Error: NAND File System Fail Format File System
  • Kaitlyn Jones
    Kaitlyn Jones Apr 20, 2008
    no it is an insignia model #NS-DV4G
  • art2938 Jul 19, 2008
    I have a Samsung MP3 player. It was working fine up to yeasterday! I left it in my car and it was hot. When I turned it on , it says " Format NAND file system" Samsung US does not have this modle and could not help me out!
    How can I format NAND file system?
    A
This ipod is a apple ipod 8g. It was not listed in the list.
Posted on Apr 20, 2008
How do I transfer from nand to sd
Hi
If your SD card is not recognised there are possibilities:
1. The manual - I'l give the link later in case yours is mislaid - only mentions "Micro SD" up to 32Gb. Sometimes these cards can be the SDHC category and these are not always accepted in devices designed for SD only. They look identical so make sure yours doesn't say SDHC.
2. The file format on the card can be significant. It needs to be a format compatible with the phone. If you have no other data on the card, it might be easiest to see if the phone will format it.
3. Of course it might be a faulty card - can you test it elsewhere?
The link for the manual mentioned above is here:
Proscan Media Tablets eBooks ReadersInstructions Manuals Quick Start...
Its about 15th down the list and will download direct to your computer.
With regard to downloading from nand to SD card, is this essential? If you have a micro USB to normal USB, then you should be able to use a computer to take data from the nand. The nand would show up as a drive in "My Computer".
Hope this is helpful, if so would you please register that with Fixya
Cheers
Jan 04, 2015 | Proscan PLT7223G 7" 4 GB Wi-Fi Black...
Xbox NAND format was missing
You can't get it back unless you do data recovery, which is unlikely to work as you have most probably reinstalled an new operating system on your PC and overwritten the saved bin file.
Alternatively boot the 360 into Xell with the ecc file, get the CPU key and the lock down value. That will be the amount of "F" you see after the CPU key. Create a retail NAND with J-Runner. It's not very difficult to do. You will need a donor KV and SMC file the same as your model.
(http://www.xpgamesaves.com/topic/83174-jtagrgh-how-to-build-a-new-nand-when-you-lost-everything/)
Jan 16, 2014 | Microsoft Xbox 360 Console
What is Error 71 and 79 on my xbox360
E71 is a dashboard update error. Try to turn off the console, hold the sync button and continue holding while turning on the console until it boots fully to dash. This will clear the cache and any failed updates.
E79 is a broken HDD error. Try removing the Hard drive. It also can be a bad .xex file.
Both of these are also caused when you attempt to modify the NAND.
If you have modified it, to fix it you will need to flash it back to the original NAND.
Jan 06, 2010 | Video Game Consoles & Games
I was given a used ns-dv2g insignia mp3 and cleared the downloaded material to start anew. Afterwards, the screen says "nand file system fail format file system!! I've tried the solutions posted, but to no...
You may reset the unit by inserting a pointed object, such as a paper clip, into the reset port on the bottom of the unit. A copy of the owner's manual will help identify the location of the port. I hope this helps.
Aug 21, 2009 | Insignia NS-DV2G MP3 Player
Frozen and memory messed up
try resetting it
if that fails try taking the battery out for a few seconds to clear the error out
still no luck consider it dead and buy new one
Aug 03, 2008 | Insignia NS-DV2G MP3 Player
Can u help pls
1) Hold the power button (slider) in the on position for about 15-20 seconds to force the player to turn off, if it's already on.
2) Hold the menu button down and simultaneously hold the power button (slider) to the on position.
3) Do not let go when the device turns on. You will then get a screen message in black and white that reads (with a typo):
WARRING !!!
NAND FLASH MEMORY INITIALIZE......
"WARRING !!!" will appear in red (and probably should read "WARNING". You will have the options of "No" and "Yes".
4) Choose "Yes" to re-format your device.
Jul 09, 2008 | Insignia Sport MP3 Player
Help fix this
WARRING !!!
NS-xV24 Insigna Pilot
WARRING !!!
Jun 24, 2008 | Insignia Pilot MP3 Player
Error Message? "Press ENTER to configue NAND Press ESC to cancel"
With you 500 turned off press nav + power; then change the numbers 00 in 95 by using the joystick and and then press the joystick itself; accept what proposed.
after turning the gps on again and pressing enter the NAND will be configured and your gps will become in order again. if necessary, in usb file transfer mode, reload the basemap in the directory background maps
May 24, 2008 | Magellan eXplorist 500 GPS Receiver
Cant dectect the player
WARRING !!!
Feb 07, 2008 | Insignia NS-DV2G MP3 Player
781 people viewed this question
 Grubhead
Grubhead
