Question about Pitco Frialator SG14 Deep Fryer
My pitco gas frialator oil leak in tank .how can
My pitco gas frialator oil leak in tank .how can I do?
  • Pitco Frialator Expert
  • 683 Answers
You need to identify where the leak is coming.
If the leak is on the fry tank, best way to address it is to replace the oil tank.
Check the serial number of the unit with leak on fry tank, verify if it is still under warranty at PITCO web on http://www.middleby.com.
Posted on Jun 06, 2011
  • 3 Answers
Is not the tank leaking, is the drian valve dripping
Posted on Jul 21, 2013
How to check gas pressue on pitco frialator
To check manifold pressure, there is a pressure tap on the manifold on which the burners are mounted. Remove the tap, hook up your manometer and turn the fryer on. Be sure you have no gas leaks once you reinstall the plug. The gas pressure should match what is on the data plate.
Apr 12, 2013 | Pitco Frialator 35C Deep Fryer
Hi I have a pitco sg14 fryolator. At the time of firing off main burner there is a false ignition at start of heating cycle of oil in tank and there is a woosh sound that shakes front door so basically the...
for the latest design of pitco frialator, the manufacturer added what they called the self-cleaning burner system.during start-up, ignition is delayed so that dust accumulating in the burner face will be removed once the gas build up on burner chamber ignites, it creates a weak explosion like sound.the next time you hear that during start up, the unit is cleaning its own burner, no need to worry.
Mar 28, 2011 | Pitco Frialator SG14 Deep Fryer
I have a Pitco Frialator 35CS Deep fryer that is leaking natural gas leak inside gas fryer door just above gas valve assembly the leak is bubbling through each of the 3 flues above the gas valve any help...
Opening fryer door during operation does not correct gas leak problem.
If there is gas leak on your fryer's system, you have to fix the leak or replace parts if necessary.
You can download parts, operation and owner's manual at pitco web on http://www.middleby.com
Regards.
Jan 16, 2011 | Pitco Frialator 35CS Deep Fryer
Our staff cleaned the fryer last night and left the pilot on without filling the oil. . The fryer was with no oil and pilot on overnight. Will it lead to problems or we have to take corrective action.
If the main burners didn't light there shouldn't be a problem. If the main burners came on there could be some damage to the tank but there is no corrective action that can be taken. If damage was done it will usually leak cooking oil when filled. Was the gas valve turned to "pilot" or "on"?
Dec 12, 2010 | Pitco Frialator SG14 Deep Fryer
Pitco fryer
Try removing the oil and boil out the fry tank.
Fryer cleaning manual is downloadable on PITCO site at http://www.middleby.com
Jul 19, 2010 | Pitco Frialator SG14 Deep Fryer
Just purchased a used pitco frialator model no.145
Visit http://www.middleby.com and go to PITCO web, you can download there installation, operation and user's manual which you can use as reference.
Apr 10, 2010 | Pitco Frialator SG14 Deep Fryer
Pitco fryer leaks when oil is hot but can't find where is leaking from
Hi, I have the same issue, did you manage to locate the leak? I think mines comes from the heat tubes.
Dec 17, 2009 | Pitco Frialator SG18S Deep Fryer
35C+ Pitco Frialator overheats oil what is likely problem
I am having the same exact problem and I am assuming either the tstat or high limit units have failed.....
Jun 04, 2009 | Pitco Frialator 35C Deep Fryer
Pitco sg14 commercial frier
id say change the valve that runs the gas has to be leaking
Feb 15, 2008 | Pitco Frialator SG14 Deep Fryer
Converting a pitco frialator from natural gas to propane
you need to change the pressure regulator,burner orfices and possibly the gas valve.goto northernparts.com and type in the model of the fryer for propane
Dec 12, 2007 | Pitco Frialator SG14 Deep Fryer
Pitco Frialator SG14 Deep Fryer Logo
759 people viewed this question
Top Pitco Frialator Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Paul Carew
Treefrog15
Treefrog15
Are you a Pitco Frialator Kitchen Appliances - Other Expert? Answer questions, earn points and help others
