Question about GE Profile JTP56 Electric Double Oven
Error code f0 - GE Profile JTP56 Electric Double Oven
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error F0 means a stuck/faulty touch pad. You’ll need to check the touch pad and if faulty replace it. However, usually the Electronic Range Control (ERC) is also replaced if this error cannot be cancelled. You’ll need to check and replace the oven control (also called clock or ERC), touch pad, or both. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 12, 2010
Testimonial: "I replaced the touch pad but did not have to replace the ERC. Thanks. This solution solved my problem."
Double wall oven F0 error code
The F0 error code means that the control board has detected a defect within the control board itself, the F0 code can be cleared by pushing the CANCEL/OFF button and if it goes away and returns all is well,however if a short time later the F0 returns the control board would need to be replaced.
GENE
Oct 04, 2011 | GE Profile 30" Built-In Double Electric...
F0 Error code
your model number please?
Jan 21, 2008 | Ovens
Dacor model ersd30 how do i fix an F0 error code that also blinks F1 and beeps
Hi dan8260,
If you're encountering F0 error code, it is due to a stuck function key. You need to replace the touch pad to fix this error. If the touch pad is part of the clock, you need to replace the clock or ERC.
Hope it helps.
Thank you for using FixYa.
Feb 07, 2011 | Dacor Epicure EO127 Stainless Steel Dual...
I am getting an F0 error code on my GE JTP15. It was working and then just shut-off. Then the error code appeared. I removed power for 30 minutes but the oven control did not reset.
F0
Stuck touch pad Usually means that either the touch pad or the oven control
(also called clock or ERC) is defective and needs to be replaced. If this fault
code cannot be cancelled, replace the oven control (also called clock or ERC),
touch pad, or both.
Jan 30, 2011 | GE JTP15 Electric Single Oven
Error code - F0
F0 Stuck touch pad Usually means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be cancelled, replace the oven control (also called clock or ERC), touch pad, or both.
Sep 14, 2010 | GE Profile JTP56 Electric Double Oven
What does an error message "F0" mean for kenmore model 911.41185991?
for a maytag the F0 code means a function key is stuck, and recommends changing out the touch pad, or touch pad and oven control assembly if one unit. google your model number for error codes.
Jun 21, 2010 | Ovens
GE Profile Performance Spectra Range error code F0
F0 - F1 - F7 Stuck keypad may mean relay is turned on. Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Jun 20, 2009 | GE JKS05 Electric Single Oven
F0 error code on ge profile oven
Could be a stuck keypad. Try pressing all pads at random several times each to clear it.
If that does not work the ERC(clock) must be replaced.
May 26, 2009 | GE Profile JTP18 Electric Single Oven
326B1230P001 GE TrueTemp Black Oven Error Code F0
We had the same problem with our GE Tru Temp Oven and the fix worked like a charm! Thank you for posting this fix - you saved our dinner party!
Jun 21, 2008 | GE JKS05 Electric Single Oven
GE Profile Performance Double Oven
I was getting only the F0 error code. The wiring diagram inside the stove said F0 indicated a bad off button on the keypanel. There were instructions to check the ribbon cable on certain lines, with values for the resistance. It seemed to check out, so I ordered a replacement and voila, it worked.
Jun 11, 2008 | GE Profile JTP56 Electric Double Oven
GE Profile JTP56 Electric Double Oven Logo
423 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a GE Oven Expert? Answer questions, earn points and help others
