Question about GE 31GT740 31" TV
Screen is bright green, all channels. Sound is
Screen is bright green, all channels. Sound is fine. I can make out shapes and sizes.
    Genius:
  • 1,121 Answers
Is hv RGB circuit defective, needs to be repaired or CRT Tube is end of life.
Posted on Jul 11, 2010
Zenith plasma TV green screen problem
If you wish to get some details; check the site linked here. Pull up older posts.
Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Sep 21, 2016 | Zenith Televison & Video
The picture has a green tint to it on all channels
The color signal consists of Red, Green and Blue. Those three colors, at various degrees, make all the other colors on your screen.
If you have a BRIGHT green screen it's best you don't operate your set.
If it's just tinted green then there is a problem on the CRT (Cathode Ray Tube) drive board. Do check your "tint" setting and see if someone misadjusted it. If that isn't it then you need to have your set on an electronics bench and get an estimate for repair.
Apr 17, 2010 | Sony FD Trinitron WEGA KV-27FS100 27" TV
The tv was working fine the other day. I turned it out today and the screen just stays black. If I press the channel button up or down the channels change and sound comes out. The audio works fine, but the...
Turn it off/on a few times within a few mins each times.U get a flashes of picture about 10 to 20 sec?Than ur LCD inverter board is dead.Tries Websites Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board for the replacement.It usally a long PC board in shape.
Apr 16, 2010 | Polaroid FLM-3232 Television
Our 1991 RCA P52150CP rear projection TV has gradually been getting bright cloudy blue, slight haze around letters & shapes-(especially blue channel change headings) when first turned on and then it...
Hi
First check whether all the cables from your dishnetwork are fine and connected firmly.If yes then you'll need to pull off the front of the tv, behind the speaker grill there would be a panel. Remove the panel and check for a black box hanging over there. It has 6 controls on it, 3 are marked as focus and 3 as screen. You'll need to adjust the screen. If you turn these too high you can damage a tube. so we are doing real small adjustments. Turn the color off on the tv and adjust the red, blue & green controls up till you get a fine picture. Also adjust the focus until you get a clear picture.
And, if it doesn't resolve your issue then it is an intermittant blue picture tube, a bad blue driver transistor on the CRT board, a bad connection on the blue crt board, or a problem in the RGB coming from the video jungle IC. A set this age, most likely will run you about 300 to 500 bucks to have this problem fixed, unless it is the picture tube.
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Jul 03, 2009 | RCA P52926 52" Rear Projection Television
Hitachi big screen tv
if ths image is stuck on screen the solution should be white wash
Mar 01, 2009 | Hitachi 55HDS69 55 in. Plasma Television
Rear projection tv picture problem
Sounds like a tuner or Video output problem. What make and model set do you have.
Jan 09, 2008 | Televison & Video
Green Screen
Sounds like the green tube is shorted.
Oct 06, 2007 | Hitachi 50VS810 50" Rear Projection HDTV
I have the 51" rear projection (kp-51ws520) and problems...
The same problem?? Sounds like a green crt driver is defective or the green crt is bad.
Aug 14, 2006 | Sony KP-51WS500 51" Rear Projection...
GE 31GT740 31" TV Logo
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
