Question about Dell Dimension 5100 (D51L1) PC Desktop
Unable to turn off computer except at the strip
Unable to turn off computer except at strip.
Computer indicates "Update 1 - 1, don't turn off
computer".
Dell Dimension 5100
    Genius:
  • 1,121 Answers
Is important update perfoming, or virus Malware spreding (trying to acess bios)
Posted on Jul 11, 2010
Compaq starts on pluging power indicates red signal and stops few second
To help you troubleshoot the issue for unable to start the computer, there can be several reasons. Please find the link given below and follow the step-by-step instructions given on it:
http://answers.microsoft.com/en-us/windows/forum/windows_vista-update/unable-to-start-computer/1fbecac8-06a0-42b1-a7fd-0becc2687f31
Also find the additional link given below that can be useful:
https://technet.microsoft.com/en-us/library/bb457123.aspx
GuruAid.com
Jun 27, 2016 | Compaq Computers & Internet
Dell Bios Updater. Unable to see current version and will not update BIOS.
Ensure that the AC adapter is plugged in, the main battery is properly installed, and a network cable is attached. Turn on the computer. Locate the latest BIOS update http://www.dell.com/support/drivers/us/en/19/DriverDetails?driverId=R301502
Feb 04, 2013 | Dell Studio 1555 Laptop Computer 15.6-Inch...
I have a Toshiba Excite 10 AT205 and I can't seem
Have you restarted your computer after turning off the sound via the control panel? Restarting it should do the thing except to some issues that might be happening inside your computer.
When you restart your computer, it usually shows up a notification the settings have changed. That's the sign that your computer is detecting the changes you've made and the typing sound should be turned off completely.
However, if restarting it won't fix the problem. I suggest you update the driver of your computer. Outdated drivers cause problems. However, finding the right driver for your computer is such a headache. Don't worry though because there is one software that I personally use in my computer and it does the trick of finding the latest updates, driver back ups, etc.
It's a must utility for Windows computer. It is good for fixing drivers, updating, and backing up. You don't need to find the drivers for your computer because it does the trick. It finds updates and what you just need to do is almost nothing at all. I'm using it in my computer. This software is called RadarSync. Trust me, it removes all driver related issues in your computer.
Nov 14, 2012 | Computers & Internet
My speakers won't turn on at the outlet that my power strip is plugged into, nor when plugged into any of the outlets on the strip, however the computer and monitor are running off the power strip and...
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar:
if his does not fix the problem
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps
Jul 01, 2011 | Logitech X-530 Computer Speakers
Can anybody help how to flash bios into a acer aspire 3680 using the usb?
Even with the automated (windows-based) BIOS updating software, this is not a small matter. I would make certain that you need the update for a specific problem before proceeding. Also realize that a failed or interrupted BIOS update may ruin the BIOS chip resulting in a much more costly and difficult repair. Don't jump into any BIOS update without doing your homework, making sure it's necessary, and make sure you get the correct BIOS for your PC. And make sure you don't interrupt the power once it starts! That will brick your computer for sure!
Jun 29, 2011 | Acer Aspire 3680 PC Notebook
I need to have version 6.10 for my psp but it is only version 3.5 a few days ago I purchased little big planet and downloaded it to my psp but now I cannot play because I don't have the right version...
Calm down it is simple. If you have intermet on your psp, then go to system update. Select update by internet. If you don't have wireless, then you have two options from here
1 Insert a game that is very recent(made in 2010-2011), do the same thing as before but hit update from media
2 Download the software from your computer, and with a cable that has miniUSB on one side, plug the psp up to your computer. Turn on your psp, and then copy the downloaded update file to which ever drive you psp is mounted to
Thank you for your time, Good luck and I hope it works
Jun 05, 2011 | Video Game Consoles & Games
Any one help my brother display error 48, init unable 48, what are the things that i have to do?
There are several issues that pertain to this code, including a service update. If your printer is still under warranty – visit your local ASC, find one here, this issue is covered! First off, the Service Update, the encoder strip needs to be cleaned with a lint free cloth. The encoder strip is responsible for relaying the position of the print head to the main pcb. If the encoder strip gets dirty, many different problems can occur. The encoder strip is exposed, which allows grease, paper dust, finger prints, ink, etc. to get onto the encoder strip. (The white strip when you lift the scanner cover)
If the machine still errors, the encoder strip needs to be replaced – Part Number LS4467001
If the machine still errors, replace the carriage PCB assembly – Part Number LS6543001
If the machine still errors, replace the Printhead – Part Number LK3211001
If the machine still errors, replace the Main PCB assembly – Part Number LT0284011
THANK YOU FOR USING FIXYA! – DON’T FORGET TO RATE OUR SERVICE!
Jan 21, 2010 | Brother DCP 165C Compact Color Inkjet...
Dell Inspiron 2200 Charger Malfunction
Try to turn off the computer and remove the battery from the bottom of the notebook. Turn on the computer with just the charger plugged in. If it doesnt turn on. you may have a bad power port.
If it has no power/charging issue since that happened except that the indicator light doesnt turn on when you plug in the charger, you may just need a bios update. Click here. That's the bios update for the inspiron 2200 from dell's website. You should have at least 30% charge on the battery and the ac adapter should be plugged in so you can run it. The computer will restart and will come back normally after this. I'd suggest that you backup your files before running this.
Sep 28, 2008 | Dell Inspiron 2200 PC Notebook
My HP computer keeps crashing
Could be an overheating issue. Open it up and clean it out with canned air. Blow all the dust out of the fans and heat sink.
May 20, 2008 | Compaq Presario 5000 PC Desktop
Unable to install KB928366
update the OS to SP2. more stable and secure.
Nov 14, 2007 | Microsoft Windows XP Professional With...
Dell Dimension 5100 (D51L1) PC Desktop Logo
55 people viewed this question
Alun Cox
