Question about Whirlpool Refrigerators
Whirlpool Gold model GC5SHGXLS00 temp control board is acting strange. When the door to the refrigerator is opened the LED Display for the freezer moves from 4 down to 1 and beeps until the door is shut. You have to manually reset the LED display back several times during a day. The freezer is more than plenty cold as is the refrigerator. Sugggestions? Thank you.
  • 27 Answers
SOURCE: WHIRLPOOL CONTROL PANEL
Hi. Your temperature control board display is bad. You may also have a power convertor board located next to the compressor. Normally you would replace the temperature control board first. I have a temperature control board listed on Ebay as item number 250211412492. Good luck, Mack
Posted on Feb 02, 2008
  • 27 Answers
SOURCE: Digital display is blank in GE Profile fridge
Hi. Its either a bad motherboard or control board. I would check the control board for any obvious signs of damage to the board first. I've seen the control board go blank on the GE side by side and it turned out to be the motherboard. The motherboard is located behind a cover on the back of your refrigerator cabinet. You should have a new motherboard on hand at all times because they fail alot. Be sure to put a surge protector on your refrigerator. Good Luck, Mack
SOURCE: I have a frigidaire sisde
Success!! I just bought a Frigidaire Gallery series side by side model # GLHS39EPJW0, in Canada. My temp readout was in F and I would like Celcius. The hidden button between the readouts I could feel, but it didn't work. However, holding the Fridge readout "up" and then pushing the Freezer readout "up" three times switched me from F to C on the fridge side. I repeated this but pushed the freezer "up" twice and the freezer readout changed to C. Thanks for the info - it helped out when Frigidaire couldn't.
Eden in Canada
Posted on Aug 09, 2008
SOURCE: WHIRLPOOL REFRIGERATOR
my refrigerator gold is running but not cooling I have the model number and serial numbers if that is helpful please help
Posted on Sep 15, 2008
SOURCE: Kenmore Elite bottom freezer refridgerator
I just went through this with my refridgerator and actually posted one of the questions. Here is what I found ........
In the freezer compartment behind the panel there is an evaporator fan which pulls cold air from the freezer and pushes it up into the refrridgerator compartment. If the fan is not working it is one of three things.. 1) there is so much frost in the fan area the fan blade is stopped and cannot push the cold air into the refridgerator compartment or the air channel is blocked. 2) there is no electricity going to the fan (usually tied to the door switch of the refirdgerator compartment, and 3) the motor is dead and will have to be replaced.
Solution to #1 - defrost but there is another problem in the "frost-free" part of the system which must be addressed or the frost will return and it will happen again in the future.
Solution #2 - check to see there is power to the fan. (most are 110VAC but some are 100VDC. Use a meter and check)
Solution #3 - If there is power, the motor is dead. Replace the motor. Be aware that AC and DC motors are different and replace per manufacture's specifications.
Posted on Nov 23, 2008
There is a constant buzzing noise coming from the lower freezer ice maker. It is producing very few ice cubes. The control bar is down and in proper position to make ice.
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
Cause of Beeping Noise in Frigidaire Refrigerator eHow
May 21, 2015 | Whirlpool Gold Series GB2SHTXTS (219 cu...
Whirlpool GC5SHGXLS00
Sounds like the main controller, contact Whirlpool service.
Nov 26, 2013 | Whirlpool Refrigerators
Refrigerator lights both not working. Freezer / Fridge LED Control numbers not lighting up. Still works fine. Freezer lights work fine. Whirlpool Gold Model GS5SHAXNL00.
Sorry to read about your problem, I hope this helps you out.
you lost a control board
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 23, 2010 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Vegetable crispers freezing my vegetables
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Dec 17, 2009 | Refrigerators
Whirlpool refrigerator model GD5rha does not cool but freezer portion does.
replace the control board usually lights are out in refrige side also ans temp readout is also out part # 4334000 appliance parts pros $80.25 shipped
Oct 23, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool gold gs5shaxnl side by side-the ref. side has no power and when the door is opened there is a clicking sound until the door is shut -temp is 33 degrees-everything is working on the freezer side...
replace the control board Part#4334000 appliance parts pros $80.25 if you recently blown a light bulb in the refrige section this will also ruin the board
Oct 11, 2009 | Whirlpool Refrigerators
I have a 2004 whirlpool gold model #gd5rha. When
you need a new control board,this is very common,especially if the bulbs on thr refrige side blow out,this creates a surge and ruins the control board $85.00 w/shipping at appliance parts pros or 1-877-477-7278
Oct 06, 2009 | Whirlpool Refrigerators
Whirlpool Gold GS6SHEXNL - Freezer works, Refrigerator cools but display and lights do not work.
From about an hour of searching your refrigerator I found that the problem is in the control board mounted on the back of refrigerator. Visit this link below and enter model number GS6SHEXNL into the search model and parts search feature. When you get to your refrigerator on left of screen is different prints, chose #11 and you will #18 in picture. Click on link below and following links to support this problem. Model GS6SHEXNL Part Number W10135090
http://servicepartstec.blogspot.com/
refrig-problem-5577/">http://www.diychatroom.com/f47/whirlpool-refrig-problem-5577/
If you need more help, just let me know, Thanks, Sea Breeze
Apr 22, 2009 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
Strange noise when door is open, light barely flickers, LED out.
I would try replacing the bottom door cam assembly. I have also seen the actual cabinet making a popping noise during opening which is there is no cure for that.
Apr 08, 2009 | Refrigerators
Refrigerators Logo
168 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
