Question about SPL DK-2600D Car Audio Amplifier
Spl fx-1800 My amp was working fine, I took it out my old school and put it in my truck , now the protection light won't go off.. Any suggestions
  • 52 Answers
Hmm i would start by checking the wiring in your truck. make sure nothing is grounding out (short). if still happening try hooking the amp up to a battery out side of the vehicle and see if the light is still on. if so u need a new amp
Posted on Apr 21, 2008
I have 2 Soundstream SPL 10 Car Speaker
need to know model number on amp, and the impedance of the woofers
Apr 06, 2012 | Soundstream SPL 10 Car Speaker
Everything wired right but light on amp won't come on. Took it apart an not burned anywhere. What's the problem an how to fix it?
It is possible that the amplifier had encountered a fault with a higher current drain which had triggered it to a protection fault condition. The fault can be your output drivers- the MOSFETS/IC's fitted for both the channels, Use a meter after disconnecting to check for short in the drivers. Disconnect the positive and negative voltages to the output and see if the protect changes. Even a fault in the preamp stages that drives in high current into the output can shut the Amplifier. Sometimes this can be a noise like a HUM or HISS before the protect works. Faulty capacitors in these circuits also can cause similar issues and needs close observation.
You need to confirm and replace the specific stages or outputs. If not there can be issues in the mother board, maybe the protect circuit by itself is shutting off due to a faulty bias , maybe a leak in any voltage/current sensing circuit. Also disconnect the speakers and test, if the protect is off then check for short on the speakers.
Jul 22, 2011 | SPL Audio Phantom DK2-2400 Car Audio...
I have a spl fx2 1800 that i got from a guy for 40 bucks and it is frozen in the protect mode is there a way i can get it to come out of the protect mode with out sending it in to the shop
The most likely culprit when an amp goes into protection mode is the power wiring. Check your ground wire, it should be solidly connected to the vehicle chassis in a paint-free location. Then check the live power wire and make sure it has a good connection. If that doesn't work, download the user manual from retrovo.com. That should help you to decode why the amp is in protect mode.
Mar 05, 2011 | SPL FX21800 Car Amp
Amp goes straight to protecting
bad power supply or out put i hat to say it but spl is note a good company i would replace the amp
Jul 07, 2010 | SPL Dynamics CRM1200-2 Car Audio Amplifier
The fuse blew on my spl 1920watt amp and now the protect light wont go off and it wont do anything
Did you put a new fuse in it? If you didn't then put a new fuse that is rated at what the amp calls for. If you have and the light stays on, then odds are there is a broken wire inside and the amp needs repairing or replacing.
Jul 12, 2009 | SPL Audio Car Audio & Video
Opened my garage door remote and now it doesnt work
old school hollywood baseball old school hollywood baseball old school hollywood baseball old school hollywood baseball old school hollywood baseball old school hollywood baseball old school hollywood baseball old school hollywood baseball old school hollywood baseball
Feb 01, 2009 | General Electric GE 13-438 Overhead Garage...
Amp not working
If the amp is in protect mode, it probably has shorted output transistors. To eliminate other possible problems, read through the following page:
Amp in Protection - Troubleshooting
Let me know if you have any other questions.
Aug 18, 2008 | SPL Dynamics Z2X-820 Car Audio Amplifier
Sony explode amp for my car
Try disconnecting everything but the power connections. If the protection light still comes on, then there's a problem in the amp. If it goes out, then there's a problem elsewhere. In that case, hook up one speaker cable at a time and power on. If the protection light comes on, then either that speaker is bad, or you've got too many speakers connected to that one amp output. Too many speakers connected together can cause an overload and trigger the protection circuitry, or worse, blow out something out.
Hope this helps, and please rate my advice.
Thank you, and good luck!!
Feb 04, 2008 | Car Audio & Video
SPL DK-2600D Car Audio Amplifier Logo
162 people viewed this question
Top SPL Car Audio & Video Experts
Tygh Duval
Tygh Duval
bigdawg7299
Are you a SPL Car Audio and Video Expert? Answer questions, earn points and help others
