Question about NorStar Meridian M7310 Phone
We have a M7310 meridian with startalk voicemail. We programmed the auto attendant greetings correctly, which comes after three rings. However this greetings is followed by another old greetings by previous owner and we are not able to locate it and delete it. We have tried a lot of things but failed.Even the local phone specialist says it is a ghost voice mail and cannot be deleted. Once again this is not individual phone greeitng but auto attendant greeting
  • wingglider2 Jul 12, 2010
    I do not think the solution pertians to the question.
    As mentioned it has got nothing to do with individual mail box or its greetings.
    This is related to Auto Attendant. When you login as Admin and use 'AA' , record say greeting -1 and assign it to a table and inturn assign it to a line ( We have assigned all lines same table, same greeting)
    When some one calls from outside after 3 rings the Auto Attendant greetings comes on and if no extension is picked (as instructed by the AA greeting), another old greetings comes on. No idea where this old greeting resides and how it comes. We need solution to locate and delete the old greetings.
    Hope the question is clear
    President:
  • 1,070 Answers
Welcome to FIxYa
Si/Madom,
How To Change Your Personal Greeting:
  • Press the Check Voicemail key or press the Feature button, then 981
  • Enter your password
  • Press the ADMIN softkey
  • Press the GREET softkey
  • Press the REC softkey
  • Press the PRIME softkey
  • Press the YES softkey
  • At the tone, record your new greeting, press the OK softkey to end your recording and then the OK softkey again to accept the new recording
How to Add, delete, or change a Mail Box and more Information look this Link
To Record Your Alternate Greeting (Used when on vacation or out of the office.:
  • Pres the REC softkey
  • Press the ALT softkey
  • At the tone, record your new greeting, press the OK softkey to end your recording, then the OK softkey again to accept the new recording.
  • You then need to have your voicemail box now play the Alternate Greeting, Press the GREET softkey
  • Press the ChOOSE softkey
  • Press ALT softkey
  • Display will show: "Accept msgs: Y", Press the OK softkey to have your voicemail box accept messages while your Alternate Greeting is turned on, or press the CHNG softkey to change the "Y" to an "N" if you do not want your voicemail box to accept messages.
  • When you return to the office, make sure you go back into your voicemail box and have it play the PRIME greeting
I hope you got it Now...Thanks for Contacting FixYa..
Posted on Jul 12, 2010
  • 677 Answers
Hi,reset the admin password.
Norstar Voicemail for Call Pilot
Log In to System Administration:
1. Enter Feature 983 on a programming set
2. The display will show "LOG:", enter login password: "1020000"
3. Press the softkey under "OK"
4. Select the softkey under "MBOX"
5. Select the softkey under "DEL"
6. Enter the mailbox number (extension. you want to delete - 123)
7. Select the softkey under "Delete"
8. Press the RLS button to end.
Voila, now the mailbox is deleted.
Ok ~ well if you do a Feature 980, 12 and leave a message, is this the greeting that you heard.
Well you can change that extension 12 password:
How to Change a Mailbox Password 1. To access the voice mail system press "Feature".
2. Press "983".
3. When you see "Log:" enter "120000" for 2 digit extension numbers, enter "1020000" for 3 digit extension numbers.
4. Press "OK".
5. Press "MBOX".
6. Press "CHNG".
7. Enter the mailbox number you wish to reset.
8. Press "Reset".
9. Press "Rls" to exit (orange button to the right of the number buttons).
Default password is "0000".
By changing that password for the admin mailbox, you can change the greeting, -or- there is another choice, change where 12 goes to from the CCR tree (Custom Call Routing).
Meaning when you hear "press 1 for x press 2 for y and press 3 for z", that is the CCR Tree... if someone dials 12 it goes to a route 12, which points to an extension.
We can alter where 12 points to:
4. Select the softkey under "OTHR"
5. Select the softkey under "CCR"
6. Select the softkey under "ADMIN"
7. You will see CCR Tree: and type in 1 and "OK"
8. Select the softkey under "CHNG"
9. You will see PATH: type in 1 2 and "OK"
10. Select the softkey under "CHNG"
11. Press INT (for internal extension)
12. And type in the internal extension transfer is to go to, you can point it to the main reception set's extension.
13. Press the RLS button to end.
Posted on Jul 11, 2010
  • wingglider2 Jul 11, 2010
Not the normal voicemail problems
Before you can do anything you need a M7310. Programming a Nortel voice mail requires M7310. It uses the 3 soft keys under the display to program it. You can get one cheap on EBAY. Next you need to find out what type of Voice Mail System in connected to your Nortel phone system. Below is a link to a Older StarTalk manual. You may have a StarTalk, StarTalk Flash, or a Call Pilot.
http://www.myuserguides.com/Nortel_Norstar_Startalk.pdf#page=15&zoom=auto,-69,407
Below is a link that tells how to reset the System Manager Password.
Reset Admin Password Norstar Meridian and Nortel BCM Help Guides
The default code and password for System Admin is F983 and 1020000 or 1021111. The photo below shows a system admin programming tree. Hope this helps
Charlie
Apr 10, 2015 | Nortel Norstar M7208 Telephone
PLEASE HELP!!!!!! DESPERATE!!!! M7310 NORSTAR - No one helped me with auto attendant but I figured it out. 1st greeting is you have reached... press one for touchtone... greeting is correct and says...
