The way the recorder is set up I can`t watch TV while recording on another channel. Also, I have to watch TV by turning on the recorder. I have a digital box. The cable line is coming in from the wall connected to a splitter. One line from the splitter goes to the digital box the other line goes to the TV. I have red, white and yellow going from the digitl box to the audio in on the VCR and another set going from the audio out on the VCR to the audio in on the TV.
  • 19,396 Answers
Hi.
If the splitter is working, and the recorder has a built in digital tuner (ensure), then you should be able to receive channels only using the recorder. In that case you should be able to watch TV while recording on another channel simply by setting channels on recorder tuner, and then by choosing the desired channel number on recorder instead to use the input channel (line in, or AV) fromi tuner box.
If the recorder has its own tuner you can also disconnect tuner box from recorder input and connect the AV cables (red white and yellow) from tuner box straigh to TV. In this way you will be able to use cable box with VCR box.
If the recorder does not have a built in digital tuner you won't be able to watch TV while recording on another channel.
You can find out if recorder has a built in digital tuner disconnecting digi box and attempting to set and use the channels on recorder only.
Posted on Jul 11, 2010
I have just bought a Digihome pvr320sd tv recorder with freeview, can i set it up as a tv recorder only without the freeview as i already have built in freeview on my tv.
When you set up the recorder Freeview stations will be stored. This means that you can record TV stations without watching them. So you can say watch BBC1 on your TV and record a program on Channel Four. You need the recorder set up with Freeview to recorder channels. Otherwise you would have to have your TV on and recorder set to record via the scart lead. Which would be not great quality and messy.
You should be able to loop the aerial lead so that both the TV and recorder can get the signals from your aerial, if that's what is bothering you.
Dec 22, 2012 | Televison & Video
CANNOT GET PHILIPS DVDR3305 TO RECORD ON PANASONIC TV.TX-L37D25B WHILE WATCHING ANOTHER CHANNEL?.
What is your source? Since the DVDR3305 has an analog PAL tuner and most TV stations are broadcasting in digital, you probably have some sort of set top box connected to the recorder. If you change the channel on the set top box, you will record the program on the new channel. If you are recording PAL and your TV has a PAL tuner, you should be able to just record one show while watching another with the DVDR3305 daisy-chained to the TV. Just make sure to change the TV channel not the channel on the DVDR3305.
If your TV has a digital tuner, you can split the signal before the set-top box to record one channel and watch another. (Note: basic splitters will cause some extra loss of signal and may reduce a digital signal below the threshold needed to tune in the signal. An amplified splitter can avoid this - when the amplifier is working properly.) Otherwise, you need a second set-top box (or a dual tuner set-top box).
On my set-up with an aerial antenna, I would put the splitter between the wall jack and the electronics. The incoming cable goes to the splitter, then cable 1 goes to the TV. Cable 2 goes to the set-top box. Tune the set-top box to the channel to record and check the settings with the TV set to the DVD source. (DVD set to record on Tuner (and the specific channel of the set-top box output) or front s-video or EXT1 or EXT2.) Then change the TV back to the TV source and change to the channel for the second program.
The manual for the DVDR3305 is available from Philips. The link to the manual is http://download.p4c.philips.com/files/d/dvdr3305_05/dvdr3305_05_dfu_eng.pdf .
I hope this helps.
(I actually use an A/B switch and do not try to watch a second program on the TV connected to the DVD recorder. However, most of my recordings are for time-shifting of programs that air when I can't watch any TV program.)
Apr 29, 2012 | Televison & Video
The recorder if not recording and when watching previous recordings you cannot rewind or forward wind or turn off
for recording plz click this link may be it helps you
http://windows.microsoft.com/en-US/windows7/Record-TV-in-Windows-Media-Center
and for the change channel and pause live tv you change you remote set. may be it has some problem.
Dec 15, 2011 | Humax Televison & Video
We just dvrs hooked up a few weeks ago.when I am recording somthing down and my daughter goes upstairs to watch her tv and tries to change her channel to watch somthing a message comes up on the tv that...
Hi, poog_23350, I caught your post! How a Duo DVR receiver works is that the TV you have it set to record on will not allow you to change the channel while the recording is in progress. The other TV, that isn't recording anything, can be used freely to flip through channels.
