Back to:
Tags:
Jensen JER-321 Remote Control
Programming my remote ? (by 2 users)
posted by crowcana on Apr 19, 2008
programming my remote ?
Comment by crowcana, posted on Apr 19, 2008
how to config the remote with my tv ?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by abfamily, posted on Jun 09, 2008
My remote was working on my small primus tv, but now it has stopped. I checked another tv and the remote is working on that one, but not on the one that it gets used with all the time. I have the jensen 321 model remote control and a small primus tv. I suspect the code has been knocked out for some reason and can't find the code for it.
Can you help.
Thank you AB
Solution #1
posted on Jun 21, 2008
Not Rated (0)
superdaintyk
Rank:Apprentice Apprentice
Rating: 100%, 1 votes
These are the instructions to re-code the remote:
1.Manually turn on the component you want the remote to control.
2.Press and hold the component key (TV, VCR, Etc..) you wish to program. The illuminated ON-OFF key turns and remains on.
3.While holding the component key down, press and hold the ON-OFF key. The illuminated ON-OFF key turns off.
4.After holding down both keys for three seconds, the illuminated ON-OFF key turns back on.
5.Release both keys. The illuminated ON-OFF key remains on.
6.Press and release the ON-OFF key repeatedly until your component turns off. Wait four seconds between each keypress. Each time you press the ON-OFF key, the illuminated ON-OFF key blinks and the next code in the list is sent. This process continues until all of the codes in the Code lists have been searched. If your component turns off, you have found the correct code.
7.Once you have found the correct code, you must save the new code by pressing and releasing the STOP key. The illuminated ON-OFF key turns off. You must press the STOP key to save the code or the correct code will not be stored.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on programming my remote ?:
I don't want to Accept this solution
Can you Help with these Remote Controls problems?
alguns programas de minha tv hitachi 32cx33b , est?£o...
heeeeeeeeeeeeeeeeelllllllllllllllllllllllllppppppppppppppm...
my reote does not have set up
i lost the codes can someone send me the codes for an...
how to congig remote with my new tv ?
Loading problems.
Repair Service
Find Remote Control Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
