Question about Belkin (F5D7230-4) Router (587009)
HOW do I find router's security settings?
I am trying to connect to a Roku box, to watch Neflix movies. After input of WPA key- the error msg says to check if both the Roku and the router have the same security settings
serra_baby
  • 144 Answers
SOURCE: Belkin Wireless G Plus MIMO (F5D9230-4)
hello!
normally, if you configure the wireless security settings wirelessly, it will automatically disconnect you from the network. you have to input the security key on the laptop first before it connects you back to the network.
i suggest, if you really like to configure the settings of your router, get an ethernet cable, connect it directly to the laptop so you can access and configure the router settings and to avoid from being disconnected
Posted on May 30, 2008
  • 104 Answers
SOURCE: Belkin Wireless Router/HP Laptop - wireless security problem
This is an unusual problem. It's interesting that you can connect without encryption. A few thoughts, which you may well have considered already:
1) Does this happen even when you deliberately disconnect from the network, and reconnect?
2) The network key/passphrase is case sensitive; it is very easy to make a small slip with this, or some other tiny detail, when entering the key;
3) Is there the slightest chance your router has the same SSID (name) as a neighbour's? ....Sorry if this seems a daft question, but it is something to consider...
Posted on Nov 27, 2008
Joed911
  • 4338 Answers
SOURCE: I can't get my Belkin router to accept WPA in security.
Reset the router then try it.:
Step 1 Locate the reset pinhole on the back of the unit.
Step 2 With the unit powered on, press and hold the Reset button.
Step 3 Hold the Reset button for about 10 seconds.
Step 4 Release the Reset button.
Step 5 The unit will reboot. Allow 20-30 seconds before reconnecting.
Step 6 The device is now at factory defaults.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Jul 29, 2009
SOURCE: Support for the Roku netflix box says the Dell Router is blocking
how to connent the roko and what or where is the router
Posted on Jul 31, 2009
  • 4044 Answers
SOURCE: belkin router F5D8638-4 laptop connects but no internet access
Make sure you entered the same key exactly the same way in both the router and the computer. Also, make sure you have selected a Security protocol that is supported by the computer. Some versions of Windows do not support WPA. XP supports it but really doesn't like to auto detect it. If it's a HP laptop make sure you are using a communications channel other than 6. Some routers give you an option to select the channel HP computers don't like working with channel 6.
Posted on Jul 28, 2010
How can i get the arab chanel on my roku 3
Sir
Try lowering the security level on the Dlink router it's most likely set to high for the Roku to connect.
You can do this from the router's setup page on your computer. It's best to make changes from a PC that is connected with a network cable directly to the router.
Open a browser in the address bar type in 192.168.0.1 and hit enter.
The prompt for password XXXX come up the default for dlink router is admin proceed to next screen.
You will be at the dlink page click on "Wireless Settings" on the left side. Then click on the Manual Wireless Network Setup box.
Here you will see the wireless network name and security level change to WPA you can change the key also if you like to save the settings.
Try to connect your Roku to the wireless network.
I hope your D Link router Problem is solved by now,
Or In Case You still need Online D-link Router problem Help assistance then follow us on for
http://www.techsupportrouter.com/support-for-d-link-router.html
Mar 02, 2014 | D-Link Computers & Internet
My roku will drop the program while watching a movie
Sounds to me that your Roku is losing signal to the Router or hotspot. Try setting the router at least 5 feet away from the Roku Box and the higher the router is in the house, the better signal for all devices. Wi-fi broadcast down easier than up!
Jan 31, 2012 | Roku Televison & Video
How do i watch i-player through my wii? got wireless connection,but got error code 51330 hope you can help,thanks!
The error code 51330 on Wii usually indicates that there is a problem relating to wireless security. You can try the following steps below as it should solve the problem:
If you are using WEP or WPA security on your router try this:
1. Log into the router using the default IP (consult your router's manual for assistance)
2. Locate the "wireless security" section of your router settings and find the WEP or WPA key.
3. If you are using 64-bit encryption, the WEP Key must be a 10-character key consisting of numbers or letters A through F.
4. If you are using 128-bit encryption, the WEP Key must be a 26-character key consisting of numbers or letters A through F.
5. The WEP Key must be a Hexadecimal (0-9, A-F, no other special characters or letters).
6. If your router has multiple slots for a WEP Key, make sure the active key is the one in the #1 slot.
7. If you are using WPA, the Wii console is compatible with the following types:
* WPA - PSK (TKIP)
* WPA - PSK (AES)
* WPA2 - PSK (AES)
But if your WEP or WPA key is correct, then the problem might be related to MAC address filtering:
1. From the router settings, locate the "MAC address filter" settings (also known as "access control", "access list", or "network filter" depending on your router model).
2. If the Mac address filter is set to "enabled", then you must add the Wii's MAC address to the "allowed" list. You can locate the Wii's MAC address from the "console information" page (located under "Internet" in the Wii Settings).
3. If the Mac address filter was disabled, then continue troubleshooting.
Check Nintendo's router info for special notes, if available, for your router.
