Question about Samsung SyncMaster 930B 19" LCD Flat Panel Monitor
Brightness box I've had this monitor for about a year or two. All of a sudden the adjust brightness box keeps flashing on screen and won't go away. Sometimes it stays up for a few seconds sometimes a few minutes. It's really annoying since it blocks a portion of the middle of the screen. Any help or suggestion is appreciated.
  • Anonymous May 01, 2008
    I have a Samsung SyncMaster 720N 17inch monitor that does the same thing. the Brightness box flashes on the screen and stays there. Very annoying predicament. A driver problem? reinstall driver to fix?
  • 180 Answers
I suggest you to track faulty component at logic board.
Posted on Apr 20, 2008
Screen brightness
Changing the Screen Brightness
1. Press the Home Key > Menu Key > System
settings > Display > Brightness.
2. Check the Automatic brightness box to make the
phone adjust the screen brightness automatically
or clear the check box to adjust the brightness
manually.
3. Tap OK
Mar 10, 2014 | Tracfone Wireless ZTE Valet
How do I turn down brightness on my hp Windows 7 computer?
Below are instructions to adjust brightness on HP laptop
    • Press the "Fn" key with the computer turned on and hold the key.
    • Press the "F7" or "F8" key on some HP laptops, which are printed with a small sun icon on the key. The sun icon is filled on the function key for dimming the laptop. The other key is printed with a hollow sun icon for brightening the screen.
    • Press the "Fn" and left arrow keys together on some HP laptops to turn down the brightness. The "Fn" and right arrow key will increase brightness. Press and release the right arrow key repeatedly, while holding down "Fn," to decrease the screen brightness slowly, or hold the keys to darken the screen as low as the setting will go.
  1. For HP Monitors
    • Press and hold the down arrow key on the front panel of the monitor below the screen to turn down the brightness on the external monitor to the lowest setting.
    • Repeatedly press the down arrow button to dim the monitor gradually.
    • Press the up arrow key on the monitor to increase brightness.
Regards,
Rahul
Jul 15, 2013 | Computers & Internet
I have a brighten symbol that keeps popping and I can't get it to go away right in the middle of screen
go to set up menu then select the brightness adjustment and then exit.if can get with adjustment turn off then unplugged don't use for an hour to reset the power supply.
Aug 12, 2012 | Mag Innovision LT776s 17" LCD Monitor
I would like to reduce brightness on my ASUS VH242H
Actually, the problem isn't with the drivers. Right click on the battery icon in your system tray. Select "Power Options" (NOT Power4Gear eXtreme). On the right panel, select "Adjust the display brightness." Then, select "Change advanced power settings." Scroll down and open up the "Display" box. The options that are affecting your screen brightness on battery are "Allow SmartDimmer to reduce my brightness after," "Have SmartDimmer reduce my brightness by," and "SmartDimmer full-screen video mode." Playing with the percentages in these boxes will affect how your screen brightness adjusts itself. To get my screen to stop re-brightening itself, I changed "Allow SmartDimmer to reduce my brightness after/ On Battery:" to 100%. I then changed "Have SmartDimmer reduce my brightness by/ On battery:" to 0%. Finally, I set "SmartDimmer full-screen video mode/ On battery:" to Maximum Power Saving. This should solve your screen-rebrightening problems even with the 163.44 drivers (I use those too). Please Rate.
Thanks, Anand Fixya
Dec 23, 2010 | ASUS VW193T Monitor
The brightness adjustment scale keeps appearing. I
Hi!!! You can end process by going to task manager and click processes tab. Look for the brightness adjustment among the list and click end process.
Hope it works!
^_^
Jun 03, 2010 | iiyama AX3817UT D 15" LCD Monitor
I have an ACER X203H and cannot adjust the contrast or the brightness. I can bring up the MENU, however I cannot adjust because when I HIT ENTER the menu disappears.
Press the Menu key on the Monitor to bring up the dialog box press Menu again because it defaults to the Brightness Icon. You will see the lower half of the dialog box change color. Use the left or right arrow to move off of Acer eColor Management to the User setting. Then press Menu again to edit contrast or brightness. User the left and right arrows on the Monitor to move to the desired adjustment, press Menu to allow adjust then arrow left for less or arrow right for more.
You really just keep moving between the Menu and arrow til you get it right.. I definitely needed to turn down the brightness on my monitor.
May 04, 2010 | Acer X203H bd Monitor
Monitor brightness contrast problem
Turn Off auto-adjustment screen
Jul 29, 2009 | Proview PL19Wb Monitor
Problem with brightness of monitors SyncMaster 710n
HelIo! right after computer inclusions on the monitor screen have a tablet with the message which disturbs to work. The message: brightness of the monitor of 100 %! A problem: how to clean from the screen this tablet so she prevents to read the information. I have not found adjustment in the menu of the monitor brightness. And what should be brightness: 100 % or another? have not found adjustment in the menu of the monitor brightness. And what should be brightness: 100 % or another?Thanks and sorry about my bad english. Afzal.
Sep 06, 2008 | Samsung SyncMaster 710N 17 in. Flat Panel...
Display problem
the adjustment box for colour, brightness and contrast stays fixed on the screen. i tried pressing the exit button.... after a few times it disappears only to reappear within a few minutes. also the auto adjustment option, for which we are supposed to manually press the i button, keeps auto adjusting the screen whenever it feels like it. the box appears right in middle of the screen and is a real nuisance as it blocks out the main portion.
Jun 28, 2008 | BenQ FP547 - 15" LCD Monitor
Hp pavilian f1703 monitor
Press the menu button again (or when done adjusting) and it will go away.
May 09, 2008 | CTX S762A 17" LCD Monitor
Samsung SyncMaster 930B 19" LCD Flat Panel Monitor Logo
374 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
