Question about Zanussi Refrigerators
Zanussie zfk56/52rf freezone not getting cold enough too warm
Bought recently 2nd hand and transported home upright let it rest but no the fridge/freezer doesnt seem to be getting cold enough on my zanussi ZFK56/52RF FREEZONE, is there anything that i can do as i would like to get working again as its a nice size one to use. help would be greatly received. :-D
  • 1122 Answers
SOURCE: How do I change the
first you have to see if you have all the same fitting on the other side,top and front,let me know and we can go from ther,mike
Posted on Sep 12, 2008
rylee_smith
  • 8619 Answers
SOURCE: item is secondhand and i was not given the book
Hi!
You can download the manual from this link, the manual is of a similar model---
Zanussi User manual
Please click on the above link and click on the link that says zanussi manual(150k)
Please ask for further clarifications.
Please rate this solution as fixya if found useful.
Thanks
Rylee
Posted on Mar 03, 2009
  • 193 Answers
SOURCE: zanussi freezone fridge freezer
well asuming you already thought to turn the thermostat down, i would check to see if you have a freon leak. with the fridge running, paint the coils with soapy water untill you see bubbles. mark that spot and dry off the area around it. generously apply electronics grade solder to the area where the leak is. (be sure you don't melt the copper and unplug the fridge first) then continue untill you have checked the entire length of coil. when all ieaks have been stoped recharge with recomended freon.
Posted on Aug 17, 2009
  • 4793 Answers
SOURCE: Possible Air Lock in Zanussi Freezone larder fridge
leaving it switched on should settle the unit down can take a day or two though.you should have fully defrosted the unit and dried out as best you can before use...so that any build up of semi defrosted ice was removed...hope this helps....
Posted on Feb 25, 2010
  • 713 Answers
SOURCE: why does the fridge part of my zanussi freezone
Hi,the problem you are encountering is as a result of the fact that the thermostat which regulates the cooling temperature in the fridge/freezer is bad hence there is no regulation of the cooling temperature in the fridge/freezer section, hence the food in the fridge freezes up.
The solution is to replace the thermostat of the unit,here is how you go about it;
1.You have to disconnect the fridge from the power source.
2.Locate the thermostat at the bottom of the unit,at the top left corner above the condenser.
3.Now you need to locate the wire ends or wire harness and unplug them.
4.Replace the thermostat,reconnect it back,put the back cover back and you have completed the job.
Take care of yourself
Posted on Jun 24, 2010
Everstar portable A/C unit MPM1-10CR-BB6 not getting cold
It seems low refrigerant issue need to refill refrigerant
Jul 26, 2016 | Heating & Cooling
I need user instruction for zanussi aquacycle 850
I suggest check right model and try looking in this link: zanussi/washing_machine
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Feb 09, 2012 | Washing Machines
How much does this model weigh?? (MSD2454GRW). Just bought one 2nd hand now need to transport it it home. Any advice on how to lift it into back of pickup truck??
its a model not made anymore but most weigh between 200 and 450. the more gadgets, the more it weighs. It is a side by side so id guess around 250-275, youll need a couple hands
May 18, 2011 | Maytag MSD2454G Side by Side Refrigerator
Freezer not cold
Check Compressor. If its too hot to hold your hand on it then
you may need a new compressor. Check condensor fan, and check
evaporator fan
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Aug 02, 2010 | GE GSL25JFPBS Side by Side Refrigerator
Transported the refrigerator on it's side and when we got to our destination, the ref doesn't work. doesn't get cold
you should have let it"rest", upright for 24 hours before you switched it on to let any gas bubbles settle.leave it closed and hopefully it will go back to normal soon....
Jun 03, 2010 | Refrigerators
Feb 25, 2010 | Refrigerators
Cool down period for plasma TV for transport.
I believe 20 minutest just enough. But when you bring it back from cold outside to your new home it have to stay/warm 2-3 hours before you plug it in.
Dec 18, 2009 | Pioneer PDP-5020FD 50 in. Plasma HDTV
Red alarm light is on on Westinghouse upright freezer
Most probably during transportation either the coolant(previously freon gas) may have leaked out so the pressure on the cooling pipeline causing the red alarm because the compressor will overheat if the fridge is kept running at very cold thermostat readings and no effect of cooling the fridge will ultimately result in the compressor getting burnt. However fist have look at thermostat setting knob which could have loosened during transportation and just pushed into the spindle without knowing the correct angle, thus even though it looks as if on high cool but could also be the lowest setting..........sodeep
May 19, 2009 | Westinghouse WRS3R3EW 33" 22.6 Cu. Ft....
Freezer quit working
I suspect when you lifted or moved the freezer, you tilted the compressor such that the oil washed out into the refrigeration lines. Common when people tilt refrigeration equipment the wrong way.
Jan 30, 2009 | Freezers
The best ways to move my 55 inch Mitsubishi TV to another home?
Move it with an appliance hand truck and do not lay it on it's side. When transporting, always keep unit standing upright. Good Luck
Aug 14, 2007 | Mitsubishi WS-55819 55" Rear Projection...
Refrigerators Logo
Top Zanussi Refrigerators Experts
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a Zanussi Refrigerator Expert? Answer questions, earn points and help others
