Question about GE Profile Spectra JGBP90 Gas Kitchen Range
When press bake button oven is not heating up
  • 375 Answers
Find the bake ignitor (you may need to remove bottom drawer or oven cavity floor to get to the ignitor). Turn on the bake. If the bake ignitor comes on (starts glowing after a few seconds) - check the amperage on the bake ignitor wires when it's on. If the ignitor is a round style - amperage should be 2.5-3A, if the ignitor is rectangular - 3 - 3.6A. If less than 2.5A or 3A respectively - replace ignitor. If the ignitor does not come on - check the voltage on the ignitor, should be the line voltage 110-120v AC. If there is a line voltage on the ignitor and it's not coming on - replace.
Ignitor part numbers for round style ones: 4342528, WB2X9154, SGR403, 5304401265;
rectangular styles: 12400035, WB13K21, WB2X9998, SGR412, NR020, 5303935066, 814269, 9753108.
Ignitors of the same shape (i.e. rectangular) are interchangeable, if you can splice the wires.
Posted on Jul 15, 2010
Oven will not heat at all. Stovetop works fine
Phillip, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Oven Wont Heat or Not Working Bake and Broil Element Testing Oven...
Electric Stove Troubleshooting Oven Not Working
Top 6 Reasons Electric Oven Wont Heat Electric Range Troubleshooting
Stove Terminal Block Replacement Frigidaire Electric Range Repair part...
Jun 17, 2016 | Kitchen Ranges
How to turn on electric frigidaire oven; fgf337gud?
Good Morning Friend,
I understand you want to know how to turn on the oven on your Frigidaire range, model# FGF337GUD. First, make sure you have set the clock. You will do this by pressing the "Clock Set" button and then press and hold down the up or down arrows, until the correct time shows. After you have set the clock, you are ready to turn your oven on.
To set the temperature for your oven, you will press the "Bake" button and three dashes will appear. Press the up and down arrows to change the temperature. Note: The temperature will begin at a default temperature of 350 degrees. Once you have released the up or down arrow, your oven will begin heating to the selected temperature. When your oven reaches the desired temperature, it will beep once.
To cancel the baking function, you will press the "Clear/Off" button.
If you wish to change the temperature after baking has begun, you will press the bake button again, and then change the temperature by pressing the up or down arrows to either increase or decrease the temperature.
I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your air conditioner status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 13, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
I need to learn how to use my oven, because i don't know how to turn it on.i need to bake,so can u tell me how?
You can get the manual for the RGB745 at the GE Appliances support site: http://www.geappliances.com/service_and_support/literature/ . Enter the model number in the search box. There are several models that start with RGB745.
On most of the Hotpoint ovens for regular baking, press Bake and use the + or - buttons to set the desired oven temperature. Then press Start/On. Then the oven will display Pre as it re-heats. When the thermostat indicates the desired temperature is reached, the oven will beep. The racks should be on the middle positions for most baking. (For roasting use the lowest positions.) Put the food in when the oven is done preheating. When done, press Clear/Off. Timed baked requires the clock be set correctly, then set the start and end times.
For the older ovens with dials to control the oven, set the first dial to Bake and the second to the desired temperature. Wait at least 10 minutes for the oven to preheat. Again put the oven racks in the middle of the oven for most baking.
Do not lock the oven latch and keep the oven closed through the baking cycle as much as possible. (Rotating pans and basting steps should be done quickly so that the oven doesn't cool much.)
I hope this helps.
Feb 11, 2011 | Hotpoint RGB745 Gas Kitchen Range
Oven won't heat past 290 after that we get an error message
Your oven is in celcius mode to change press bake and broil at the same time SF will appear then press broil and cooking time at the same time a C will appear press again to toggle to farenheight then press start to lock it in that mode. Some models when you press the bake and broil the sf will appear if it does press the press the broil button to toggle between C & F then press start.
www.appliancehelponline.com
May 21, 2010 | GE Profile JTP18 Electric Single Oven
The bake button is not going on how do i fix it
The bottom element is bad...and not working...
Check out this tip that I wrote about this problem...
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
May 03, 2010 | Magic Chef CGR3742 Gas Kitchen Range
Broiler element comes on when "bake" is pressed
does the bake element come on at all?
if so, try the oven out. do a bake @ 350 allow it to pre-heat, and see if once the pre-heat is comlete, id the broil shuts off.
on many ovens at the beginning of the cycle during pre-heat both bake and broil elements are powered.
other than that it may be a control board, or a burnt and crossed wire in the harness.
May 28, 2009 | GE JTP15 Electric Single Oven
TAPPAN gas range model 30-3991-00/03 oven won't work.
the button your holding is the switch that tells the board that the consumer whats to bake.so if holding the switch causes that message to work[or oven to heat] and letting go of that button ,then no work .its that button ,but its all part of the board .just that part of its funktion is broken.,if it was lets say your oven ignitor or oven gas safty valve ,the board/oven control[the one with the button]would continue to try after you have selected bake [pushed button]or would give error code.hope that helps you. God bless you , tom
Jan 05, 2009 | Tappan Kitchen Ranges
Instructions for Frigidaire oven missing.
I found the manual online. Apparently my unit is malfunctioning and should work by just pressing bake temp and then selecting the temp...
Dec 02, 2008 | Frigidaire FEB27S5A Electric Single Oven
Whirlpool Accubake oven super capacity series 465
Press and hold the Broil button for 5 seconds. You will see the c change to f. THen change the temp to what you need.
Dec 21, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
725 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