The problem you describe is not the fault of the phone, but a function of the Voice Mail system the phone is connected to. The solution previously posted is partially correct but each destination in the greeting table (the table entry associated with the number the auto-attendant recording tells the caller to press to reach a specific destination or feature) is assigned a function such as "info" or "forward" or a branch to another list of selections. If the selection does nothing then its configuration is incorrect, and it needs to be assigned to what ever function you want it to perform such as ring a specific extension, divert off to another branch of prompts, ring the attendant, etc. My suggestion is to get the model number and software revision on the Applications Module ("NAM") and post your question with as much detail as possible to the Nortel forum on the Tech Talk board at Sundance Communications (http://sundance-communications.com/forum/). Lots of well-seasoned professionals hang out there and I've always received very good support from posting there - they are equally respectful of old-timers and noobs and I've found them to be very professional and helpful with everything from simple mailbox glitches to a set-relocation function gone crazy. I'd give it a try.
Sep 30, 2013 | NorStar Meridian M7310 Phone
M7310 voicemail
You need to access Admin programming in the phone system and navigate to Capabilities and change the Forward No Answer to the DN of the voicemail....if unsure of any of this you need to be calling your vendor that handles the system for all issues or questions.
Dec 06, 2012 | NorStar Meridian M7310 Phone
We have a Norstar - Meridian M7310 phone system. Today for some unknown reason when an incoming call comes in, the ring is two short rings rather that the "longer" ring that we normally have. I have...
The two short rings is telling you that the call is either a transfered call (answered by someone else and transfered) or answered by an auto attendant and transfered. Watch the ringing phone when the call comes in and see if the intercom LED blinks.
Bill C. www.dyna-tech.us
Mar 12, 2010 | NorStar M7310 Corded Phone
We have the Norstar Meridian (M7310) telephone system and would like to change after hours message. I cannot locate this information in our book. How do we change it?
To re-record greetings, enter Feature 983. if your system has 2 digit intercom #s your default password is 120000 if your system has 3 digit intercom #s your default password is 1020000. once you have entered the password you will see 3 selections you can make .use the three soft keys under the display and select AA (auto Attendant). next press greeting and greeting again. next it'll ask for the greeting number your probably working with greeting either 2 or 4 (you might want to listen to the greeting first). press record to start and ok when finished. dont forget to save the greeting or it will be deleted if you exit early. hang up when finished
Jan 08, 2010 | NorStar M7310 Corded Phone
Cannot change greeting when we are out of office. M7310 phone
Which greeting is it? If the AA greeting...try this.
But listen before you record, to make sure you are recording the correct thing.
http://dstech1.com/how-do-i-change-the-auto-attendant-greeting-on-my-nortel-voicemail/
Jul 06, 2009 | NorStar M7310 Corded Phone
I need to program the voice mail on our M7310 system
first press Feature 983. if your system has 2 digit intercom #s your password is 120000 if your system has 3 digit intercom #s your password is 1020000. once you have entered the password you will see 3 selections you can make .use the three soft keys under the display and select AA (auto Attendant). next press greeting and greeting again. next it'll ask for the greeting number your probably working with greeting 1. press record to start and ok when finished. dont forget to save the greeting or it will be deleted if you exit early. hang up when finished
Mar 19, 2009 | NorStar Meridian M7310 Phone
Automated Attendent
Norstar Voicemail for 6.0 or less
Programming must be done from any M7310, T7316, or M7324 model phone set.
To Log Into System Administration:
2. The display will show "LOG:", enter your login password
a. If your company extensions are 2 digits long enter "120000"
b. If your company extensions are 3 digits long enter "1020000"
c. If your company extensions are 4 digits long enter "10020000"
To Record the Company DAY & NIGHTGreetings:
1. Press AA
2. Press GRTG
3. Press GRTG
4. <Display> Greeting:
5. Enter 1 for DAY Greeting --- Enter 2 for NIGHT greeting
6. Press OK
7. Press REC to record.
Feb 25, 2009 | NorStar M7310 Phone
Night ring change the number of rings
Auto Attendant
Answer Lines
1 – Feature 983
2 – Log: Dial 1020000 (3-digit DNs) or 120000 (2-digit DNs)
3 – Press AA
4 – Press LINES
5 – Line number: Dial line number (001-xxx).
6 – Line:xxx Ans:No Press CHNG to AA if auto attendant will always answer theline. If a Night Service key will be used to activate auto attendant answering, leave Ans: at No.
7 – If line has been changed to Ans:AA, press * then press TABLE.
8 – If Table:1 is OK press RINGS. (Table 1 is the default greeting table. Change to a different table (1-4) if alternate answering is required on the line being programmed.)
9 – Rings:0 – Press CHNG, dial number of rings before auto attendant answers the line, or leave at 0 for immediate answering. Allow at least 2 rings if CLID is in use.
10 – Repeat for each line to be programmed.
Notes For Night Service Mode Auto Attendant Answering
If the auto attendant will only answer lines in night service mode, line answering should be set to No as per step 6 above. Using night service will cause the AA to answer lines immediately.
Feb 11, 2009 | NorStar M7324 Telephone
Norstar M7310 auto attendant problem
As far as changing the # of rings, that may be your phone company. Feature 983 will get you in to change to number of rings. It goes as follows:
Feature 983
System coordinator mailbox # and password
OK
AA
Lines
Enter Line Number
OK
Table
Rings
CHNG
Enter the desired number of rings
If after changing the number of rings the Auto atendant does not pick up at all, You have to call your phone company and set up the second delay through them. We had the same problem here.
Mar 27, 2008 | NorStar Meridian M7310 Phone
NorStar Meridian M7310 Phone Logo
106 people viewed this question
Top NorStar Lands Phones Experts
george  peters
george peters
dan4261
Level 1 Expert
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
