Question about Saeco Talea Giro Espresso Machine
Talea Giro - Will not grind coffee
Hi! I have cleaned the machine and emptied the coffee grains completely. I have put new grains and still not grinding. Everything else is working perfectly. It sounds like an airplane taking off when it grinds!
I have turned on and off the machine too a few times, gving also a few days rest but to no avail. Can we ourselves undo the grinder???
Hope you could help me! The machine is 3years old now.
    Sniper:
  • 81 Answers
Does the spindle spins when you do the grinding? If not the parts in the grinder is broken. If the spindle still spins and you get sort of wood chip grounds, the adjusting wheel has come off the grinder when you adjust the grinder too coarse.You can undo the grinder if you know how to open the machine. Go to my Odea solutions and look up step by step instruction on how to. Itis very similar.All the best.
Posted on Jul 13, 2010
  • esteban_past
    esteban_past Aug 02, 2012
    btmachi, can you gide me in how to go to my Odea solutions (or your Odea solutions)? I realy need this instructions. Thanks in advance.
Talea ring the grinder will not stop gringing
The Talea model is with a Ceramic grinder system. This can happen when the grinder outlet is clogged with coffee grounds. Fresh beans cannot enter the grinder as the outlet is clogged. Remember, the grinder in any machine is a grinder. It does not shovel the coffee grounds out and clean the outlet when it is clogged.
1- Check if the grind setting is too fine (powder like). If so change the setting to coarse. Fully automatic machines do not need fine grind. Keep the grind fineness like the table slat grain.
2- Check if the beans are dark roast and oily. Oily beans are a slow poison for any fully automatic machine. Change the beans to Non oily medium roast type.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edward_bbd2c7ff4ee1828a
Oct 16, 2014 | Saeco Talea Ring Plus Espresso Machine
Saeco talea giro flashing red exclamation point
take out the coffee waste bin, on the side facing into the machine, there's a little metal bit, it's a kind of sensor.
Clean it if it's dirty with a screwdriver or some wire wool.
Have you cleaned the brew group lately?
Sep 06, 2014 | Saeco Talea Giro Espresso Machine
My SAECO Talea Giro is not working. I have cleaned it properly and coffee beans and water is filled up. The red exclamation mark and the warm water lights are flashing. I can produce steam without a...
The thing that comes to mind is the brew unit is blocked and or the grind is too fine. Remove the brew unit and clean the screen under the red o-ring.
Aug 06, 2011 | Saeco Talea Giro Espresso Maker -...
Coffe does not come out. It grinds but wont drip out.
Hi...The grinder is set too fine, first check the ground cake ,it should be grainy form not in powdery form. Set the grinder about 2 notches coarser.It should fix your problem.
Sep 03, 2010 | Saeco Talea Giro Espresso Machine
Hi, I have a Saeco Talea Giro Plus machine and have only used it a few times. Now the alarm light is permanently on, but the machine has enough coffee and water and the drip tray and dregdrawer are empty....
Hi Natasja, try pull out the driptray and dreg draw while the machine is on and wait about 10 secs. When the red light start flashing, put the parts back. The red light should dissappear. Good luck.
Jul 03, 2010 | Saeco Talea Giro Espresso Machine
Talea giro plus. csan't exit descale cycle
Keep pressing the water button for 6 secs until the flashing light goes off.
Jan 16, 2010 | Saeco Talea Giro Espresso Machine
How do I remove the drip tray on the Saeco Talea Giro?
I have a Talea Giro. To remove the drip tray, just pull it off. I pull from the centre
Nov 09, 2009 | Saeco Talea Giro Espresso Machine
I have a saeco Talea Giro machine. When I press the button to make coffee, the beans grind but no coffee comes out, but raher the water comes out of the steam spout. What is the solution
Check the screen on the brew unit, it might be blocked. If the brew unit is cleaned and the problem is still happening then the steam valve needs to be rebuilt because the pins are allowing the water pressure to pass through.
Oct 07, 2009 | Saeco Talea Giro Espresso Maker -...
Temperature of the coffee?
Not what i know on Talea and Odea, but on Primea can you do it.
Jul 30, 2008 | Saeco Talea Giro Espresso Machine
Saeco Talea Giro Espresso Machine Logo
697 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
