Question about Asko 24 in. 1585 Built-in Dishwasher
ASKO Model 1585 diswasher. The fan (in the door) won't shut off.
  • Asko Master
  • 19,396 Answers
Hi.
The door fan is the dryer (turbo) fan. The problem often happens when there is residual water at the bottom side of the tub.
trip the circuit breaker (or disconnect power cord), dry the water at the bottom of the tub(under the bottom panels) and restart the dishwasher.
If there is no water simply disconnect power to reset the dishwasher.
If the problem occurrs again and there is water, then there may be a faulty pressure switch (the sensor that detects water level).
If problem occurrs and there is no water it can be a faulty dryness sensor or a defective timer board.
Problem is usually fixed removing water and resetting the appliance.
Posted on Jul 11, 2010
  • newellm Jul 12, 2010
    I removed the water and cycled the power off and the fan continues to run. Is there a way to verify whether the issue is with the timer board or the moisture sensor?
Asko dishwasher model 1585
hi Servicing the Door Switch
On many dishwashers, the latch engages a switch to activate the timer and other control components. If the latch is not completely engaged or if the switch is faulty, the machine will not operate. Here's how to test and repair a door switch:
Step 1: Latch the door and hold the latch tightly in the closed position. This works best on a unit with a lever-type latch. Then turn the control to the ON position. If the unit works, the problem is probably a misaligned lock unit. Adjust the lock unit with a screwdriver. If this doesn't solve the problem, the switch may be faulty.
Step 2: Test the switch with a volt-ohm-milliammeter (VOM) set to the RX1 scale. Remove the panel covering the door switch and remove one of the electrical lead wires of the switch from its terminals. Clip one probe of the VOM to each switch terminal and shut the dishwasher's door. If the meter reads zero, the switch is working. If the meter reads higher than zero, the switch is faulty and should be replaced.
Step 3: Replace the switch with a new one of the same type. Connect the new switch the same way the old one was connected.
©2006 Publications International, Ltd.
For repairs to the timer, door latch, or switches, remove the control panel. To take it
off, remove a series of retaining screws and the control knobs, and lift off the panel.
Sep 14, 2008 | Asko 24 in. 1585 Built-in Dishwasher
Asko 1755 dishwasher. The pump keeps running We need to replace a new PCB P/N: DW955 8057931-05 Is it available?
My Asko Model 1585, Type DW 95.4 Circulation pump just died. I have the following parts available (All in working condition):
* 8057931-05 Control Board (this is the replacement part AFTER the recall)
* 8057083 Drain Pump
* 8057085 Fan circulation module (the one in the dishwasher door)
* 8057077 Heating Element
Photos and motor/coil/element resistance values available on request. I have no prices listed as I am still trying to determine their value. I am an old Boy Scout & NOT out to screw anybody.
Feb 20, 2011 | Dishwashers
I have an Asko Model 1585 and the detergent door will not stay shut and there is a constant noise coming from the door like a selonoid is stuck open. I turned the unit off at the breaker for fear of a...
Welcome to FixYa.
Based on the description you posted..." detergent door will not stay shut and there is a constant noise coming from the door like a solenoid is stuck open " You are bang on...unfortunately.
This is a red flag. In these scenario's 99% of the time the control and Combi-dispenser are both at fault. The control is no longer available according to the "repairclinic.com" website, but they have this note...
**Control board kit *Note: Consumers can contact Asko at (800)898-1879 option 3 for further assistance.**
The buzz you hear is indeed the solenoid for the dispenser, the control is sending voltage to the soleniod all the time.
If the component has failed both will need to be replaced, you can inspect and check the dispenser with an ohm meter and visually inspect the control board.
Having said this, If you remove the door and control panel and visually inspect the control you will most certainly see burnt circuits, relays or resistors on the control. i.e
**Be sure to turn the power off to the dishwasher before servicing...safety first**
The associated output components on the control unit for the dispenser to check are as follows,
Combi dispenser... Q12, R50, R58, D21, D23, P2 3 ( these are identified this way on the control unit. )
The last available control part number is # 80 579 31-4 and a good control if you can find one, should resemble the image here...
As for the dispenser, the original Asko number is 88 011 39-77, but now subs to 1399543 and is available at "repairclinic.com" It will look like this, front & back...
Hope this info helps move you forward, I know it isn`t a lot of good news.
Let me know what you find or if you require further assistance. Thank you for choosing FixYa and good luck.
Regards,
Macmarkus :)
Oct 27, 2010 | Asko 24 in. 1585 Built-in Dishwasher
All the lights stay on after a cycle completion even after I siphoned all the remaining water in the filter sump.(After opening and closing the door. ASKO model 1585)
Hello, the reason for the light flash error is the unit either didn't drain properly, overfilled somehow or has a leak which is filling the "overfill basin" ( it's designed to, that way it doesn't get to your floor...in theory ). Check your drain hose by removing it where it connect's to your home plumbing via under sink pipe or food diposer/garberator. You'll also need to remove the lower access panel, or kick plate as it is sometimes referred to, and absorb the water in the basin before it will run a cycle...or wait a few days for enough water to evaporate from the basin ( shut off the power/breaker before doing so ) then look for evidence of a leak. Check at the fill valve, (to the left) the drain pump, (slightly to the left-center) as well as the circulation pump & hoses, ( it is much more difficult to see...directly behind the big gray main sump assembly). That should get you moving forward. The Asko can be a challenge to work on if you've never worked on one. That is why I usually suggest calling a pro, preferably an authorized Asko servicer. It may save many unessasary part's being changed as I see too often with these. Hope that help's, good luck. macmarkus :)
Feb 28, 2010 | Asko 24 in. 1585 Built-in Dishwasher
Asko 1403 Dishwasher: soap door do not open during cleaning cycle
i know that some Indesit an Aristion models uses the same soap box.
Jul 08, 2009 | Dishwashers
Help for my asko diswasher
Unplug the washer for ten minutes, see if this clears the problem.
Aug 28, 2008 | Asko 24 in. D3350 Dishwasher
Asko 1585 wash cycle goes continuously until manually shut off
it may be a heating problem,does it get hot at all, or over heat.may be a thermistor fault.remove the door skin and see if rinse aid has leaked onto the wiring.or the board itself cauld be faulty,but are very expensive.hope this helps.
Mar 22, 2008 | Asko 24 in. 1585 Built-in Dishwasher
Asko 1585 Dishwasher
do they flash lik all on one side then the other? Start a cycle, then open the door. Do the lights flash the same way when you open the door as when it stops? if soyou may have a door that needs to be adjusted so it closes better. when the cycle ends, is there any standing water in the bottom? if so you may have a poorly routed drain hose or a partial clog in it. Last, pull the bottom panels off and look inside the bottom of the dishwasher and see if there is standing water down there . If ther is you have aleak somewhere or a bad drain pump. You r only other choice is a bad pressure switch. If youve already adjusted the water fil to the proper level ( just up to the grey plastic housing that the lower wash arm sits on) tehre really aernt any more options. Hope this helps!
Aug 29, 2007 | Asko 24 in. 1585 Built-in Dishwasher
Dishwashers Logo
98 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Owen Barnes
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
