Question about Garden
Yardman 21AA413B729 gearcase. Already have the manual. It doesn't show the breakdown of some of the gear assemblies. Individual parts of 'gear assemblies' are not shown. There 2 spacers or collars that are not shown. One is 1.5" id 1.755" od .61" thick. The second is 1.518" id 1.988" od .71" thick. I know they go in the 'gear assemblies' but cant make them look right.
mistersony
  • 320 Answers
SOURCE: 61 inch sony LCD projection
Optical block or LVDS cable You need a tech to tell you for sure, have a tech look at it
Posted on Oct 18, 2008
  • 398 Answers
SOURCE: reassembling blades on hedge trimmer
the blades are stuck , i spray my trimmer with wd40 before every use to keep them juicy you should too. also sometimes if you hit a large stick it will put a divot in the blade cause ing it to stick. as for putting it together, find some one who can do it without directions. but when you use them next make sure you soak em good with wd40 or something if you dont i guarantee they will always stick. wd40 willl not hurt any shrubbery, as ive been doing it for years.
Posted on Feb 26, 2009
Just_Bobz
  • 448 Answers
SOURCE: need illustrated parts breakdown for 2000 ford
Go to dealer and get print out from parts department
Posted on Aug 09, 2009
  • 3 Answers
SOURCE: connecting the throttle assembly to the governor
see http://forum.doityourself.com/outdoor-power-equipment-small-engines/384248-spring-locations
Posted on May 26, 2010
  • 2309 Answers
SOURCE: hIT A CURB WITH THE
the repair shop probably is listed in assembled units like bearing and hub unit whereas the dealer lists the parts separately, hope this helps
Posted on Aug 06, 2010
The lip of the planetary ripped off and I am having a trouble replacing it for a Kitchen aid K5-A mixer
The planetary is replaced by removing the chrome drip ring from the housing and then knocking the through pin out that holds the planetary hub onto the shaft from the gearbox. In New Zealand the planetary comes as individual parts not an assembled unit so will certainly look different to the full assembly you take off. The lip of the planetary ripping off is most likely caused by one or more of the 5 gearcase screws under the planetary coming loose and rubbing. Check the other 4 (total) screws at back and middle of gearcase as well.
Nov 23, 2013 | Food Mixers
Hi guys.. I have a 1993 Jeep wrangler YJ Automatic column change. I need to know how to take the complete cowling off so that I can get to a tiny piece of metal from the steering wheel assembly out that I...
A body shop may have the info you need as they/their parts manual should show breakdown for ordering parts but dealer should have the same breakdown as the parts are ordered from them anyway---you may have to schmooze somebody to get a Pix
Jun 11, 2017 | Jeep Wrangler Cars & Trucks
How to assembly makita hr2475
If you go to the Makita website, http://www.makitatools.com/en-us/Modules/Home/Default.aspx, or to http://www.ereplacementparts.com and search on your model number you can see a parts breakdown that shows an exploded view where the parts go. It doesn't tell you the sequence of assembly but will get all the parts in the right place.
Mar 05, 2012 | Makita Drills
Drive belt diagram for mtd yardman 42"
i need a diagram showing for a 20hp yardman tractor model number 13AT605G755
Dec 07, 2010 | Mtd LAWN MOWER PART # 983-04162A-0638 DECK...
How do I remove the armature and gear from a skil saw hd5660
you would have to completely disassemble the saw, I suggest going to ereplacementparts.com and downloading a breakdown before starting. The motor housing would have to be removed to get to the armature and on the other side the gearcase cover would have to come apart for the gear assembly. If you handy with tools and can read a breakdown it should not be that difficult just take your time. let me know if you need more help.
Jan 21, 2010 | Skil Saws
Need To buy a work shop service Manual yard
Mtd list a manual #770-10136d but it may be just a owner's manual.
Go to www.precisionope.com and put your information for a parts breakdown.
Sep 30, 2009 | Mtd Products Yard Machines 158CC Tiller
How do I assemble 1988 jimmy steering column start to finish.
Go to the dealer and ask the parts dept if they will print you a parts breakdown sheet from the factory parts manual, they are great for this kind of repair, really shows every little detail, don't shut me down on this suggestion, I have allot of experience doing these column repairs and the factory breakdown parts sheet is the best source I have come up with in 30 year's of being a mech.
Nov 07, 2008 | 1988 GMC Jimmy
Garden Logo
47 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
