Question about Frigidaire Professional Series 24 in. Built-In Dishwasher Dishwasher
Smells very bad inside - Frigidaire Professional Series 24 in. Built-In Dishwasher Dishwasher
Smoke, burning smell coming from my machine. Door wont open and clothes and water inside is black
the bad smell you refer to is a smell of the electric motor burned out have the motor replaced the machine should be ok
Nov 23, 2017 | Whirlpool Washing Machines
Chemical odor...
HERE ARE 10 EFFECTIVE WAYS TO REMOVE THE BAD SMELL:
1. CharcoalCharcoal is on top of my list as it is one of the best absorbent agents that can absorb and soak up the bad odour. Charcoal is also widely used as water filters and in most odour removing commercial products. You can put a medium-sized chunk of charcoal inside your smelly refrigerator for instance, and leave it there for a couple of days. You will notice that it can effectively remove the bad smell.
2. Baking SodaBaking soda is also a good absorbent. Put a generous amount of baking soda in an uncovered container (the size of the container depends on the size of the confined area) and leave it for several days. Remove the baking soda and replace it with new one and leave it for a couple of days. Continue replacing the baking soda until it has cleared the bad smell.
3. Lemon or Lime PeelJust put some lemon or lime peels into an uncovered container and leave them inside the confined area for a couple of days. The citrus smell will naturally replace the bad smell.
4. Pandan Leaf (also known as Pandanus or Screwpine)It is easy to get pandan leaf in tropical countries as it is widely used in Southeast Asian cooking to add aroma to dishes. Its pleasant aroma also acts as natural air freshener. Just take a few strips of the pandan leaves and tie them into knots. Place the leaves inside the confined space and leave them until the leaves withered or dried up. Replace the leaves regularly until the smell goes away.
5. Vanilla Essence Pour several drops of vanilla essence on a couple of cotton wools. Toss the cotton wools inside the confined space such as your wardrobe. Leave them for several days and you will notice that the area smells nice.
6. Mint Extract If you favor neither the smell of citrus nor vanilla, you can perhaps use mint extract instead. Pour several drops of mint extract on a couple of cotton wools. Toss the cotton wools inside the confined space and leave them for a couple of days.
7. Fresh Ground CoffeeGround coffee has a nice, crisp natural aroma. Just put about a cup of ground coffee in a flat, uncovered container. Place the container inside the confined space for several days. If the bad smell is extremely horrible, put more ground coffee. The area will smell of fresh coffee for many days.
8. Tea BagsIf you don't like coffee, you can use tea bags instead. Just place 2-3 tea bags inside the confined space. The tealeaves in the bags will not only absorb the bad smell but also will release the natural aroma of tea.
9. Orange and ClovesGet an orange and poke it with sharp objects like needle or fork to form small holes. Place each of the cloves inside these small holes until most of the orange surfaces are covered. It may look like a hedgehog with the cloves jutting out of the orange fruit. Leave it in the confined area for a couple of days. The area will smell nice with the said combinations.
10. Old Newspaper and Slices of BreadOld newspaper and slices of bread also work wonders in absorbing the bad odours particularly inside the refrigerator. Just place some crumpled old newspaper and two slices of bread (uncovered) inside your refrigerator and leave them for two days. Replace them (especially the bread) regularly until the bad smell is removed.
You can also use the combination of any of the above tips together, to effectively remove bad smell. Try those tips and you will say goodbye to bad smells forever.
Goodluck,
Please don't forget to rate the solution.
Mar 29, 2008 | KitchenAid Superba KSCS23IN Side by Side...
There's a gas smell inside the car.
Check your muffler for holes. The gases can enter the passengers cabin and it can smell like gas, specially if your car isn't burning gasoline completely due to bad tuning.
Oct 26, 2012 | 2006 Chevrolet Cobalt
Odd odor coming out of dishwasher upon opening it. Smells like rotten milk. What is the best cleaning solution?
After a dishwasher is installed the hose rarely comes to mind - unless a problem occurs and a repair person comes out to inspect the job. If the hose was installed improperly, or if it is lying in a position that does not let it drain, stagnant water will create a bad smell. Examine the hose that is probably inside the kitchen cabinet beneath the sink. If the hose is lying in the bottom of the cabinet, it is probably full of water. A film begins to form inside the hose and the odor begins to grow. The next time the dishwasher is used, the stagnant water ends up on dishes, and in the meantime it can cause a bad smell inside of the dishwasher. Hang the hose at an angle on supports in the back of the cabinet. This alone might get rid of the bad smell inside the dishwasher.
Check the Seal
A dirty dishwasher seal can be a source of a bad smell. Before deciding the dishwasher needs to be replaced, check the seal - especially at the bottom. Old food and grime builds up in these areas and can cause a particularly bad smell. Clean it with a solution of diluted bleach and hot soapy water. One teaspoon of bleach for each quart of water is sufficient to kill germs and the odors they create.
NB I decided to add a little bit of vinegar to the machine after I unloaded it. Sure it would smell pretty strong for a while but then the smell would dissipate. Voila! For two weeks now my dishes have not smelled whatsoever.
Jun 23, 2011 | Maytag MDB6709AW Builtin Dishwasher
My widows fog up heavy on the inside when the defrost heats up
This is usually a good indication of a small leak in the heater core. Does it also smell really sweet?
Dec 14, 2010 | 1995 Honda Civic
Putrid cheesy smell eminating from the back of our Fridge-Freezer
To eliminate bad smells from just about anything..place an open saucer of unused coffee grounds in the space. Coffee will stop any bad smell!
Mar 14, 2010 | Liebherr KES4260 Refrigerator
Bad smell inside dryer
that's because it's brand new. See if it goes away in a month. After a load has dried leave the door open for a bit. What does it smell like?
Feb 27, 2009 | Kenmore Dryers
Bad Smell
this is caused by a build up of old detergent and limescale.there are some industrial strength descalers around.wpro descaler is one.add the sachet to the drum with no wash load.pour in a kettle of hot water(not boiling)and leave for thirty minutes.then put washing machine on a 60 degree cycle and allow to run right through.you will need to repeat approximately every three months
Nov 16, 2007 | Hotpoint Aquarius WMA42 Front Load Washer
Bad smell inside my washer
Washer Magic Its a special cleaner they sell at most appliance retail stores (probably not walmart or lowes) please rate my advice>>>
Oct 02, 2007 | Kenmore 23822 Top Load Washer
Bad Smell
Make a boil wash (with no clothes and detergents) put in the powder's drawer a cup of bicarbonate of soda. It should clean the machine and remove out the bad smell. Good luck!
Aug 31, 2007 | Bosch Classixx WFC 2465 Front Load Washer
Frigidaire Professional Series 24 in. Built-In Dishwasher Dishwasher Logo
394 people viewed this question
Top Frigidaire Dishwashers Experts
Carmen Mikulic
Mike
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
