Question about Garmin eTrex Legend Cx GPS Receiver
The 5th digit the cordinates N & W WILL NOT LET ME PICK ANUMBER 6
7,8 or 9 when i try manually AGAIN ITS THE 5th DIGIT in the 7 digit cordinates MY ETREX LEGEND
  • Garmin Master
  • 638 Answers
You need to make sure your unit is set for decimal degrees. It's probably set for a different format.
Main menu> Setup >Units > hddd.ddddd
If this solves your problem, please come back and rate our answer. Thank you.
Posted on Nov 04, 2010
Search a string of at least five numbers (for example, 65403) Identify all of the substrings that form numbers that are divisible by 3.
I guess a hint is that to see if a number is divisible by 3, you can add up the digits of the number and if the sum is divisible by 3, the number is divisible by 3. Another way of seeing if a number is divisible by 3 is to do an integer divide and then multiply back to see if you get what you started with. For example, 7 / 3 = 2. 2 * 3 = 6, thus 7 is not divisible by 3.
As for all the substrings, start at the 5th number and do substrings of length 1 to 5, Move to the next digit, do substrings of length 1 to 4. Move to the next digit, do substrings of length 1 to 3. Repeat until only 1 digit is left.
Good luck,
Paul
Apr 12, 2016 | Office Equipment & Supplies
I HAVE A 2007 HARLEY DAVIDSON CLASSIC SOFTTAIL. SECURITY SYSTEM PROBLEM. I HAVE REPLACED BATTERY & KEY FOB STILL COMPUTER WILL NOT ALLOW ME ENTRY TO DISARM & WILL NOT CRANK. DID STEP BY STEP OWNER...
If you do not know the security code, you can reset it to your own choosing.
With the fob present, turn IGN switch:
IGNITION-OFF-IGNITION-OFF-IGNITION
Press LEFT turn signal switch 3 TIMES
Press RIGHT turn signal switch 1 TIME and release
Turn signals will flash 3 times. Current PIN will appear in odometer. The first digit will be flashing.
If changing PIN, enter first digit (a) of new PIN by pressing LEFT signal switch (a) time(s) i.e., for the number 1, press one time. for the number 5, press 5 times.
Press RIGHT signal switch 1 TIME and release.
the new digit (a) will replace the current in odometer window.
Enter second digit (b) with LEFT signal switch.
Repeat until PIN is set.
Once PIN is set (either new or old PIN), to disarm security system, DO NOT sit on seat, lift bike off kick stand, or anything else that will activate the security mode!
Turn IGN to IGNITION.
Quickly (within 2 seconds) hold BOTH turn signal switches until confirmation signal (KEY icon flashes at fast rate, in odometer window, a flashing "-" will be followed by 4 more dashes = "----")
Enter 1st digit (a) in PIN by pressing LEFT turn signal switch (a) times (i.e., 5 times for the number 5)
The 1st "-" will become the 1st digit (i.e., "5")
Press RIGHT switch signal 1 TIME.
The 1st digit is stored and the dash will flash.
Enter 2nd digit (b), and repeat sequence until done.
After the 5th digit is entered, the KEY icon stops blinking, and the system is disarmed.
The system will stay off until the IGN switch is turned off.
If at any time during disarming sequence an error is made, wait 2 minutes before trying again.
Feb 28, 2013 | 2007 Harley Davidson FXSTC Softail Custom
Retreving calls from another phone uaing my code does not work any longer. I would like to reset the code. Please give instructions. Thank You,
Changing the Remote Access Code The Remote Access Code is preset to 500. You can change the Remote Access Code to any three-digit number from 500-999. DO NOT pick the same number as that assigned to the Priority Calling Code. 1 Press g. The Message Window displays CH. 2 Hold down c for at least two seconds. The system announces "First digit." 3 Press / or ? to change the digit. 4 When the Message Window displays the desired first digit, press c. The system announces "Second digit." 5 Press / or ? to change the digit. 6 When the Message Window displays the desired second digit, press c. The system announces "Third digit." 7 Press / or ? to change the digit. 8 When the Message Window displays the desired third digit, press c. The system announces the new Remote Access Code.
Aug 26, 2011 | AT&T 1725 Answering Machine
How do I play regional dvd's that the player is not tuned to. I have been trying to find a code but I am struggling. Can you help me?
Hi
You need to follow these instructions.
To unlock the Region Code on a Panasonic DMR EZ48 using a One for All - URC 7040
1. Switch on the player (make sure the drive select is DVD).
2. Select DVD on the URC.
3. Hold the magic button on the URC until the DVD button on the URC blinks twice
4. Enter device code 0490 on the URC, (DVD button blinks twice), URC takes control of the Player.
Point the URC at the Player and program the URC buttons using the following procedure:
1. Hold magic button until the DVD button on the URC blinks twice
2. Press 994 (DVD button blinks twice)
3. Briefly press magic.
4. Enter 4 digit code 1911 (DVD button on URC blinks twice)
5. Repeat steps 1, 2 & 3
6. Enter 4 digit code 1202 (DVD button on URC blinks twice)
7. Repeat steps 1, 2 & 3
8. Enter 4 digit code 0653 (DVD button on URC blinks twice)
9. Repeat steps 1, 2 & 3
10. Enter 4 digit code 1804 (DVD button on URC blinks twice)
11. Repeat steps 1, 2 & 3
12. Enter 4 digit code 1435 (DVD button on URC blinks twice)
13. Repeat steps 1, 2 & 3
14. Enter 4 digit code 1556 (DVD button on URC blinks twice)
15. Repeat steps 1, 2 & 3
16. Enter 4 digit code 1227 (DVD button on URC blinks twice)
17. Repeat steps 1, 2 & 3
18. Enter 4 digit code 1178 (DVD button on URC blinks twice)
19. Repeat steps 1, 2 & 3
20. Enter 4 digit code 1299 (DVD button on URC blinks twice)
21. Repeat steps 1, 2 & 3
22. Enter 4 digit code 1230 (DVD button on URC blinks twice)
23. Press the One For All URC buttons in the following sequence
1, 2, 3, 4, 5, 6, 7, 8, 9, THEN hold down 0 until "HELLO" appears in the display;
After about 1 minute the Player comes back to life as Multi Region.
