html
No heat on Oldsmobile Silhouette?
http://technoanswers.blogspot.in/2012/02/no-heat-on-oldsmobile-silhouette.html
Heater blows cold?
http://schematicsdiagram.blogspot.in/2012/02/heater-blows-cold.html
Heat blows cold on drivers side and hot on passenger side?
http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html
Hot air on the driver's side vents only?
http://repairhelpcenter.blogspot.com/2012/01/hot-air-on-drivers-side-vents-only.html
Temperature gauge does not move and no heat when heater is ON?
http://technoanswers.blogspot.com/2012/01/temperature-gauge-does-not-move-and-no.html
1992 Toyota Camry: A/C Control light Flashing and A/C not Blowing Cold?
http://technoanswers.blogspot.in/2012/04/1992-toyota-camry-ac-control-light.html
No heat, blower blows only cold?
http://technoanswers.blogspot.in/2012/02/no-heatblower-blows-only-cold.html
Ford F150 Ac only blows through defrost vents?
http://technoanswers.blogspot.com/2012/01/forf-f150-ac-only-blows-through-defrost.html
Dodge A/C come out of defrost vents only?
http://technoanswers.blogspot.com/2012/01/dodge-ac-come-out-of-defrost-vents-only.html
Ac vacuum line on dodge cummins?
http://technoanswers.blogspot.com/2012/01/ac-vacuum-line-on-dodge-cummins.html
Ford ranger AC blows cold through defrost vents instead on cabin vents?
http://technoanswers.blogspot.com/2012/01/ford-ranger-ac-blows-cold-through.html
2005 Chrysler PT Cruiser: A/C Blows Warm?
http://whoisbyme.blogspot.in/2012/06/2005-chrysler-p8t-cruiser-ac-blows-warm.html
2009 Mercury Grand Marquis: A/C blows Cold From Defrost Vent Only?
http://whoisbyme.blogspot.in/2012/06/2009-mercury-grand-marquis-ac-blows.html
AC not blowing through Vents on 2007 Chevy Trailblazer?
http://schematicsdiagram.blogspot.in/2012/04/ac-not-blowing-through-vents-on-2007.html
Passenger side temperature is warm air out of dash vents?
http://schematicsdiagram.blogspot.in/2012/04/passenger-side-temperature-is-warm-air.html
These will help.
Thanks.
Nov 28, 2012 | Cars & Trucks
No heat from vents
Heater blows cold?
These will help.
Thanks.
Nov 28, 2012 | 2006 Ford Taurus
When I turn on the heat in my 2004 mazda mpv the front air vents blow heat but the rear air vents are blowing cold. I have adjusted every setting is there something I am overlooking.
When I turn on the heat in my 2004 mazda mpvicon1.png the front air vents blow heat but the rear air vents are blowing cold. I have adjusted every setting is there something I am overlooking.
Jan 14, 2011 | 2004 Mazda MPV
DRYER DOESNOT BLOW AIR OUT BACK of dryer checked screen nothing
Check the entire rear vent pipe. It could be blocked with lint build-up, or a small critter could have gotten in and died.
Sep 25, 2010 | GE Profile Harmony DPGT750EC Electric...
GE AJCQ08ACB Air Conditioner Logo
60 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Lawrence Oravetz
Andrew Taylor
Andrew Taylor
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
