Hi
Thanks for using FixYa. To start with unplug the
unit and take the back off then check the power supply board for any
bulged/swollen components. Also check the controller board which is the board
located next to the power supply unit. The orange light indicates that the
power is coming to the unit however, as its not working so the issue is more
likely the power board. Hope you know that a plasma TV is a very hard working
device. It is working harder than any TV that has been built before, and as a
result it produces a lot of heat. 75% of technical problems in plasma TV's are
caused by overheating problems. All this is only recommended if you have
electrical expertise and/or know how to solder/re-solder components as these
units contain high voltages even when switched off. Please do accept the
solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