In this case, it's TV2, the one upstairs in your daughter's room, that's currently set to record on while the downstairs TV is free to use. This can be adjusted by pulling up the Main Menu with the Menu button on the remote, selecting option 8, then option 5, and changing the TV1/TV2 setting there on the Record Plus screen.
If you'd like a receiver capable of allowing channel changing while recording a program, our VIP 612 receiver is a Solo receiver that acts like a Duo. What this means is that it has one TV output and two tuners. Along with being able to change channels while a recording is in progress with this type of receiver, you can also record two programs on two different channels simultaneously.
Hope that helps!
Aug 29, 2011 | DISH Network DVR-625 DTV Receiver /...
Connect VCR without tuner to record from television
If it has a scart, you can get a scart lead to connect it to your TV. You would need to set the VCR to the Scart socket, IE: AV1 etc.. to record. You wouldn't be able to change channel on the TV, to watch another channel while recording though. If you had a set-top box, you could connect that up to the scart of the video then record, while you watched another channel on your TV.
Feb 06, 2010 | Televison & Video
With the new HD transfer. We just have atenna...we just bought a HD TV. Is there a way of connecting the DVD Recorder so I can watch one channel and tape another with this new system
A lot of your question depends on your DVD recorder, but there IS a way to connect them so you can watch one channel and record another one.
First - if you have an HD compatible DVD recorder (one that will allow you to select channel 8, 8.1, 8.2, etc) then you could simply split your antenna signal BEFORE the TV or DVD recorder. Then you can select one channel to watch on your TV while selecting and recording a different channel on the DVD recorder. If your DVD recorder is connected to your TV's Video Input, you should be able to monitor DVD recorder's activity by selecting the "Video Input" on your TV.
If you DON'T have an HD DVD recorder, then you will need to get a converter box to put between the Antenna signal and the DVD recorder. You can then set the converter box to the channel you want and the DVD recorder can be set to record it.
Jul 08, 2009 | Philips Magnavox MWR10D6 DVD Recorder
Can I watch tv with the timer on the dvd recorder turned on?
Hook up the cable wire that comes directly from the wall to the dvd recorder's in connection, then get a 3 ft cable cord and connect from the out of the dvd recorder to the in on the tv. You should be able to set the dvd recorder channel and timer and leave it off. you then should be able to have your tv on and watch any station but to watch the tv with dvd recorder on, your tv should be set to either channel 3 or 4 depending on the switch on back of dvd recorder. I hope this solves your problem. Foxpaw13
Jun 15, 2009 | Panasonic DMR-EZ37VS
Recording
You should set the VCR to the channel which you want to record. It doesn't matter what channel the TV is on. In your case, just turn off the TV.
I making assumptions about your setup. If you can turn on your VCR and TV and watch the channel that you will be recording, then just turn your TV off, and you should be good.
Only caveat, some VCRs must be turned off while waiting for the recording timer to activate (presumably, so as not to interfere with someone actively watching a program).
May 19, 2008 | Sanyo VWM-800 VHS VCR
Unable to record one tv channel while watching another tv channel
You CAN record one channel and watch another with satellite service, but it would require two separate DBS receivers. The issue is that all satellite broadcasting is encrypted until it hits the receiver, which decodes it and transmits it outward toward your other AV devices. If it weren't for the receiver, connecting the coax cable to your other devices and trying to tune channels with them would yield no signal and possibly much frustration. You would need to split the signal into each receiver and have one connected to the television via one input and the other to the recorder then to the TV via another input.
With cable, you can split the signal without having to have two boxes - this way the QAM tuner in the cable box is still capable of tuning channels while the recorder can tuner basic cable channels for recording separately. You can also have the cable box connected to the recorder via composite so that you can record premium stations on a DVD recorder input mode anytime you like - but you would have to be watching that channel at the same time unless the DVD recorder had a pass-through RF signal (rather than a composite clone) - meaning you could also use coaxial to your television from the recorder and tune channels separately on your television while the recorder is recording one channel.
A lot of what-ifs there, but it is all quite possible.
Mar 18, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
