Question about Refrigerators
The refrigerator evaporator iced up. I thawed it with a hair dryer and the fan does not come on. Would a bad refrigerator fan cause the evaporator to ice up and the temp in the fridge section not to stay cool?
  • 166 Answers
A bad fan wouldn't cause your evaporator to ice up but would cause the refrigerator section to not stay cool
Posted on Jul 12, 2010
Hi. i have a kenmore french door bottom freezer refrigerator thats leaking in the back of the fridge part. is it a clog in the evaporator drain tube? its all a big sheet of ice from it leaking.
remove back panel of refrigerator. use hair dryer to melt ice in drain pan under evaporator. keep thawing drain and pouring hot water down it till water runs down and clears drain tube.
May 07, 2017 | Kenmore Refrigerators
How do i fix a loud noise coming from my frigidaire glrs264za refrigirator?
Sounds like you have ice buildup next to the evaporator fan that circulates air inside the fridge. Ice buildup happens due to too much moisture - door open for extended periods, leaky door seal, heating system meant to de-ice the fridge not doing its job. You can approach this two ways. Unplug and leave both sides of the fridge open for at least 24 hours to let it thaw, or open up the fan cover and thaw it with a hair dryer (fridge unplugged ofcourse). Option two is faster, but more labor intensive. This wont solve the underlying problem of ice buildup, but will get rid of the noise for some time (likely months).
Sep 06, 2014 | Refrigerators
My sub zero refridgerator (freezer on bottom fridge on top) is cold on the bottom of fridge and warm on the top of the fridge. Any idea what is causing this. Items are also damp in fridge. We just vacumed...
the evaporator coil inside the freezer compartment is iced over and can't transfer cold air in thes condition,remove panel inside freezer on back side of freezer compartment and thaw it out with a hair dryer,then check the defrost heating element for continuity,if its open replace it,if its good, ,check the defrost control that powers the defrost heater
Jul 15, 2010 | Sub-Zero 611 / O Bottom Freezer...
The fridge runs all the time but it is not cold & the freezer is only as cold as the fridge should be.
check the back wall of the freezer for frost build up,if so remove panel and the evaporator is iced up,thaw ice out with hair dryer then check the defrost heater under the evaporator coil you de-iced its either bad or the defrost control is bad be it a timed or adaptive type defrost control
Jul 17, 2010 | Frigidaire Refrigerators
Refrigerator and freezer are not cold
possible causes: bad door seals or condensate drain plugged causing evaporator coils (in freezer) to ice up, condenser or evaporator fans not on, condenser coils dirty, compressor not working, or a freon leak. if the back wall of your freezer is frosty or super cold, the coils are iced up. remove the back wall and defrost it with a hair dryer. if the water doesn't drain, unclog the drain tube. check the door seals for gaps. replace if necessary. check the fan in the freezer and the fan in the back. both should come on when the compressor is on. if not, check the fuses on the main board. replace if needed. if all that is fine, and there is no frost, you have a slow leak or a bad compressor. call in a pro or get a new fridge.
Nov 12, 2009 | Kenmore 57029 Side by Side Refrigerator
The freezer isn't gettting cold enough to freeze solid and the ice maker isn't making ice because of that too. Repairman says we have a freon leak. Is that a valid response...
Nov 12, 2009 | Amana SXD524VW Side by Side Refrigerator
My samsung rb 1855sl is having an issue where freezer is not working.
Nov 12, 2009 | Samsung RB2155 Bottom Freezer Refrigerator
Evaporator fan stopped spinning
while you have pannel off replace heating element on the evap. this is causing the ice buid up.. after defrosting with hair dryer if you were useing a sharp object you cold of put a hole in the evap and lost all freon use hair dryer.. make sure you do not bend the fan blades if so you might have to replace, make sure same blade degree is replaced marked on blade most of time....
Aug 12, 2009 | Frigidaire FRT15B3A Top Freezer...
Ice build-up around the fan making a noise.
Drain line froze.
Used hair dryer to thaw frozen line, works OK now. 01/07/09
Think the frozen drain line was caused by the light in the refrigerator not shutting off when the door closes, causing excess cooling in the freezer. Poor design on the light shutoff switch, corrected design to make permanent repair
chestnutlee.
Dec 27, 2008 | GE Refrigerators
GE refrigerator not cold but Freezer works fine
you need to find out if the evaporator fan in the freezer is working. or if the evaporator is all iced up. If the fan is not working you will need to replace it. If the coils are all iced up you have a defrost problem and that will ned to be resolved. Once a evaporator is all iced over air can not pass through it and you will loose your cooling in the refrigerator first. Check the heater and the terminator to make sure they are good. You can use a hair dryer to clear the ice off the evaporator. Once you find the bad part replace it and the unit will function normally
Jul 23, 2007 | GE J Series 18.2 cu. ft. Top Freezer...
Refrigerators Logo
158 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
