Question about Sony Playstation 3 (PS3) Console
I have problem
Iam have work shop and most of problem come for me is , when i turn on the power it came green light then turn off by it self to red light again
can you help me please
thanks alot
    Scholar:
  • 65 Answers
I am guessing you have an xbox if that is the case try unplugging every cord from it for about 30-60 min and make sure you unplug the power cord from the wall as well. if that does not work comenet back here with more detailed disctiption of what happens or call Microsoft at
1-800-4MY-XBOX
International (direct dial to U.S.): 425-635-7180
Hearing Impaired (TDD device): 1-866-740-9269 or 425-635-7102
Hours of operation (every day):
9:00 A.M. to 1:00 A.M. Eastern Time
6:00 A.M. to 10:00 P.M. Pacific Time
Good Luck,
-Rel
Posted on May 30, 2008
Sir, Iam using the ZED-10FX Allen & Heath mixer. Iam not getting the 48V phanthom power and AUX out from the mixer both Green and RED LED on Phanthom power is not glowing. Iam getting the LED VU m
sOMEHOW YOU BLEW THE 48 v PHANTOM SUPPLY.
Open it up and check power board voltages.
Replace regulator circuit and check for shorts on your mic cables.
PEACE---
Feb 09, 2015 | Allen & Heath ZED-10FX Sound Mixer
Why does my Mitsubishi XD221U projector click and blink red/green on the power light when turned on?
All projectors run a self diagnosis when you press the power button. This does a kind of "pre flight check". If some component isn't working right then the projector won't fire up.
There's no mystery to these status lights. The answer to what they show is written in the manual. Sorry to be blunt, but if you had bothered to read your manual then you would know that red green flashing power light means that the lamp housing cover isn't closed properly. If it is the status light, then it means that the lamp has gone past its due time for replacement. I only know this because I read the bit in the manual just now about the Status Lights.
Sep 03, 2014 | Mitsubishi XD221UG DLP Projector
Does the green light come on after freezer is turned back on?
if you turn the freezer off for some time then on again the red light has to come on as an indicator for high temperature it goes off by itself when the freezer attains the required temperature according to the thermostat settings ,that is the lower the settings the faster the red light goes off. the orange light indicates super cooling and the green light indicates power supply.if you turn the two lights off and the freezer still works without the green light on that means that the bulb for the green light is faulty and you don,t need to worry
Jan 23, 2013 | Freezers
Iam wiring a celing fan with a remote(added). The wires from wall switch are green(ground), white(neutral) black(fan) red(light)? Hooked to the wall switch remote. 2. Fan green, white, blue, black. 3....
I'm an electrician and will be happy to help you out. I need a little more information to answer accurately first. 1) What is the brand and model number of the "ceiling fan with remote". 2) If replacing / adding switches, how many locations will control the fan / light fixture? Please provide this info and I'm sure we can get this working very quickly.
Dec 12, 2012 | Dryers
Power Problem with 2Wire 2701HG-B
Sounds like a startup self test. All wireless devices go through a power on self test. Does it connect? You can connect to it and go online? I rarely turn mine off, only in a electrical storm.
Nov 22, 2012 | 2wire (2701HG-B) Wireless Router
Mitsubishi big screen HD 1080 series model WS-55809. it switched off one day. and when i turn it back on it switches right back off. red light in front. what part do i need to fix it/
That model does not have a red light---Green.
If set powers up for a few seconds (green power light) and goes out do the self check the model indicated has:
On front of set (not with remote) press and hold both the input and menu buttons for at least 5 seconds and release both.
Green power light will blink a two digit error code like 2 blinks, 2 blinks a pause and repeat it several times.
Let me know what error code you find (if you have unplugged the set that will clear all errors and you have to plug it in and try to turn set on again---when it fails do the self check)
Mar 31, 2012 | Mitsubishi WS-55809 55" Rear Projection...
Screen won't turn on
You can try to do the monitor self test.
Monitor Self Test:
1. Physically test the monitor autonomously from the computer.2. Switch both the monitor and the computer off, and then disconnect the VGA cable le from the computer.3. Turn the monitor on, pressing the power button for about three seconds. The self-test screen will come up .4. If the image is clear, bright, and shows red, green, and blue, the monitor is working properly. Video issues may be due to the video resolution in the computer, and not the monitor.5. If the image is not apparent and intense or the colors are not accurate, then the trouble is with the monitor or some of the (OSD) settings. In this case, test your particular monitor's information for OSD.
It is always important to check the color of your power light for so you can distinguish if the monitor is defective. Getting red lights on the the power panel states that the power section of the monitor is faulty.
Dec 03, 2011 | Emerson Televison & Video
My kinect is not workin on the kinect its self only the red light is on and no green what is wrong and it is askin if my power supply is plugged in
Original Xbox 360 console
  1. Turn off the console.
  2. Make sure the power cord is plugged into a working electrical outlet.
  3. Make sure the USB connector is plugged into the back of the console.
  4. The light located near the middle of the split cable should be green.
    No green light? Try plugging the cable into another outlet to make sure the cable is working properly. If you still do not see a green light your cable needs to be replaced. Contact Xbox Support.
  5. Turn on the console.
Other solutions can be found on the Xbox support site by following the link below.
http://support.xbox.com/en-us/pages/kinect/more-topics/errors/red-light-kinect-sensor-1.aspx
Mar 08, 2011 | Video Game Consoles & Games
I am trying to hook up to my new comp. and new internet and the lights come on for the wireless, wired and router r green then the modem light is red, what am i doing wrong
There is nothing wrong with your modem. There are modems that when you turn it on, the wireless, dsl lights are green while the power light is red then after a few seconds, the green lights disappear and the red light will turn green. After sometime green light will come back on. This means your modem is restarting and doing a self check.
If the power light stays red, then you a have a problem with your modem.
Sep 10, 2010 | Computers & Internet
Tv wont turn on
i had this problem myself, press the power button and when it goes green press it again but hold it for 10 seconds, then it should work fine mine did good luck :)x
Jan 29, 2010 | Televison & Video
Sony Playstation 3 (PS3) Console Logo
26 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