Please dont forget to vote if you liked my answer
thanks
Feb 13, 2011 | Panasonic DMR-EZ48 DVD Recorder
I GOT A 2000 SILVERADO 1500 OBD CODE IS 421 THE PROBLEM IS I DON'T KNOW LOCATION OR HOW TO FIX THE PROBLEM
Sounds like an O2 sensor, especially if your not experienceing major problems.
Example obd code P0101
1st digit: B-Body, C-Chassis, P-Powertrain, U-Network
2nd digit: 0-SAE (generic), 1 mfg (Manufacturer Specific)
3rd digit:
* 1 Air & Fuel Metering
* 2 Air & Fuel Metering Injector Circuit
* 3 Ignition System (Including Misfire)
* 4 Auxiliary Emissions Controls
* 5 Vehicle Speed Controls And Idle Control System
* 6 Computer Output Circuit
* 7 Transmission
* 8 Transmission
4th & 5th digit - two place fault code 0-99
Feb 02, 2011 | Chevrolet Silverado 1500 Cars & Trucks
I need the formatting code
Try these default security codes:
Default 4 Digit user code: 1234 or 0000
Default 5 Digit Security code: 12345 or 00000
Default 6 Digit Security code: 123456 or 000000
Default 6 Digit Security code: 000999 or 1122
Jan 05, 2011 | Nokia 6111 Cellular Phone
34122 45200 56300 67428 785630 what is the next line ? explain the pattern
We can solve this problem by taking digit by digit.
First and second digit,both are increased by 1,respectively
34…,45…,56…,67…,78…,89…
Third and fourth are the multiplication of first and second digit
3 x 4 = 12
4 x 5 = 20
5 x 6 = 30
6 x 7 = 42
7 x 8 = 56
8 x 9 = 72
so now the series become
3412.,4520.,5630.,6742.,7856.,8972.
Last digit equivalent multiplying the third and fourth digit:
1 x 2 = 2
2 x 0 = 0
3 x 0 = 0
4 x 2 = 8
5 x 6 = 30
7 x 2 = 14
34122,45200,56300,67428,785630,897214
Mar 05, 2010 | Mathsoft StudyWorks! Middle School Deluxe...
Honda civic D15B7 japan or american made?
You can determine where your car was made by examining the VIN
Example Description Vin # ------- -------------------------------- J ╗ H ] - JHM = Honda Motor Co. passenger car M ╝ E ╗ EG1 = D15B7 (93-95 S) G ] - Engine: EG2 = B16A2 (96-97 VTEC), B16A3 (94-95 VTEC) 2 ╝ EH6 = D16Y7 (96-97 S), D16Y8 (96-97 Si), D16Z6 (93-95 Si) 1 ] - Body/Transmission: 1 = 2-door manual 5-speed 2 = 2-door automatic 6 ] - Vehicle Series: 4 = S 6 = Si 7 or 9 = Si with ABS, or VTEC ? ] - math check digit R ] - Model Year: P = 1993, R = 1994, S = 1995, T = 1996, V = 1997 S ] - Assembly Plant: C = Sayama, S = Suzuka, T = Tochigi 0 ╗ 0 ║ 5 ] - Serial number, based on the sequence off the 7 ║ production line 9 ║ 3 ╝
Feb 12, 2010 | 1994 Honda Civic
Tune up specs needed
1968 Barracuda with a 318cid; The 5th digit of the vin will be (F) for the engine-318 2v rated @ 230hp.
Compression pressure--125-155 max variation 25
Spark plugs--Champion N-14Y @ .035" gap-torqued @ 30ft. lb.
Timing--man. trans @ 5 degrees btdc, auto trans @ 10 degrees btdc.
Points-- .014"-.019" gap--Dwell--28-33 degrees, max variation is 2 @ 1500 rpm--Spring tension--17-20 ounces.
Fuel pump pressure 5-7 lbs. manual pump
Hydraulic Lifters--no valve clearances
Firing order--1-8-4-3-6-5-7-2 counterclock wise rotation
Idle speed--Turn headlights on highbeams and turn a/c off
500rpm for man trans--500rpm auto trans in neutral.
Left bank of the engine (driver's side), 1-3-5-7 Right bank (passenger side), 2-4-6-8
May 22, 2009 | 1983 Plymouth Gran Fury
Setting the time
At extension 1
press Program (mute light turns on)
press Transfer (mute light flashes)
dial "38"
enter 2 digit year, i.e. "08"
enter 2 digit month, i.e. "05" = May
enter 2 digit day, "01" = first of the month
"31" = last day of the month
enter 1 digit day of the week
1=Sun, 2=Mon, 3=Tue, 4=Wed, 5=Thu, 6=Fri, 7=Sat
enter 2 digit hour in 24-hour format
00=midnight
01=1 AM
13=1 PM etc
enter 2 digit minute from "00" to "59"
press MUTE.
You will hear a single confirmation beep. If not, you did something wrong. Start again from the top.
Nov 29, 2007 | TMC M4810 NON-KSU Corded Telephone
Garmin eTrex Legend Cx GPS Receiver Logo
137 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
