Question about Frigidaire FDE336RE Dryer
Very loud squeaking noise - like a noisy loose fan belt on a car.
The squeaking/squealing noise has gradually gotten worse. It wasn't a all of a sudden happening, it happened over time. My dryer is downstairs in my garage. The squeaking is SO loud I can hear it upstairs in my house (I have a 2 story condo). While the dryer was off I lifted the top up and sprayed a silicone lubricant all over the drum thinking that might help. It didn't. A few days later I sprayed the drum again with WD40. Didn't help. Then the drum stopped turning alltogether. The dryer would run and heat but the drum didn't move. Now it's moving again but the horrendous loud squeak is still there. Needless to say I'm hanging clothes up to drip dry and not using my dryer at all until it is either fixed or replaced.
    Top Expert:
  • Frigidaire Master
  • 75,066 Answers
The dryer needs to be rebuilt, new drum belt and drum rollers to cure this problem.
Posted on Mar 24, 2017
  • 883 Answers
SOURCE: squealing!!
the noise is coming from the drum axle bushing that allows the drum to spin on it's axle. Gain access to the rear of machine and apply some high temperature grease that is found in automotive parts stores to the bushing. run it while observing spinning drum at rear for any possible other problem where squeal can be found such as drum slides.
Posted on Dec 26, 2007
SOURCE: LOUD SQUEALING NOISE
Most likely the rear drum bearing is worn. There's a "ball and socket" arrangement that supports the drum at the rear and a repair kit for it. Part #5303281153. Should run around $25.fe7bd93.jpg
Posted on Dec 28, 2007
TheMobilian
  • 8220 Answers
SOURCE: The dryer is making a terrible squeaking sound.
That my friend is the sound of metal to metal on the rear drum bearing. The drum has a ball mounted on the rear of it affectionately known in the biz as a trailer ball. It rides in a grease slathered plastic bearing. The bearing is mounted with a metal bracket. Over time the plastic will wear down and the ball will begin to meet the metal mount.
The mount will begin to act like a guillotine and actually eventually cut the ball off 85a72c7.jpgand the drum will fall into the heating element and the resulting massive breakdown only occurs on a sunday night. LOL
Posted on Jan 20, 2009
jumptrout51
  • 3361 Answers
SOURCE: squealing dryer
The dryer drum support on the rear of the drum is worn and must be replaced.
It is a ball and cup design. It is worn out.
Posted on Feb 21, 2009
  • 221 Answers
SOURCE: Dryer making loud squeaking sound
Try checking the glide wheels under the barrel they may need to be cleaned and lubed.
Posted on Mar 11, 2009
My 2001 xterra started making a weird sound between 20 and 35 mph. It sounds like there is a leak in some pressure system.
Common Car Noises and Their Likely Causes Noise More Details Likely Cause Fixing It Clicking noise while turning Starts faint, gradually becomes more noticeable until very loud Failed outer CV joint (constant velocity joint) due to torn boot (most likely) or old age Replace either the whole axle assembly (recommended) or the outer CV joint Water pump noises Difficult to diagnose because of water pump's location Noise usually caused by damage to the bearings in failed water pump Only cure is replacing it. If possible do it at the same time as a timing belt replacement to cut down on labor costs Squeak or squeal from an engine belt Loud, high-pitched squeak or squeal Belts either need adjustment or replacing If belts only squeak when damp, they probably just need adjustment. If they squeak constantly, they probably need to be replaced Exhaust heat shield noises Rattle that you hear when car is idling Damaged heat shield Replace heat shield
Sep 28, 2016 | 2001 Nissan Xterra
Why my 2010 Venza drive on sometimes while driving it sound like the transmission is in neutral
Sep 28, 2016 | Cars & Trucks
Really Bad Squeeky Noise
It could be a squeal from the dryer belt. It could be from a belt that has gotten loose, like you hear on a car sometimes when it first starts up, but usually they don't get loose. They just break. Maybe something has gotten jammed between the dryer drum and the interior of the dryer making it hard for the belt to turn the drum and so it is squealing. Does the drum turn by hand without too much force and without squealing?
Feb 10, 2014 | Siemens WTXD5300US Electric Dryer
Makes squealing noise
You need to check the belt that drives the alternator for proper operation. The belt may be old and worn, or a pulley may be not freewheeling, but seized or with a bad bearing. Possibly the tension on the belt is too loose from a worn out tensioner.
First, spray a little water on the belt with engine running and see if noise goes away, possibly a worn belt. Pull the belt off and check all pulleys. Spin them by hand and see if spins easy, no rough feeling or a catch when spun. Check alternator pulley, idler pulley, tensioner pulley, PS pump pulley and A/C compressor pulley-check them all for free wheeling. If good check the tension on the belt when installed. If unsure, have a mechanic check tension with a belt tension tool.
If belt is good and pulleys good, check alternator output with a voltmeter on the battery with engine running. If voltmeter is below 13.5 volts, the charging system is still not working properly. Have it checked out.
Sep 29, 2013 | 2000 Mitsubishi Galant
Squeaking noises from front end of car. has gotten worse in the last 2 weeks
If the 'squeak' is from a car that is standing still open the hood and listen closely. A short hose; siphon hose, garden hose (about 2-3ft. long). Put one end up to your ear and move the other end close to engine. Be careful not to get caught in any moving parts; body parts, clothing, the listening hose you are using. Always be aware of where your body parts are in engine area & well lighted (avoid moving belts & beware of radiator fan starting automatically). You can pin point a squeak accurately...just as a doctor can listen to your lungs and heart with his listening device that works pretty much the same way. This technique works great for finding 'vacuum leaks' or internal mechanical problems; loose valves & which one may need to be adjusted...etc. You don't need to go deaf to all that noise...if it's to loud hold the hose further away from ear where it's comfortable for you to listen.
Sep 26, 2013 | 2000 Ford Mustang
Frigidaire dryer model # FDEB34RGS2 Squeaking
There is a tension pulley that holds pressure on the belt, as well as wheels that the drum sits on. A drop of oil on the bearing of each one should solve the problem, unless the wear has gotten too far, and need replacing.
Jan 01, 2010 | Frigidaire GLER642A Electric Dryer
Noisy dryer......when engaged...making squeaking/squealing noise.
If the noise is like a shaking of rattling , like coins being shaked , then it is an object trapped inside the drum.
If instead the noise is a loud grinding , that may get louder on high speed, then it is usually a bad drum bearing.
If dryer is not cooling, check that the noise is not coming from the ventilation fan.
Rollers and belt tensioner can also make noise.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Apr 09, 2009 | GE Spacemaker Washer and Dryer Electric...
Squealing NOISE possibly from fan belt
Belts stretch from new. Try to tighten them again. Hopefully the are not glazed or this may stay with you.
Dec 14, 2008 | 1988 Dodge Grand Caravan
Dryers Logo
189 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
