Question about Audiovox AVT-1475 13" TV
Sound won't work
Since hubby accidently plugged the DC cord into the rear speaker outlet, the sound won't work. The picture still works fine. We tried to get external speakers to plug in, but, they didn't work either. How do I fix the sound?
    Genius:
  • Audiovox Master
  • 1,689 Answers
Most likely the audio output stage in the TV is blown!
You will have to bring the set in for service. Most likely they will have to change audio output IC and some support components.
Jerry G.
Posted on Apr 19, 2008
My rear speakers are suddenly doing this buzzing sound. I tried different speakers and different cords, and it seems to have come down to the speaker outlets. What could be the problem ?
External speakers ? try them on something else.? Internal speakers ? sounds like an issue with either the software...OR a dry joint on the board?? What leads are being used? check everything you can in order to eliminate the problem.
Jun 29, 2016 | Audio Players & Recorders
Sentry 2.1 surround sound speaker system. i have my rca cords plugged in to my tv, but i only get sound from my tv, nothing out of the speaker itself. it only works when i have my headphone jack into
Most televisions have a setting that controls whether the TV uses its internal speakers or sends the sound to the audio out jacks for an external amplifier or speakers.
Try going through the settings menu and follow through the audio/speaker selections and confirm that the TV is set to use external speakers.
Best Regards,
Sep 01, 2017 | Televison & Video
Amana refrigerator sparked by plug and now won"t turn on even when plugged into another outlet with extension cord should i repair or replace?
i am in the uk so i dont no if this will sound right,but have you tried changing the fuse in the plug of the fridge? make sure you put the same size fuse back in.
Oct 12, 2017 | Kenmore Refrigerators
** TV won't turn on.** No picture or sound. Please Help !
If the red light won't come on it is not getting power.First,try plugging it in to a different outlet,or unplug one of the gadgets you know is working and plug the tv in there.You are simply switching.If you know that there is power coming from the outlet and it still won't come on then you'll have to check the cord;don't go much farther than that without expert help.
Apr 04, 2012 | Televison & Video
Built in speakers not working
Are you using external speakers? or internal?
EXTERNAL SPEAKERS: If your are plugging speakers into your headphone jack and they dont play, but you plug headphones into the same port and they work fine.. then it is the external speakers.
INTERNAL SPEAKERS: But if you are using the speakers in the laptop, then your speakers are probably bad. Try some software settings, but probly just bad speakers. Could also be that the speaker cord inside the laptop came unplugged from the motherboard. In which case you would have to take the laptop apart and plug it back into the motherboard.
Good Luck.
Sep 08, 2009 | HP Compaq nx6115 Notebook
Sound but no picture. menus work.
I had the same problem. In the menu, the image button was grey, and could not be hi-lighted, and the screen stayed blue. I was using the AC power cord. I plugged in the DC power cord instead, and it "woke" the unit up. I switched back to the AC power and it works fine. If you don't hve the DC cord that came with the TV, try andy 12 volt dc output cord with a positive tip.
Jul 12, 2009 | Polaroid 15'' HDTV Monitor FLM-1511
I moved, and now my speakers won't work
check for the power button is on behind the woofer or speaker,if ur speakers does not have switch hten select the volume control optin and click the properties and check the sounds by clicking the speaker images in that window.if u have problem again,askme through fixya again.
Aug 16, 2008 | AOpen MS-810 Computer Speakers
SoundDock produces only harsh crackling sound
Yeah i had that same problem. You know the chord? The cord you plug in from outlet. The square cord you plug into your speakers.. yeah the "DC outlet" is supposed to be UP. if you have it the wrong way in there it wont work and will make a crackling sound.
Apr 30, 2008 | Bose SoundDock Digital Music System for...
TV is DEAD without any prior symptoms
opening the tv you will see a fuse  it is surely open - you have to chenge with the same type and rating- pay attention to make this
just after did you disconnect the pewer cord from ac outlet- delfo
Mar 21, 2008 | Televison & Video
Toshiba 9" TV/VCR W/CAR AC/DC - No power when on battery
I would check on the inside for a disconnected wire or loose connection at the Dc imput if it still works on ac. You can most likely get a service manual at http://www.servicemanuals.net/ if the wires are intact on the DC imput and the jack itself fits secure to the adapter. Hope this helps
Oct 24, 2007 | Toshiba 9" TV/VCR W/CAR AC/DC COMBO...
Audiovox AVT-1475 13" TV Logo
91 people viewed this question
Top Audiovox Televison & Video Experts
Jaime Hernandez
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
