Question about Husqvarna Forest & Garden 125c 17" Curvgastrimmer
325 X-L trimmer throttle doe not operate.
Dog ear that holds the throttle handle broke. I replaced it but now I can not get the throttle to depress. When I removed the handle the cable and and spring were not in their proper location. I do not know the proper location of these.
    President:
  • Husqvarna Master
  • 1,545 Answers
There should be a small recessed area off to one side inside the handle for the routing of the throttle cable...Look closely. The spring that controls the return on the trigger isn't too complicated either. It has to be held in place somehere on the throttle handle also and may have to be preloaded so there is tension on it when you install it..Look around closely in the area in the handle RIGHT above the trigger.
Posted on Jul 12, 2010
Starter handle will not catch
It's possible that a few things are happening. Some recoil set us have the dog ears, the little plastic piece that flaps out and catches the flywheel bell. Have you taken that cover off the unit yet? If not, take it off, pull the cord and see if either the dog ear is broke or something else is...this is an easy fix, recoil assys are not expensive at all... it all starts with that pull cord assy. Should be 4 screws that hold on the side panel to the saw, just don't take the recoil pulley out or you may find the spring will pop free from where it sits..
Oct 05, 2015 | Garden
Starting procedure
Terry: According to eHow.com:
  • Put on a pair of safety glasses. Remove the fuel cap from the Weed Eater and set it aside. Fill the fuel tank with unleaded gasoline that has been mixed with quality 2-stroke oil in a 40:1 ratio. Replace the fuel cap.
  • Move the Weed Eater to a safe place and lay it flat on the ground. Depress the fuel bulb located beneath the carburetor approximately six times to prime the engine. Press it slowly so that fuel has adequate time to traverse the fuel line.
  • Slide the handlebar-mounted engine "On/Stop" switch to the "On" position. Slide the choke lever beneath the fuel tank to the "Full" position.
  • Depress the "Throttle Lock" lever located beside the engine "On/Stop" switch. Keeping the lever depressed, squeeze the throttle trigger. Release the throttle lock. This sequence holds the trigger in the depressed position, which aids in starting the Weed Eater.
  • Roll the Weed Eater so that it is resting on the engine and the trimmer head shield only. This will allow the spinning trimmer head to avoid contact with the ground. Brace the Weed Eater by holding it to the ground with one hand. Using your other hand, pull the starter rope quickly until the engine begins to run. Do not pull the rope more than a dozen times. If it fails to start by then, squeeze the throttle trigger and continue to pull until the engine starts.
  • Allow the Weed Eater to warm up for about 15 seconds, then slide the choke lever to the "Off" position. Let the trimmer run for another minute without touching the throttle lever. After the Weed Eater has warmed up, squeeze the throttle trigger once to disengage the throttle lock. The trimmer is now operational.
  • Read more : http://www.ehow.com/how_6720315_start-gas-weed-eater.html"
    Jun 08, 2015 | Garden
    How do I adjust the throttle cable on a C430 String Trimmer? When I depress the throttle cable, the linkage on the carburetor only moves about 1/16 inch and will barely turn the cutting head.
    The throttle cables aren't adjustable. Make sure the other end is on the trigger correctly and that it is routed through the handle and the engine cover correctly. Also, make sure the throttle shaft and throttle plate (inside carb) are free and easy in their movement with the throttle cable off. The engine idle speed adjusting screw may be in too far also. Back it all the way out and then back in with the throttle closed Once the speed screw touches the throttle lever (what you hook cable into) on the shaft, give it about 2 turns in. This is about all you can do. If the cable is stretched badly (rare), it would need to be replaced.
    Oct 26, 2010 | Ryobi Garden
    I have a ryobi hedge trimmer p2601 and the plastic handle broke. Is there a way to get a stronger handle or just a replacement?
    May 29, 2010 | Ryobi 18V Hedge Trimmer
    Weedeater is usable and ready, don't know how to start it
    I hope you have fresh gas and 2-cycle oil mixed up! They always seem to start strong and explosively cut on good, fresh fuel. :D
    1:Choke on.
    2:Push the primer bulb (rubber ball by the side of the air filter) 3 times.
    3:Place trimmer on ground. Grasp the handle, squeezing the throttle fully in left hand. Kneel and give that starter a crisp, sharp tug with your right hand. If the engine "hits", then push in the choke until off. Goto step 4.
    If it does not give a hint of life, repeat the tug on the line 2 more times. If it STILL does not start, check for a distinct odor of gasoline. Likely, at this point, it is flooded, proceed to step 5.
    4: With choke now off, continue to depress the throttle fully and give it another sharp pull on the starter. If it starts and revs? Let it idle for a minute to warm up, then go to work!
    5:With choke OFF, press and hold throttle at full. It may take several pulls on the starter rope to see any life. If after 10 pulls and there is still no life, and still smells of gasoline - time to see the Ex about getting the trimmer looked after for some TLC. :D
    May 08, 2010 | Craftsman 25cc Gas Line Trimmer
    Case won't opem
    There is a screw underneath the Toro label.   I learned the hard way.
    Jun 09, 2009 | Toro& Electric String Trimmer
    REplacing the pulling cord on a gas trimmer
    those are usaully under your pull start cover and if its broke you can buy a new rope but if its broke near handle i would open it and retie it to save ya money. but remember to wind spring a little to keep tension on it before pushing it through the hole for handle.
    Apr 17, 2009 | Craftsman Convertible 25cc. Gas Line...
    Throttlc cable
    Disassemble the handle. Remove the cable and pay attention to the HOOK in the carb throttle. Install the new cable in the exact location, positioning it in the handle properly. Check for proper operation before you reinstall the handle.
    Sep 05, 2008 | Garden
    Trimmer Broke
    Call this number; 1-800-736-4648 Or go to this link; http://www.remington-products.com/consumer/contact.htm Hope this helps :)
    Apr 04, 2007 | Remington NEDH-2500 Nasal/Ear Trimmer
    Husqvarna Forest & Garden 125c 17" Curvgastrimmer Logo
    447 people viewed this question
    Top Husqvarna Garden Experts
    Jim Parker
    Jim Parker
    Phil Walker
    Phil Walker
    Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