1. go to our Wireless Router look up page.
2. Use the drop-down box to select, if available, your router manufacturer.
3. Click on your router's model number, if available.
4. Read any "special notes" at the top of the router's page. Many issues can be solved by changing settings described in the "special notes."
Lastly, Power cycle your router and modem by unplugging them both from the wall. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then turn on the router. Try to connect the Wii console online and test for proper response.
I hope the above solves your problem.
Good luck.
Oct 23, 2010 | Nintendo Video Game Consoles & Games
What does wpa key stand for when setting up for the x box live
Hi ,
I got your issue , WPA Security it denotes that , the network to which you are trying to connect has been protected with WPA security mode, inorder to prevent other people to connect to your internet.
Usually the router can be secured with 2 different security mode, They are
1. WEP(64 bit and 128 bit)
2. WPA
So your router is secured with WPA security
Oct 11, 2010 | Computers & Internet
Undefined error code and unkown ssid# i had net flix was watching a movie then it would not reconnect error code 51330
Hello Sir
You Problem Was
Error Code: 51330This error code usually indicates a problem relating to wireless security. Please try the following troubleshooting:
  1. Are you using WEP or WPA security on your router?
      • WPA - PSK (TKIP)
      • WPA - PSK (AES)
      • WPA2 - PSK (AES)
  2. If your WEP or WPA key is correct, then the problem might be related to MAC address filtering:
  3. Check Nintendo's router info for special notes, if available, for your router.
    1. Click here to go to our Wireless Router lookup page.
  4. Try a "Manual Setup" with the Wii console (how to), using your network's IP configuration settings. To access these settings:
    1. On your PC, click "Start" and then "Run."
    2. Type "CMD" into the field that appears to open a new window.
    3. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings. Locate the settings asked for by the Wii console during the Manual Setup process and enter them.
  5. Power cycle your router and modem by unplugging them both from the wall. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then turn on the router. Try to connect the Wii console online and test for proper response.
Aug 22, 2010 | Nintendo Wii Console
Im recieving an Error Code 51330 on my TV. trying to watch Netflix on tv.from my Wi Machine
Error Code: 51330 This error code usually indicates a problem relating to wireless security. Please try the following troubleshooting:
      • WPA - PSK (TKIP)
      • WPA - PSK (AES)
      • WPA2 - PSK (AES)
Aug 15, 2010 | Nintendo Wii Console
I need to connect my wii to internet. to watch netflix movies. never connected before to my wireless connection. getting error code 51330. please help me set up
      • WPA - PSK (TKIP)
      • WPA - PSK (AES)
      • WPA2 - PSK (AES)
Apr 21, 2010 | Nintendo Wii Console
Trying to connect Wii console up to internet with a wireless router so can netflix movies got error 51030 what do I do
this is a internet connection error follow the trouble shooting guide i have posted below and if you still need further assistance i can help you from there. Please try the following troubleshooting: Are you using WEP or WPA security on your router? Log into the router using the default IP (consult your router's manual for assistance) Locate the "wireless security" section of your router settings and find the WEP or WPA key. If you are using 64-bit encryption, the WEP Key must be a 10-character key consisting of numbers or letters A through F. If you are using 128-bit encryption, the WEP Key must be a 26-character key consisting of numbers or letters A through F. The WEP Key must be a Hexadecimal (0-9, A-F, no other special characters or letters). If your router has multiple slots for a WEP Key, make sure the active key is the one in the #1 slot. If you are using WPA, the Wii console is compatible with the following types: WPA - PSK (TKIP) WPA - PSK (AES) WPA2 - PSK (AES)
If your WEP or WPA key is correct, then the problem might be related to MAC address filtering: From the router settings, locate the "MAC address filter" settings (also known as "access control", "access list", or "network filter" depending on your router model). If the Mac address filter is set to "enabled", then you must add the Wii's MAC address to the "allowed" list. You can locate the Wii's MAC address from the "console information" page (located under "Internet" in the Wii Settings). If the Mac address filter was disabled, then continue troubleshooting.
Check Nintendo's router info for special notes, if available, for your router. Click here to go to our Wireless Router lookup page. Use the drop-down box to select, if available, your router manufacturer. Click on your router's model number, if available. Read any "special notes" at the top of the router's page. Many issues can be solved by changing settings described in the "special notes."
Try a "Manual Setup" with the Wii console (how to), using your network's IP configuration settings. To access these settings: On your PC, click "Start" and then "Run." Type "CMD" into the field that appears to open a new window. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings. Locate the settings asked for by the Wii console during the Manual Setup process and enter them.
Power cycle your router and modem by unplugging them both from the wall. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then turn on the router. Try to connect the Wii console online and test for proper response. if you require further assistance please let me know and i will be glad to assist you. -Midwest-tek
Apr 20, 2010 | Nintendo Wii Console
Can not connect to the internet error code 51330 WII I have wireless connection in my home
I don't personally know how to solve this, but you could try some of the suggestions here.
Sep 09, 2009 | Nintendo Wii Console
Belkin (F5D7230-4) Router (587009) Logo
172 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
