Question about Sceptre X20WC (Black) LCD Monitor
Hello. My sceptre x20wc-gamer moniter used to work fine but now it just goes blank after several hours. Almost like I have to stop using it and let it cool down. Any suggestions?
5 Suggested Answers
SOURCE: Sceptre X7g Monitor Flashing Red & Blue Lights. Blank Screen
i fixed this problem by unplugging the monitor, unplugging the video cables. Then hold down the power button while plugging it back in. Release power button and then press power button for on. It worked then. I got the icon for no signal, i plugged back in my monitors. Sceptre X9W
Posted on Mar 10, 2008
  • 109 Answers
SOURCE: X20G-Naga III screen goes blank after 1-2 secs
most common lcd monitor break down, check all electrolytic capacitors for leakage and loose board solder specially on the ccfl inverter section.
Posted on Jun 01, 2008
SOURCE: X22WG-gamer sceptre 22" monitor won't power on
Your monitor has 3 or 4 blown caps right next to the power plug. They are CapXon 470uf25v. Just open the back and remove the power board, desolder, and replace the 3 or 4 caps put it back together and it should go back to working. This a typical problem with the Sceptre gamer, HP1706, and the HP1903. And guess what they all have the same caps blown in almost the same place.NOTE: When seperating the case the power led is glued to the front frame. Take your time if you rush you will break a cable wire or plug.
Posted on Oct 09, 2009
zaldyboy01
  • 293 Answers
SOURCE: I have a sceptre x20g naga III screen goes blank
if you have the warranty, return it and get a new one free. ok
Posted on Feb 19, 2010
Mitsubibishi wd series 73"..Mitsubishi ws series 73" dlp. Works fine but after several hours of viewing screen scrambles then goes blue and sound goes off. I can switch to another input and watch ama
A couple of suggestions, if only on cable and using a box disconnect the set and box from power and after several minutes repower and see if a reboot helps.
The two models listed here both should also have a soft reset done with the original remote and the set on---Menu,1,2,3, enter.
Dec 20, 2012 | Mitsubishi WD-52525 52" Rear Projection...
I turn on the computer on and it the monitor turns on then off.
Try another monitor - if it does does same thing, your graphics card may be the problem. If not, then it's the monitor.
Oct 24, 2010 | Sceptre X20WC (Black) LCD Monitor
My Sceptre x20wg has gone blank. The blue light is on and "clicks" every couple of seconds. There is no display
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed Sceptre and all monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Aug 16, 2010 | Sceptre X20WC (Black) LCD Monitor
X22wg-Gamer Monitor: It appears the power supply is dead, what can I re...
you need to check if your capacitors are blown, if they are, you can replace them...it's a very economical way of fixing it. This is a common problem of Sceptre x22wg-gamer.
May 16, 2010 | Sceptre x22wg Gamer Monitor
Feb 19, 2010 | Sceptre X20g-Naga III 20.1" LCD Monitor
We have hardly used our C2 due to continuous house moves[purchssed new in 2005/6] went to set it up today and the screen just has a series of vertical and horizontal line and then goes blank
I to have a C2 rowing machine with a PM3 moniter which i havent used since August last year, and i decided to use it to help loose the excess Christmas pounds and the moniter sounds like it does exactly the same as your moniter with the vertical and horizontal lines then goes blank. I bought the rower new about 2/3 years ago and it hasn't been used too much.
If you find a solution to the problem please let me know thanks (jm@manx.net)
James
Nov 04, 2009 | RTO Concept2 Model D Rowing Machine with...
X22WG-gamer sceptre 22" monitor won't power on. It's not the power cord because I've used the power cord on a different monitor and it worked fine. Any and all assistance will be much appreciated.
Sep 07, 2009 | Sceptre x22wg Gamer Monitor
Moniter is not powering up.
unfortunately. This is a classic symptom of a faulty inverter board. I would suggest looking on ebay to see is there is a cheap replacement. Purchasing a new one is usually not economical these days.
Jul 11, 2009 | Sceptre x22wg Gamer Monitor
My Sceptre x22wg-Gamer Monitor isn't getting any power, HELP!!!
I have two of the X22WG monitors, both dead. The power supply in this model is apperently plauged with a common error. The problem is close to the +5V and +12V output connector (Far right corner, with power plug against you). Two out of the four small caps are blown. Replace those, and it should be fine. C551 and C552.
Jun 09, 2009 | Sceptre x22wg Gamer Monitor
Monitor goes blank less than a second after turning on.
the moniter may be having  some technical errors   maybe the IC's has got corrupt
you need to call the seller of the moniter
Sep 06, 2008 | BenQ FP71G 17" LCD Monitor
Sceptre X20WC (Black) LCD Monitor Logo
Top Sceptre Computers & Internet Experts
Robert Veldman
Robert Veldman
methjd
Are you a Sceptre Computer and Internet Expert? Answer questions, earn points and help others
