I've got a Honeywell Environcare Elite filtration system on my furnace. How is the best way to clean these two units that slide into place and provide electrostatic cleaning? Can I soak in a laundry sink in some sort of cleaning mixture or do I pressure wash them or what? Thanks for your help, Russ
    Scholar:
  • 178 Answers
Honeywell Electronic Air Cleaners remove airborne particles as small as .03 Microns. To put that in perspective the smallest particle you can see with the human eye is 10 microns
Honeywell Electronic Air Cleaners have far more collection area to collect and store airborne particles than any other electronic air cleaner on the market.
Maintenance requires cleaning every two to three months. Located inside the unit are two pre-filters, which need to be rinsed off. The two electronic cells require a good rinse followed by washing them in your dishwasher.
Great for allergy sufferers.
This came from the link I provided below. Good luck.
http://www.americanairheatingco.com/residential/indoor_air_quality.shtml
Posted on Apr 19, 2008
How do I clean the filter?
Ultra Wash Filtration System - Kenmore Elite ... - YouTube
? 1:16
https://www.youtube.com/watch?v=wtfx6dajSyA
Feb 28, 2013 - Uploaded by Kenmore
The triple-filter system consists of two parts: An upper filterassembly and a lower filter. No one cleans better ...
Nov 06, 2015 | Kenmore Elite 45986 Front Load Washer
I have a F50E electronic filter. The light comes on, but there is no snapping sound when I push the test button. The cells and wires look ok. What could be the problem.
It's possible that the board is at fault. Triple check and make sure all the ionizing wires are in place on both cells and that the thin collector plates are not touching each other. Also, make sure the contact points are clean on both the cells and the cabinet.
The F50 is an obsolete EAC, so parts are becoming difficult to get. If the board is bad, I would recommend unplugging the unit and using a MERV 10 media filter in its place (Honeywell designed that EAC with the same cabinet as the media filter... all they did was add a power pack on top for the EAC. The media filter will slide directly in the cells place.) You will get better filtration with much less maintenance.
Mar 24, 2010 | Honeywell Air Purifiers
Honeywell HE260 leaks somewhere
Neither, even if the solenoid or humidistat stick, it should always drain properly. Is the unit mounted on the cold air return duct or the supply plenum? If it's mounted on the supply plenum, the water panel might be getting blown forward and spilling the water. High efficient furnaces also can leak water on the floor if its drain is restricted. If hum. is mounted on return duct make sure drain is clear by blowing through it. On Honeywell hum's I've seen the rubber hose from the solenoid valve to the distributor tray leak too, check the rubber 1/4" hose.
Dec 28, 2009 | Honeywell HE260A1010 Whole House...
F300E powers up in purge mode, but shuts off when heating
In the heat mode your furnace fan operates in a lower speed. when your zone panel purges it powers the G terminal in your furnace, which is high speed. You may have an airflow problem if your EAC is powered directly to an outlet, you may have a bad air pressure switch, or if the eac is wired to the furnace control board, it is mis-wired..more info needed.
Dec 12, 2009 | Honeywell Enviracaire Elite F300E-1019 Air...
Air filter location/fit problem
the main thing is to make sure no air is escaping around the filter you could always use something like a brick to keep it in place or bend a coastr hanger to hold it just make sure nothing hits the blower wheel
there are also a lot of high efficiency air cleaners that you can install in your system which is a yearly filter and has its own housing to hold the filters these filtrate a lot better than those 1" filters
Jul 17, 2009 | Goodman GMS90703BXA Heater
Environcare unit is not crackling.
Check the connections to the air cells (precipitators) and be sure you have a good connection - make sure none of the cell plates are touching each other
Mar 07, 2009 | Honeywell Air Purifiers
Can't get the Honeywell F300e EAC back together.
there is a plastic cell key that keeps you from putting the cells in backwards. Simply reverse the cells and they should slide in fine.
I/O is the power switch, I think O is off.
Jul 18, 2008 | Honeywell Enviracaire Elite F300E-1019 Air...
Honeywell F300E not cleaning air.
A newly installed system should still be under the contractor's labor warranty. Call them and ask them to come out to check on the unit and explain what you wrote above. This should cost you nothing and is the best way to get to the bottom of the problem.
Nov 09, 2007 | Honeywell Enviracaire Elite F300E-1019 Air...
Heating & Cooling Logo
146 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
