Question about Dacor DCM24SS Convection Microwave Oven
Our 5 yr old Dacor DCM24S microwave is no longer heating. Power is on, it sounds like it is cooking when it is started, but the turning wheel in the oven is not turning and nothing warms up ... we have tried powering it off and back on, and we still have the same problem. Are there other things we should try ?
  • Dacor Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101 ???
Posted on Mar 27, 2011
Turntable will not rotate and food will not heat up.
If it is not cooking and the turntable will not turn, this sounds like the secondary interlock switch is bad. Almost always this failure is caused by opening the door when it is in a cook cycle. Pushing the stop button before you open the door will prevent this in the future..
Nov 04, 2013 | Dacor DCM24 Convection/Microwave Oven
Dacor Microwave DCM24S cooling fan continues to run
follow this steps and fix it. God bless you
  1. Interlock switchIf your microwave is turning itself on, the first thing to check is the interlock switch. This is usually the first thing to malfunction that could cause this issue. If the interlock switch is bad then it will need to be replaced.
  2. Main control boardIf your microwave is turning itself on and the interlock switch is still working, the probable cause is the main control board. If the control board is defective it will need to be replaced.
Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#9#ixzz2aNH65mG4
Jul 27, 2013 | Dacor DCM24SS Convection Microwave Oven
Dacor DCM24S microwave not working--not heating and table not rotating
The bottom door switch or its mount is bad.
See the service manual here and a help file on door switches here.
Nov 23, 2012 | Dacor Microwave Ovens
My DACOR microwaive/conviction oven (model no. DCM24S) suddenly went dead. all of the lights are off and it does not work. I checked the circut breaker I found it to operate properly. could you tell me wha...
We have the service / repair manual and parts list for this model and have uploaded them to our site here and here for free download to help you.
You can find Dacor parts by entering the part numbers at the Pros' Web site.
Oct 16, 2011 | Dacor DCM24 Convection/Microwave Oven
Can I get an electrical schematic for the Dacor DCM24S. Thank you. AE.
We have the full service manual for this model and have uploaded it for you here.
You can order parts (by part number only) from the Pros here.
Let us know if we can help further.
We're
Jan 15, 2011 | Dacor DCM24 Convection/Microwave Oven
Dacor microwave model DCM24s broken door latches
Many times restaurant supply houses can have what you are looking for in terms of hinges. However, when the hinges, seals, megatron tubes go....generally its time to go shopping for a new unit!
Nov 09, 2009 | Dacor DCM24SS Convection Microwave Oven
Dacor dcm24s.light, fan, and control panel work but turntable and heat do not
Most likely the bottom door switch. Dacor units are built by Sharp and that switch is a very common problem. You'd either need to check the switch with an ohm meter or remove the cover of the switch to see if it's burned inside.
Oct 20, 2008 | Sharp R-930AK Convection/Microwave Oven
Dacor Microwave/Conv Oven DCM24S
Placing the bag on an inverted glass bowl or pyrex casserole dish worked!!!!!  For 2 years, I have cursed my Dacor microwave for its inability to make popcorn (burns a hole in the bag, bag stays flat, almost no kernels pop, etc...)  I read the last suggestion to use the glass plate and I am now sitting with a bowl full of perfectly popped popcorn - with only 1 kernel unpopped.  The metal tray in the microwave conducts too many waves through the bag I guess.
Thanks for the solution!
Apr 15, 2008 | Dacor DMT2420 1200 Watts Microwave Oven
Dacor Microwave dcm24s
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
This can be caused by slamming the door or by habitually opening the door while it's cooking without hitting the Stop pad first.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Feb 14, 2008 | Dacor DCM24SS Convection Microwave Oven
DEMO MODE
how do i change the bulb inside the microwave ge xl 1800
Feb 13, 2008 | GE XL1800 1100 Watts Microwave Oven
Microwave Ovens Logo
166 people viewed this question
Top Dacor Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Steve
Are you a Dacor Microwave Oven Expert? Answer questions, earn points and help others
